Introduction: Picture Frame With a Strong CNC Joints
There isn't much new about picture frames but recently I had to make one. And instead of do the the tradition method of using a spline to reinforce the mitred joints. I used a CNC to make a sort of finger joint miter. Which turned out to be pretty strong. So I thought I would share it.
Step 1: Stock Preparation
Step 2: CNC the Joints
I used my xcarve to CNC the joints. Here is a link to the file in easel inventables Project.
I used 3mm bit to cut the wood.
Step 3: Glue Up
Step 4: Router
Step 5: Backing Board and Clear Plastic
i used a knife to cut some clear plastic and backing board for the picture frame. it took several cuts to get all the way through the backing board. and i was able to snap the plastic after i scored it.
Step 6: Finish
Assembled the frame and used some tape to attach the backboard to the frame. I didnt want to get fancy with hardware to hang the frame so I just drilled a hole so it could hang on a nail. This could of also of been done during the CNC stage.
Step 7: Finished
And that's it all finished. I finally got to hang up this picture that I've had for 5 years.
The CNC joint worked better than I thought it would. I intend to make some different styles and see how they work.
