Introduction: Piston & Egg
This is a statue of a dragon egg on a piston. The piston acts as the pedestal of the statue, and the dragon egg is obtained once you beat the game, so it symbolizes a Minecraft world that has defeated its dragon, or final boss. so it's like a trophy. The cool part about this project is that with the Light(Operator Utilities) item, surrounding the statue with it creates an light source so that it's easy to see even at night.
Piston: (bottom) Mossy Cobblestone, Stone Bricks, Black Wool, Black Concrete Powder, Gray Concrete, Gray Concrete Powder, Light Gray Concrete, Light Gray Concrete Powder, Cobblestone, White Concrete Powder, (middle) Yellow Shulker Box, Yellow Concrete Powder, Yellow Terracotta, Candle, White Candle, Water Bucket, Barrier (Operator Utilities), (top) Stripped Oak Log, Striped Spruce Log, Spruce Planks, Light Gray Wool
Lighting: Light (Operator Utilities)
Dragon egg: Block of Coal, Black Wool, Purple Concrete
Shaders: BSL and Complementary Unbound
Step 1: Build the Piston
Match the block's color to the pixels' colors on the piston, then build it with a pixel to block scale.
Step 2: Add Decoration
Use barriers, invisible blocks, to build a chute for the water to be placed in. Place candles of different colors on a block, then break the block, to create the effect of having floating candles. Repeat around the piston.
Step 3: Build the Dragon Egg
Put a dragon egg next to another block as comparison, and build using the pixel to block scale. Add purple and gray patches after building the egg's shape.
Step 4: Add Lighting
Cover the entire build with Light (Invisible light sources) so that the build can be seen at night, or in darkness.
