Introduction: Pin Book
Pin book uses flexible bound paper to create a tidy space for storing little things.
Step 1: Materials & Tools
Materials:
1 Case bound magazine, not stapled!
1 Rubber band, or 2 if you're feeling adventurous.
Tools:
1 Metal ruler
1 X-acto knife, with a spare blade or two if you have it.
1 Pen/marker
1 Cutting mat (not pictured)
1 Drafting triangle (optional)
Tools:
1 Metal ruler
1 Pen/marker
Step 2: Mark the Bind
Measure and mark a line running parallel to the binding edge. This measurement will determine the height of your book. Next, break up the space you just created along the binding into even sections. This measurement will determine the width. I used a 1" measurement for my height, and a 2" measurement for my width to yield five 1" x 2" sections.
Step 3: Cut the Block...nice and Easy
Use your metal ruler and X-acto knife to cut the long line running parallel to the binding edge. Depending on the thickness of your magazine it will probably take between 10 -15 passes to get all the way through. Just take it nice and easy and you'll be through in no time. Once you've made the long cut you can go ahead and cut the smaller sections out, one at a time, nice and easy.
*The remaining unbound portion of your magazine may now be recycled, used as mailer packaging, or rolled up for use as a toy telescope.
Step 4: Band the Bits
Use a rubber band or two to join the individual sections you just cut out into a flexible block.
Step 5: Book It
Store some little things. Pins, needles, paper clips, push pins, memos, business cards, guitar picks...etc, etc.
