Introduction: Pihole and Samba Display
In this tutorial, I will show you how to make a display that shows your PiHole stats and Samba stats.
- 1x Raspberry Pi
- 1x Raspberry Pi display
Step 1: Setup Pihole
To install Pihole just open a terminal and enter the code below. Follow through the install and set it up how you wish. Just don't forget to note down the password!
curl -sSL https://install.pi-hole.net https://install.pi-hole.net | bash
Step 2: Setup Samba
To install and setup samba, open a terminal and enter the code below.
sudo apt-get install samba samba-common-bin
sudo mkdir -m 1777 /share
sudo leafpad /etc/samba/smb.conf
Then enter this code into the editor:
[pishare] path=/share writeable=Yes create mask=0777 directory mask=0777 public=no
Then run this command to create a user, and then enter a password for the user:
sudo smbpasswd -a pi
Finally, run:
sudo systemctl restart smbd
Step 3: Setup the Code!
To set up the code, run:
wget https://raw.githubusercontent.com/barleybobs/piStats/master/setup.sh 2 Kudos Rep
Then run:
chmod +x setup.sh
Afterwards, open File Manager and go to /home/pi and click the setup.sh file and select Run In Terminal. This will install the code and download the dependencies.
Step 4: Setup Auto Start
Now we will set up the pi so that on startup it opens the display in fullscreen mode. To do this run:
mkdir /home/pi/.config/autostart
nano /home/pi/.config/autostart/pistats.desktop
Then enter:
[Desktop Entry] Type=Application Name=PiStats Exec=bash -c 'sleep 1 && xterm -hold -fullscreen -hold -e "sudo python3 /home/pi/piStats/main.py" && uncluttered -idle 0.01 -root'
Step 5: Connect to Your Samba File Server
To connect to your file server, open File Explorer and select This PC then select map network drive then in the folder put:
\\raspberrypi\pishare
Step 6: Conect to Pihole
To connect to Pihole I suggest you use this helpful website for how to change your DNS:
https://support.opendns.com/hc/en-us/articles/228007207-Windows-10-Configuration
