Introduction: Pipe Lamp
A few weeks ago on Boing Boing, they showed off some pipe lamps being sold on etsy. At 200 bucks each i figured i could make my own for a fraction of the cost and have fun doing so.
These lamps are functional and cheap! it cost 30 bucks to make one lamp.
GENERAL WARNING: Although this project involves very little steps it does involve AC power. Please use caution when doing projects using AC outlet power. If you are not comfortable with simple wire soldering and heat shrinking, please use caution with this project.
Step 1: Supplies
For this instructable you will need the following, note that the pipe choices can vary depending on what kind of lamp you want.
Various sizes of galvanized pipe to build your lamp base. (i used 1/2")
1 candelabra style bulb fixture (i chose this one for it's small size)
1 candelabra bulb
AC plug with in-line roll switch
Heat shrink
tools needed:
Soldering iron
Step 2: Bulid the Lamp Base
first you want to build the lamp base and see what the final product will look like. Once you have something you like you can tighten the pipes together.
Step 3: Wire the Socket
Next fit the bulb socket into the end where you want the light to shine from. Next solder the ac plug to the socket wiring.
Heat shrink your wires afterwards for safety.
Step 4: Put the Bulb In
Lastly install the bulb and turn it on! The first time i turned it on i was sure to have a circuit breaker attached so i could avoid any problems if i did something wrong, but i didn't need it.
If you have ideas for cool and interesting lamps post them in the comments below.
62 Comments
Question 4 years ago on Step 4
How do you tighten fitting in the position they need to be in?
7 years ago
Is it necessary to solder the socket?
Reply 5 years ago
This is an example of how it is never done. Never solder wires or make splices inside a pipe. Never. This is asking for a fire and uklimately burning down a house.
Question 5 years ago on Step 3
Is the bulb socket threaded if not how did you install it in the coupling
6 years ago
Hi Big Jack, Thanks so much for the info on the pipe lamp, you did a great job and I will make some myself. Shirley Worden
12 years ago on Introduction
Here is my Version. I used a 12v AC Adapter and a Halogen Bulb.
Its very funny, i make a very similar design (Parallel universe) . Me
too used a socket for led, but a have a problem because my lamp
overheats. I will try with a Halogen Bulb.
Johnny Number 5 !
Reply 11 years ago on Introduction
Nice!!!
9 years ago on Introduction
What are those round pipe holder bracket things called? I tried looking up pipe bracket, pipe mount, and pipe holder and couldn't find them.
Pipe "Flanges" is what I think you mean.
10 years ago on Step 4
How did you mount the light socket in the pipe?
BTW, great job! It looks really nice.
There's no need to stuff a plastic socket into a pipe fitting. Standard lamp pipe is 1/8" and 1/4" npt. It mates perfectly well with pipe fittings of the same size. I just use a reducer and connect a proper lamp socket.
For those who haven't discovered it yet, GrandBrass.com has the best selection of lamp parts in the universe and great pricing as well. It also has groundable sockets.
I also agree that this thing really needs at least a grommet or preferably a strain relief at the bottom. Unless it NEVER moves, this has probably cut through the insulation by now.
Thanks for the tip on that website- It's awesome!
it is pretty cool....i think it would look equally as good with painted pvc
This is cool as heck!
I love this idea!!!
to personalize it for myself. I would have a flexible shaft on it....but I love the idea!!
TY for sharing. 8)
11 years ago on Step 4
How did you secure the light socket inside the pipe? I've been trying to figure out how the maker of Kozo Lamps did it, and I can't figure it out! Any ideas?
Q for whoever wishes to answer.
is it NOT a good idea to use schedule 40 pipe for a lamp?
Schedule 40 pipe is that white thick walled plumbing pipe used for water
lines usually.
I'm just wondering if the lamp would get too hot for that,..
Or if it would not be stable enough(IE: be susceptible to tipping over too easily & causing problems that way)?
13 years ago on Introduction
it looks nice, but wouldn't it be dangerous to use non-coated metal directly on electrical stuff?
