Introduction: Pikachu
Size introduction:
Body: length: 100mm Width: 30mm Wheel: diameter: 25mm
Specific introduction:
The skateboard adopts metal collocation, which can give people a strong visual conflict. Picachu pattern is placed on the surface to make the skateboard more vivid. Spline curve is used to fit the side to make the skateboard lighter and thinner, with more smooth lines. Protective strips are arranged on the side to facilitate fancy movements. In the middle of the wheel, it is cut to make it petal like, eliminating the clumsiness of the wheel itself and making it more dazzling. The wheel is an enlarged wheel, in order to increase the safety of the skateboard, and also to adapt the skateboard to a variety of terrain. Spring is added to the wheel and axle to make the skateboard more flexible, adapt to the more complex terrain and enhance the user experience.
尺寸介绍:
车身:长:100mm 宽:30mm 轮子:直径:25mm
具体介绍:
该滑板采用金属搭配,能给人以强烈的视觉冲突。表面放置皮卡丘的图案,使滑板更为生动,侧面采用样条曲线进行拟合,使滑板更为轻薄,线条更加流畅,侧方配置保护条,更方便进行花式动作。轮子的中间对其进行剪切,使其呈花瓣状,消除了轮子自身的笨重,使其更加炫动。轮子为加大的轮子,为了增加滑板的安全性,也为了滑板适应多种地形。在轮子与轮轴等部位加上弹簧,使得滑板更为灵活,能够适应较为复杂的地形,增强了用户的体验感。
Step 1: Making Motherboard
Create a sketch and modify the sketch.Then extrude the sketch.
先创建草图,对草图进行修改。然后将草图进行拉伸。
Step 2: Modify Motherboard
Adjust the motherboard to make the appearance of the motherboard more beautiful.
Add protective measures on both sides of the motherboard.
对主板进行调整,使主板的外观较为美观。
在主板的两侧添加保护措施。
Step 3: Make a Connecting Bridge
The connecting bridge is composed of a spring and a wheel shaft fixing block.
The spring is to make the skateboard more flexible, can adapt to the more complex terrain, and enhance the user's sense of experience.
连接桥由弹簧和轮轴固定块组成。
弹簧是为了使得滑板更为灵活,能够适应较为复杂的地形,增强了用户的体验感。
Step 4: Manufacture of Wheels and Axles
Combine the wheel with the spring retaining block.
The wheel is formed by intersecting and tangent to a group of circles, the outer outline of the wheel is an enlarged outline, in order to increase the safety of the skateboard, but also to adapt to a variety of terrain; The pattern in the wheel is to increase the beauty of the petals, but also to reduce the weight of the skateboard.
将轮子和弹簧固定块组合在一起。
轮子是通过对一组圆进行相交和相切组合形成的;轮子外轮廓为加大的轮廓,为了增加滑板的安全性,也为了滑板适应多种地形;轮子中的花纹是为了增加花瓣的美观性,也为了减轻滑板的重量。
Step 5: Combination of Connecting Bridge and Axle
Combine the connecting bridge with the axle.
将连接桥和轮轴组合在一起。
Step 6: Create an Overall Motion Link
Fix the wheel and axle.
Connect the axle with the connecting bridge so that the axle drives the wheel to rotate.
对轮子和轮轴进行固定。
将轮轴和连接桥进行连接,使轮轴带动轮子转动。
