Introduction: Pirate Ship
Pirate ship made from brick mix and a couple of additional materials. The ship consists of 3 parts: body, deck and upper deck. All spaces are accessibe and fitted to the Lefo folk.
Step 1: Ship Base 1
The base is done of 2 6x12 plates. On top of it 6 expending layers of 2x4 bricks construct the walls. Small side and rear windows can be inserted into the walls.
Step 2: Ship Base 2
The walls are reinforced by flat plates. There are limiters for the deck in the corners.
Step 3: Deck
The deck is constructed and reinforced by different plates. The fence is built on the edges of the deck. The captan's cabin is built from thin bricks on the rear part. The cabin has a door and windows. There are a table, a chair and a bed inside the cabit. The cabin's walls are reinforced by thin plates with limiters in the corners for the upper deck.
Step 4: Upper Deck
The upper deck is based on flat plates. The fence and the steering wheel are built on it. A ledder to the deck can be added.
Step 5: Mast and Sail
A single mast is made of 3 connected bars and attached to the deck in a slot. 3 cords attached to the fence stabilize the mast. 2 booms made of 2 connected hole bars are attached to the mast by rings around the mast.
The sail is made of hard plastic sheet. The cords are inserted through holes. The sail can be folded and winded on the lower boom.
Step 6: No Limits for Improvements
