Introduction: Pinecil Soldering Iron Case
Features:
- Custom Fit: The case is precisely molded to accommodate the Pinecil soldering iron, providing a snug and secure fit.
- Two dedicated compartments hold the TS-100 tips, preventing them from shifting or coming in contact with your iron.
- Secure Closure: The case has a reliable clip to keep the case closed during transport.
- Easily Printed: The design keeps 3D printing in mind and can me made using any FDM printer with a big enough build volume
Whether you’re heading to a workshop, maker space, or simply need a secure storage solution for your Pinecil soldering iron and tips, the Pinecil Soldering Iron Case ensures everything stays protected and accessible.
You will need
- A 112mm length of wire to create the joint of the case. I used a ⌀2.4mm filler rod, but the case can be modified for different sizes of wire.
- The 3D printed top and bottom sections of the case.
Step 1: Print and Prepare Case
Print "BOTTOM.stl" and "TOP.stl"
I would recommend 1 at a time.
If you need to change the hinge hole diameter in Fusion or Meshmixer.
Print Settings (.4mm Nozzle)
- Layer Height: .2mm
- Infill: 20-60%
- Walls: 2-3
- No Supports
(Use ABS or PETG for increased heat / chemical resistance)
Step 2: Insert Wire for the Joint
Insert the wire that you've found to act as a joint. I used a piece of TIG filler wire.
It should be a tight fit to ensure rod stays in place.
Step 3: Check Fitment
Tips will fit in back first and can be clipped in with relatively light force, If printed with ABS, the tips can be inserted will still hot.
Interfaces at the joint can be sanded to adjust the friction when opening / closing.
