Pinned Mortise and Tenon Construction
Intro: Pinned Mortise and Tenon Construction
If you are designing a box to be cut on a laser cutter you are faced with the problem of how to join to perpendicular faces together. You could press fit your parts together. You could use snaps to hold your mortise and tenon's together. You could use a captive nut on the mortise side and thread a screw through the tennon side. ect ect
I hope to show you how to make a brand new joint which is simple and strong.
The mortise and tenon joint is at least as old as the pyramids we think this because we found a ship that uses them in one of the pyramids. http://en.wikipedia.org/wiki/Mortise_and_tenon
In this variation of the mortise and tenon joint, we add an extra feature which allows us to thread in a screw fastener which works to synch it all together. It is a simple modification which makes for speedy construction.
This joint works great for cnc fabrication such as laser cutting, cnc routing, water jet cutting.
STEP 1: Design and Cut Your Parts
Designing a mortis and tenon is straight forward. Measure you material. Make the mortis and long as the material is thick and make the width of your tenon the same as the material thickness. Then at the end of the mortise slot add a circular hole. The hole should be the size of tap drill for a common screw. I recommend using the screw which is as close to the material thickness as possible. Place the whole so that it only overlaps with the space for the mortise by .5mm.
STEP 2: Assembly of the Pinned Mortise and Tenon
Now that you have your parts designed and made you can assemble them.
Place the mortise in the tenon.
Place your screw over the hole. apply pressure and twist while holding the mortise and tenon together.
STEP 3: Finish the Rest of Your Model
Boom a beautiful part which is looking great. You have made something new and unique and used a fantastic new joinery method to do it. Congratulations.
gabrieldunne 9 years ago
Very nice! Do you know if this design scales up, say to 3/4" ply?
