Introduction: Pirate-Themed Stair Gate and Window Covers
Our home has windows that open at floor level, and accesible stairs. Adding a gate at the top of the stairs and covering the windows makes it kid-safe; designing it with Because We Can makes it cool.
Step 1: Before Pictures
Here are some before pictures. Not only are these before installing the covers and gate, they are before we ripped out the nasty carpet and cigarette-smoke-filled drapes.
Note how the windows open at floor level over a two-story drop -- perfect for crawling right out! Similarly, the spacing of the railing over the stairs is approximately 10% larger than a baby head.
Step 2: Gate Design
Functional design: Prevent a toddler from going down the stairs; make it easy for an adult to open and close.
Aesthetic design: We call our home the Isle of Tortuga, so wanted a nautical theme with pirate ships, wind, waves, sea life, and buried treasure.
The gate will be painted to match our walls (Benjamin Moore, Midnight Navy; the walls in that area are all flat, with about 3 thick coats for extra-dark, light-sucking fun; the upper walls are Lighthouse; trim is Milky Way), and the designs cut through the painted surface exposing the blonde wood underneath.
Some of the pirate ship images came from a scan of an old wood-cut project book.
Step 3: Window Cover Design
Functional design: Allow airflow from open windows. Survive a crash from a full-speed toddler. Discourage climbing.
After agreeing on the theme, we made the design "denser" to ensure toddler-impact resistance. Jeffery even made a model of a baby head, and placed it throughout the design to ensure no baby heads could get stuck anywhere!
The attached PDF is clean version of the design, should you want to use any of the imagery yourself.
Step 4: Making the Panels
The panels are europly from Columbia Forest Products. First they were painted, and then they were cut by a ShotBot.
The images show the ShopBot in action at Because We Can cutting some other panels.
Step 5: Finished Gate
Here's the finished gate, and Corvidae exploring the pirate ship. It is installed with bolts through the metal railing and screws to the post.
Note the octopus cruising around the corner.
Step 6: Finished Window Covers
Here are the finished window covers. They are installed with screws into the studs between the windows, which forms a gap between the covers and the windows. The shades can still be drawn all the way down between the windows and the covers.
