Introduction: Picture Frame Tool Pegboard
Add a touch of class to any workspace with this Picture Frame Pegboard! The frame and backing were found free on Craigslist. The tool holders were purchased from a local hardware store.
I wanted an interesting way to store my basic tools so I wasn't always digging around the messy tool box. It looks great and was surprisingly easy from start to finish! Its a fairly simple design, basically replacing the backing of the frame with pegboard.
Step 1: Materials & Tools
Materials:
-Stylish frame. The bigger, the golder, the gaudier... the better!
-Pegboard
-Screws
-Drywall anchors
-Screw hooks
Tools:
-Screwdriver
-Drill
-Saw
-Marker
-Measuring Tape
-Level
-Pegboard
-Screws
-Drywall anchors
-Screw hooks
Tools:
-Screwdriver
-Drill
-Saw
-Marker
-Measuring Tape
-Level
Step 2: Preperation & Sawing
Unscrew the backing from the frame and place it over the pegboard. Trace a line to the exact size.
If the frame did not include any backing, measure the frame and trace measurements to pegboard.
Cut the pegboard to size.
Step 3: Drilling & Screwing
Mark holes on the pegboard to match screw holes on frame. If the frame does not have pre-drilled screw holes, evenly mark spots for screws to attach pegboard to frame, giving extra support in corners.
Line up board with frame and secure with screws.
Attach hooks to the screws at the top of the frame to easily attach to wall.
Step 4: Hang Board & Tools
Mark on the wall where the board will be hung, and mark where hooks will attach to screws. Make sure the holes are level. Drill screws into wall using appropiately-sized drywall anchors. Drilling into the wall studs could work as well.
Leave a little space between the screw head and wall to hang the hooks.
Now it should be all complete! Using assorted pegboard hooks, I filled the board with my most commonly-used tools. It looks great even as wall art! Also, it can be easily removed and transportated if needed, unlike a larger, more permanant fixture.
