Introduction: Picture Art
looking for a nice gift to give someone? or a deco for your bedroom? I found just the thing!
PICTURE ART! try it out! i was able to do this proyect in one afternoon! :)
Step 1: Find an Old Picture Frame.
First of all, you will be needing an old picture frame. I used one that had been re-used once and i re-used it again! :) Then, you have to make sure that the surface is plain and smooth. So, if the painting has been re-used ; tear the paper off and make it smooth by rubbing it or sanding it!
Step 2: Flat Surface
After you have the painting smooth you will need to make a flat surface so use a bit of carboard or something similar and go sticking it onto the the painting!
Step 3: Clean the Frame
If your frame is an old one, you might need to clean it up a bit! (I sure did!)
Step 4: Painting!
Now, you can start painting! I choose to do it black and White but feel free to choose any other color!
The easiest way to paint is to do one spripe at a time with tape between each one. Again, i choose spripes, but you can paint whatever you want!
To make the proyect a bit faster, use a hair dryer to go drying the paint!
Step 5: Strings
Now... Start sticking pieces of string to the sides of the frame! I did it at random but there are many other designs you can do!
Sticking with white glue can be one of the best ideas.. :)
Step 6: Add Your Pictures and DONE!
All you have to do now, is wait for everything to dry and get decorating!! :)
Have fun! i hope you make a great proyect!
