Introduction: Pig Rabbit Crochet Pattern
STITCHES
Single crochet (sc), slip stitch (sl st), magic circle, increase (inc), decrease (dec), half double crochet (hdc).
All stitches are in US terminology.
MATERIALS
Yarn
White yarn (approx. 1 skein)
Brown yarn (not much, just for the bowtie)
Pink yarn (again, not much, we use this for the inside of the ears)
Black yarn (for the eyes)
3.5mm crochet hook (or crochet hook size E-4) Misc.
Tapestry Needle
Stitch Markers
Stuffing
Step 1: Head
1) 6sc into magic circle
2) [inc] around
3) [sc, inc] around
4) [2sc, inc] around
5) [3sc, inc] around
6) [4sc, inc] around
7-15) [sc] around
16) [4sc, dec] around
17-19) sc around
20) [3sc, dec] around
21-23) sc around
24) [2sc, dec] around. Stuff the head until it looks how you want it.
25) [sc, dec] around
26) [dec] around
Fasten off with a sl st and close up the hole. Weave in ends and set aside, cutting the tail so that none shows.
Step 2: Nose
With pink yarn
2) [inc] around
3) [sc, inc] around
4-5) sc around
Fasten off with a sl st, leaving a long tail. Set aside.
Step 3: Body
With white yarn
2) [inc] around
3) [sc, inc] around
7) [5sc, inc] around
8 – 16) [sc] around
17) [dec, 5sc] around
18) [dec, 4sc] around
19-21) [sc] around
22) [dec, 3sc] around
24) [sc] around. Stuff the body until it looks how you want.
25) [dec, 2sc] around
26) [dec, sc] around
Step 4: Arms (make 2)
With white yarn
2) [inc] around
3) [sc, inc] around
4-8) [sc] around
9) [sc, dec] around. Stuff the arm until it looks how you want.
10-12) [sc] around
13) [dec] around
14) [sc] around
Fasten off, leaving a long tail.
Step 5: Legs (make 2)
2) [inc] around
3) [sc, inc] around
5-6) [sc] around
7) [dec, sc] four times, sc 12
8) [dec, sc] three times, sc 11
9-12) [sc] around
13) [sc, inc] around
14) sc around. Stuff the leg until it looks how you want.
Step 6: Tail
2) [inc] around
3) [sc, inc] around
4-6) sc around.
7) [sc, dec] around. Stuff the tail until mostly full.
8) [dec] around
Step 7: Ears
Outer ears (make two):
2) [inc, 2sc] around
3) [inc, 3sc] around
4) [inc, 4sc] around
5) [inc, 5sc] around
6-10) [sc] around
11) [dec, 5sc] around
12-13) [sc] around
14) [dec, 4sc] around
15) sc around
16) [dec, 3sc] around
Fasten off with a sl st, leaving a long tail. Flatten along the increases.
Inner ears (make two):
With pink yarn
1) ch 4
2) inc into second chain from hook, sc, inc. ch 1 and turn
3) sc across. Ch1 and turn
4) inc, 2sc, inc. ch1 and turn
5-9) sc across, ch1 and turn
10) dec, 2sc, dec. Ch 1 and turn
11) dec, sc, dec
12) sc around the entire inner ear, leaving a round of sc along the edge.
Step 8: Eyes (make 2)
With black yarn.
1) 8 hdc into magic circle
Step 9: Bowtie
Row 1: Start with an 8 inch tail. Ch 4. Turn.
Row 2: Starting with the 2nd ch from hook, work 3 sc across. Turn. (3)
Row 3: Ch 1. Work 3 sc across. Turn. (3)
Row 4: Ch 1. Inc, 1sc, inc. Turn. (5)
Row 5: Ch 1. Work 5 sc across. Turn. (5)
Row 6: Ch 1. Inc, 3 sc, inc. Turn. (7)
Row 7-9: Ch 1. Work 7 sc across. Turn. (7)
Row 10: Ch 1. Dec, 3 sc, dec. Turn. (5)
Row 11: Ch 1. Work 5 sc across. Turn. (5)
Row 12: Ch 1. Dec, 1 sc, dec. Turn. (3)
Row 13-15: Ch 1. Work 3 sc across. Turn. (3)
Rows 16-25: Repeat Rows 4-13.
Cut yarn, leaving a tail at least 12 inches long.
Use end tail to mattress stitch across 3 sts to join the ends of the bowtie, then use tail to wrap around middle of bowtie several times. Use beginning tail to also wrap around the middle of the bowtie a few times as length allows. Thread a tail onto a tapestry needle and run the needle under the wraps to secure the tail. Repeat with the other tail, running the needle under the wraps in the other direction.
Step 10: Assembly (using Tapestry Needle)
Attach the inner ear onto the outer ear. Attach the inner ear to the top layer of the outer ear only, so that the pink doesn’t show. Secure the yarn, cut it, and hide the tail.
Attach the outer ear to the top of the head, making sure to sew through both the top layer and the bottom layer of the ear. Secure the yarn, cut it, and hide the tail.
Using some black yarn, add nostrils onto the nose as shown in the picture. Secure the yarn, cut it, and hide the tail.
Attach the nose to the face. If desired, you can add a little stuffing in the nose to add a little more dimension. Secure the yarn, cut it, and hide the tail.
Attach the eyes to the face. Secure the yarn, cut it, and hide the tail.
Attach the legs to the body. Secure the yarn, cut it, and hide the tail.
Attach the arms to the body. Secure the yarn, cut it, and hide the tail.
Use the two ends of the bowtie to secure it onto the pig rabbit as desired.
