Introduction: Pinball Cardboard Arcade
This cardboard arcade style pinball machine features a complex machine ball dispenser. This complex machine comprised of 4 simple machines is activated by a turn dial, resulting in the ball to begin game play! The game board is completely a completely functional pinball game. Link for video: https://drive.google.com/file/d/1ruLPZ3--PNze-wnmY7JKQYYWTEKmz8Ya/view?usp=drivesdk
- Cardboard
- Hot Glue
- Twine or Cord
- Box Cutter or Scissors
Step 1: Step 1: Design
The first step is the most important, as you will decide what direction you will the project in. I spent roughly 3 days designing and writing what I wanted this machine to look like. Make sure to be descriptive in all drawings and notes, as this will help you create a more accurate model.
Step 2: Step 2: Cut Beginning Pieces
To begin, cut the very beginning pieces which will comprise your basic ones. Use your cardboard and measure out the pieces needed, then cut. Try to keep pieces as precise and accurate as possible to create an aesthetically appealing and well functioning machine.
Step 3: Step 3: Create Basic Pieces
In this step, you must combine you beginning pieces together to create the basic ones using hot glue. An example of this is combining both layers of the gear together to achieve your desired thickness. All basic pieces of the game board and machine itself should be together at this point.
Step 4: Step 4: Create the Game Board
Take your top panel and add all of the game obstacles onto the board with hot glue. Consider where the obstacles are in relation to each other and how they will interact. We want the game to be challenging, but not impossible.
Step 5: Step 5: Install Levers and Side Panels
Create holes in your side panels for the levers to fit. Then, attach the side panels to the top with hot glue. The machine should be able to fully stand on its own at this point. Be sure to line the levers along the game board so the marble cannot slip through the bottom of the lever. Also, be sure to create enough of a lip around the game board, this is to ensure that the ball does not fall off the board.
