Introduction: Pier 9 Machine Catalog
The Pier 9 Workshop has a brand new website!
(This includes details on our entire machine catalog)
Please visit us HERE for current projects, events, and updates about the happenings at the workshop.
More information about the Artist in Residence Program can be found on their website or fantastic vimeo channel.
As of 08.2015, this instructable will no longer be maintained.
Welcome to the Pier 9 Workshops!
This is a live catalog of the machines we are currently using in our shops, including model numbers and links to machine spec's. We have 7 amazing maker-spaces on the Pier: a Digital Fabrication Room, Woodshop, Metalshop, 3D Printshop, Project Room, Electronics Shop, and Commercial Kitchen.
We are accumulating links to additional guides, tutorials, and example projects (being produced in our workshop) in the final chapter of this Catalog to help you get started with our machines!
We will keep this Instructable updated as we acquire new equipment or augment what we have. You can address more specific questions/comment/requests to P9Workshop@Autodesk.com.
More information about the Workshop, including how to become a Shop User is in Autodesk's Pier 9 Workshop Instructable.
Step 1: CNC Machines
Our CNC Shop Lead has put together a comprehensive and deeply knowledgeable guide to operating CNC machinery: Learn CNC the Hard Way
Our CNC Machine Shop houses this collection of world-class machines:
- DMS 5-Axis Enclosed Router Model: 5O5-5-5-36S
- material capacity: 5' x 5' x 3' (z-axis)
- 8 position tool rack
- additional specs
- HSM to DMS Workflow Tutorial
- Caldera Table - Artist in Residence project
- Omax Waterjet Model: 60120
- material capacity: 10' x 5' x 8" (z-axis)
- 5-axis abrasive waterjet cutting capabilities
- additional specs
- HAAS Lathe Model: ST-10Y
- material capacity: 9" x 14"
- 12 position live tooling
- HAAS Vertical Mill Model: VF-2SS
- material capactiy: 30" x 16" x 20" (z-axis)
- 24 position live tooling
- additional rotary table
- Mori Seiki Integrated Mill-Turn Center Model: NTX1000SZM
- material capacity: 15" x 4" x 18" (z-axis)
- 38 position live tooling
- multi-axis milling center with lathe and mill capabilities
- ShopBot 3-axis CNC Mill Model: Buddy
- material capacity: 24" x 48" x 6" (z-axis)
- 5 HP Colombo RS90/22 Spindle
- Speroni Tool Setter Model Magis 400
- Haimer Power Clamp Preset Model 80.222.00
2.11
Step 2: 3D Print Shop
The 3D Print shop includes:
- (7) Objet 3D Printers Model 500 Connex
- 19.7" x 15.7" x 7.9" build envelope
- materials:
- Vero (mimics Acrylic) in: white, black, clear.
- Tango (flexible material) in: black, clear.
- Assorted types/colors: ABS mimic/ivory, Medical Grade (some FDA approval)/clear, Polypropylene mimic
- prints over 1000g resin or 1000g support material must be approved in advanced by Shop Management: P9Workshop@Autodesk.com
- (4) Epilog Lasercutters Model Legend 36EXT
- 3@120Watts, 1@75Watts
- 24" x 36" workbed
- materials: wood, acrylic, glass, plastic, stone, fabric, and paper
- Coherent Lasercutter Model Metabeam 400W
- 48" x 48" x 12" (z-axis) workbed
- materials: Sheet metal to 1/8”, Stainless Steel to 0.65”, Aluminum up to 0.020”, Plastics and Wood to 1”
- Mcor IRIS 3D Paper Printer
- 9.39" x 6.89" x 5.9" build envelope
- material: 20lb copy paper, standard letter size (8.5"x11")
- Roland Versacamm Wide Format Printer Cutter Model SP-540i
- 54" wide print capacity
- 1440 x 720 dpi resolution
- Learn to USE THIS TOOL with our Shop Staff instructable
- software: Arctec Studio
- good for quick scans, people, human to automobile scale
- good for small, highly detailed scans
- (2) High Pressure Waterblasting Stations
2.11
Step 3: Woodshop Machines
Our Woodshop houses the following machines:
- SawStop Tablesaw Model ICS 73480
- 7.5hp motor, 10" blade
- maximum cut depth: 3-1/8"
- Video: Sawstop Accident Prevention System
- Makita 10" Sliding Compound Miter Saw Model LS1016L
- maximum crosscut: 12"
- maximum depth cut: 4-3/4"
- Laguna 20" Disk Sander Model MDISK2000-0175
- 2hp, 25.5" x 14.5" table, -30° to +45° tilt
- Laguna Oscillating Spindle Sander Model MSANOS14x14-110V-1/2-0320
- 14" x 14" table
- 1/2hp, 0° to 45° tilt
- JESSEM Router Table Model Mast-R-Lift Excel II
- 32" x 24" table with aluminum slot guides
- digital height adjustment readout
- maximum bit diameter: 3.5"
- Delta Drill Press Model 18-900L
- 6" Quill Stroke, 22.25" Chuck to Table capacity
- 3/4hp, 16 speeds, 5/8" chuck capacity
- Martin Jointer Model T54
- 19.5" max cut width, 5/16" max cut depth
- 90° to 45° fence tilt
- digital depth of cut display
- Martin Planer Model T45
- 0.11 - 11.8" planing height range
- 24.75" max material width
- 7/16" max depth of cut
- Tormek Sharpening Station
- precision water sharpening stones
- Laguna Resaw Master Bandsaw Model
- 18" max material height
- 1/4"-2" blade capacity
- Powermatic Belt/Disk Sander Model 31A
- 12" disk, 6" belt
- Supermax 25 Drum Sander
- material min length: 2.5", min thickness: 1/32"
- material max width: 25", max height: 4"
- sanding drum grit range: 36, 60, 80, 120, 150, 180, 220
- Quick Start Guide to using this machine
- Incredible selection of hand tools including:
- hand planes, carving tools, chisels, spokeshaves, etc
- Sjobergs Furniture Making workbenches
- Excellent selection of portable tools including:
- circular saw, sawsall, jigsaw, orbital sanders, and selections from the Festool system
2.112.11
Step 4: Metalshop Machines
Our Metalshop is home to the following machines:
- DoAll Vertical Bandsaw Model 2013-V
- 440V, 16A
- 20" throat
- the manufacturer's machine manual online
- Cold Saw Model CPO 350
- 230V, 10A
- 45 Deg. right and left miter capabilities
- Capable of slotting
- Pneumatic Brake/Bending Machine Model UF-25H
- maximum bend: 180 Deg.
- tubing limits: 1 1/4 schedule 40 pipe, 1 5/8 OD 10 gauge round tubing, 1 1/2 10 guage square tubing
- lockable gauge enabling angle repetition
- DoAll Horizontal Bandsaw Model 400S
- 460V, 6A
- swivel head to 45 Deg.
- pneumatic head raise with adjustable height stop
- size capacity: 9" high x 16" wide for rectangles, 10 3/4" for rounds at 0 Deg.
- Solberga Drill Press Model SE 2025
- 230V, 10A
- power feed
- Bridgeport Mill Model BPKMR8XY
- 230V, 20A
- X and Y axis Servo Power Feed
- Acu-Rite Digital Readout
- an excellent guide to squaring the vise on the mill table
- Manual Metal Shop Lathe Model 1118H
- 230V, 20A
- DC Feed Motor, 75 Watt, 110V
- Carriage power feed range: 5/16-7"
- Cross slide power feed range: 4/16-4"
- Millermatic 252 Mig Welder Model 951006
- 440V, 21A
- Miller Dynasty 350 Tig Welder Model 951402
- 440V, 16A
- Pneumatic Press Model 72002
- single acting cylinder
- each full stroke advances the ram 1/2"
- Powermatic belt/disc combo sander Model 31A
- 230V, 10A
- belt head locks at any angle from 0 to 90 Deg.
- indexing pin for 0, 45 and 90 Deg.
- belt table also tilts for beveled and miter cutting
- 12" disc
- Dayton Combo Belt and Bench Grinder Model 3NYA7
- 120V, 7A
- Wheel Dia: 8"
- Max RPM: 3450
- Sandblaster Model BPKMR8XY
- 230V, 20A
- Work Area: 46 x 36 x 35
- Buffing Wheel Model 407B
- 120V, 7A
The metal shop also includes an extremely wide variety of metal working hand tools, pneumatic and electric tools.
2.112.11
Step 5: Sewing+Project Room
The Project Room includes the following tools:
- Centroform Vacuum Forming Machine Model SV 1217
- Juki Sewing Machine Model DNU-1541S
- Juki Surging Machine Model MO-6916J-3
- Singer Futura Sewing and Embroidery Machine Model CE-250
- Hoop size 3.125" x 4.75"
- Manufacturer's User Manual
- Manufacturer's Video Tutorials
- Workshop Instructable for getting started
- Bernina Sewing Machine Model 950
- Bernina Surging Machine Model 1300MDC
- Professional Iron and Steamer Model MVP-35
- Park Tool bike stand, hand tools and pump
The Project Room also contains a wide variety of project and sewing supplies and a photography backdrop station. .
2.11
Step 6: Electronics Room
The Electronics Lab has the following equipment:
- Oscilloscope Model GDS-1152A-U
- 150/100/70MHz Bandwidths
- Up to 27 Automatic Measurements
- Triple Linear DC Power Supply Model HY3005F-3
- Dual adjustable outputs: 0-30V and 0-5A
- Fixed output: 5V and 3A
- Input voltage: 110V AC and 220V AC switchable
- BK Precision Spectrum Analyzer Model 2630
- 150kHz to 1.05GHz (1050MHz)
- 20 and 400 kHz resolution bandwidth
- 150kHz/hour stability
- Built-in tracking generator
- BK Precision Programmable Function Generator Model 4087
- Frequency range:1 uHz up to 120 MHz for Sine
- Sine and square output plus 27 additional built-in arbitrary waveforms
- Support of internal and external modulation sources as well as internal, external, and gated trigger sources
- Salae 8 Channel Logic Analyzer
- Voltage Range: -.5V to 5.25V
- General Resources
2.11
Step 7: Commercial Kitchen
Our Commercial Test Kitchen includes:
- Sub-zero/WOLF Gas Range Model R606DG
- 60" Range with dual ovens
- Waring Deep Fryer Model WDF1550
- 15 lb capacity
- Sous VideModel Pearl L
- 15.2 gal water bath, 5.9" immersion depth
- Excalibur Dehydrator Model D900SHD
- 9 tray, 15 ft2 capacity
Step 8: Guides + Tutorials for Our Machines
Guide to Buying Project Materials at Pier 9
Written by: 3D Printroom Lead - Gabe Patin
Designing Vectors for CNC & Digital Fabrication
Written by: Workshop Instructor - Martin Horn
Applies to:
- laser cutters
- waterjet cutter
- Shopbot CNC router
Quick Start Guide: Roland Versacam Vinyl Printer/Cutter
Quick Start Guide: SuperMax 25 Drum Sander
Written by: Wood/Metal room Lead - Josh Myers
CNC Room Tool Library and Resource
Written by: CNC Room Lead - Dan Vidakovich
Comprehensive Guide to learning to use CNC Machinery
Inventor HSM to DMS Router: 3+2 Axis Workflow
Written by: Artist in Residence Xander Bremer
How to Square a Vise on the Mill
Written by: Artist in Residence Bryan Smith
1 Person Made This Project!
- daniel caire made it!
18 Comments
5 years ago
WOW! OMG! It is heaven on earth!!
6 years ago
Awesome machines. Looks like a showroom rather than a makerspace. So clean indeed :D
6 years ago
I'm going to build a huge drone to pick up that building and fly it to my evil lair on the top of the mountain!
6 years ago
What a cool place! It's on my list!
6 years ago
What can you tell me about the go-kart shown in Step 3: Woodshop Machines?
7 years ago on Introduction
I think I'm in love <3
Reply 6 years ago
indeed... i visited pier 9 last summer on a vacation... it is flippin awesome! really wanna work there!
I want to work here when I am able to someday.
You don't have a large electric machines room not all rotating room !
8 years ago on Introduction
I finally found my dream home ~Angelica
Be still my heart.
This. Is. A. Dream.
internship please
home
I'll think I'll move to San Francisco Bay, soon... ;)
Awesome resources. I'll pass along to a couple of talented creators I know.
Looks like you have a really nice set up going on and a great place to be creative. Would love to be able to play around, explore and create in such an environment. Particularly like the kitchen as I am a trained chef by trade originally and could have a blast in a good kitchen. Well thanks for sharing and hope you all have a good time in a great work environment and yes i am jealous.
