Introduction: Ping-pong Racket
Your gonna make ping-pong racket!
Materials List:
-Square of Wood 30cm x 15cm.
-Saw
-Sandpaper
-Pen/pencil
-Red/black and grey rubber
-glue stick
-Hockey grip
-eraser
-scissor
Step 1:
Step 1. Get the wooden square of 30cm x 15cm.
Get your pencil and eraser. Make a sketch neatly as possible of the form of the ping-pong racket.
(This is very important because this will be your form of the racket!)
Step 2:
Step 2.
Get your saw and sketch. Get your saw and cut neatly the design! (This is very important because, if the basis is not good your whole racket will be bad.)
Step 3:
Step 3.
In this step you must get the sandpaper, black rubber and glue. First, you’re going to get the sandpaper and sanding the racket clean without any splinters.
If you’re done with this, get the glue and stick it to every edge on the racket! Get now the black rubber and let it stick tight as possible like the examples.
Step 4:
Step 4.
In this step you must get the glue, black rubber and hockey grip. First you put glue on the handle and wrap it with the black rubber. (This must be done tight as possible)
If you have done this, put glue on the handle again and get the hockey grip. Start wrapping the hockey grip tight as possible.
Step 5:
Step 5.
You must get the glue, scissor and grey rubber.
First, you’re going to put glue on ONE side. This will be your side where the grey rubber is going to be. Make stripes of the grey rubber and stick it on to it TIGHT. If you have done this there will be projections and you will cut this off neatly.
Step 6:
Step 6.
Get scissors, glue, red rubber, black rubber.
And again, stick the glue on the side where the red rubber will be going to be. Make stripes of the red rubber and stick TIGHT on the glue. You will have again projection and you will cut this off neatly.
After you have done this, you’re going to get the glue and black rubber. Put again on the edges glue and stick the black rubber tight to the edges so that it looks clean. Now you’re going to get again the black rubber and glue. This time you stick glue on the bottom of the handle and stick the black rubber tight on the bottom of the racket. (You do this so that the hand grip will no fall off.)
DO IT LIKE THE EXAMPLE!!!
Step 7:
Step 7.
And voila your ping-pong racket will be look like this!
