Pillowcase Pencil Skirt Tutorial
42,439
164
12
Introduction: Pillowcase Pencil Skirt Tutorial
About: Brooklyn-based DIY from a gal in granny glasses. Likes: Sewing, crafting, DIY, crochet, embroidery, vegan goodness, beer. I blog at http://www.thezenofmaking.com
Check it out, ladies: a pillowcase that you can totally wear to the office!
Supplies:
* 1 pillowcase
* 1 zipper (7" or 9")
Tools:
* Sewing machine (You can also sew by hand.)
* Seam ripper
* Straight pins
* Fabric scissors or rotary cutter
* Fabric pencil/tailor chalk
* Measuring tape/ruler
* Iron
Step 1: Prepare Pillowcase
Iron your pillowcase flat. Cut off the finished (open) end just below the seam. You will use this piece to create the waistband later.
Step 2: Zipper Opening
Center the seam at the back, and press the pillowcase. Open the back seam from the top, creating a space long enough to fit your zipper.
At this point, to avoid unraveling the rest of the back seam, you should stitch a few times back and forth over the bottom of the opening you just made to secure any loose threads. (You can see my stitches in the photo below.)
Note: If your pillowcase has two side seams, you can insert the zipper in either of the sides instead of the back.
Step 3: Press Zipper Opening
Before laying the zipper in place, turn skirt inside out and fold back the unfinished edges of the opening about ¼" and press.
Step 4: Place Zipper
Lay the zipper in place, taking care to center it in the opening. (Please excuse the magical color-changing zipper. I was working on 2 skirts at the same time.)
Step 5: Pin Zipper
Pin the zipper into place.
Step 6: Sew Zipper
Stitch around the edge of the zipper, securing it in place.
Step 7: Press Skirt
Turn skirt right side out, centering the zipper in the back, and press.
Step 8: Mark Center
Find the center of the top of the skirt and mark it.
Step 9: Pin Darts
Either using a dress form or yourself (with a steady-handed friend to help pin), dart the front and the back of the skirt to make the waist the correct size and the skirt the correct shape.
Take care that the darts are evenly spaced from the center, and that they are angled slightly out to follow the natural curve of your body. In the front, place the darts farther from the center, towards your hips. In the back, place them closer to the zipper. For a flattering fit, the dart placement is very important, so start over again if you don't get it right the first time (it took me more than a few tries).
Step 10: Mark Darts
Remove the skirt from the dress form and turn it inside out. Place a vertical pin at the top of each dart, then use a ruler to draw a line about 8" long from the pin to the folded edge of the dart. (Don't let them intimidate you—darts are nothing more than pinched together flaps of material.) Repeat this process for all 4 darts.
Step 11: Pin Dart Lines
Pin along the line for each dart.
Step 12: Sew Darts
Sew each dart in place along the line you drew in step 10.
Step 13: Cut Waistband
With the darts in place, it's time to add the waistband. Cut the finished seam off of the material that you set aside in step 1, creating a long strip of fabric. Cut the bottom off of the strip, leaving ¾" of fabric. (Remember, the strip is folded in half at the center, so you really have a 1½" wide strip of fabric.)
Step 14: Press Waistband
Fold the unfinished edges in ¼" towards the center fold, and press into place.
Step 15: Cut Waistband to Size
Measure around the waist of the skirt. Cut the waistband strip to size, leaving an extra ¼" on each side to finish the ends. Fold each end under ¼", then fold in half and press.
Step 16: Position Waistband
Starting on one side of the zipper, line up the folded end of the waistband with the edge of the zipper opening and pin into place.
Step 17: Pin Waistband
Pin the rest of the waistband into place around the skirt.
Step 18: Sew Waistband
Stitch down the edges and around the waistband to secure it in place.
Step 19: Hem Skirt
Hem the bottom to length, folding the unfinished edges under and pressing into place.
Step 20: Sew Hem
Stitch around the top fold of the hem, finishing the edges.
Step 21: Finished Skirt
You're done!
BurdaStyle Fashion Challenge
Runner Up in the
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • For the Home Contest
    12 Comments
    DianatStevens
    DianatStevens
    8 years ago
    It would be great if I could find a pillow case that was made out of stretchy material, maybe jersey? What do you think?
    kreator
    kreator
    8 years ago
    i think it's cool and clever and ur pretty
    depnomore
    depnomore
    8 years ago on Step 21
    love it!!!!!!!!! Gotta make it!!!!!!!!!!!
    amollenh
    amollenh
    11 years ago on Step 21
    So cute!!! I am sick of making pillow cases for children that are not even mine. Now I can make my own skits and knee length pencil skirts are my fav. :)
    star folder
    star folder
    11 years ago on Introduction
    On one of the PBS sewing shows, there was a guest who makes dresses for little girls in Africa from pillow cases. Soooo cute.
    jallenmorris
    jallenmorris
    Reply 11 years ago on Introduction
    My wife does this through our church in Bethany, OK that takes the dresses to Swaziland. The last group of doctors and nurses went in March and took about 100 dresses she and bunches of other women made. They have about 125 that are half-done and hope to send about 300 in August. A pillow case can easily be made into a little dress and so many in Africa have so little.
    OperationDressUp.com if anyone is interested.
    porcupinemamma
    porcupinemamma
    I really want to invole students and myself, but the website doesn't help. No info about patterns and where to send finished skirts. Can you please give me more info?
    This is genius. I need to find some cool pillowcases now. I was wondering though, how tight is the skirt around the legs when you are walking around? If its a bit tight then I might just make it a little shorter. :)
    thezenofmaking
    thezenofmaking
    My pillowcase didn't have any stretch, so I didn't make it as fitted as a normal pencil skirt. It falls just above my knees, and doesn't restrict normal walking. (Mind you, I wouldn't try to run in it.)
    angelabchua
    angelabchua
    Awesome idea! This is one of those, "why didn't I think of that?!" sort of things.
