Pixel Art Coasters
9,971
191
13
Introduction: Pixel Art Coasters
About: Maker with an obsession for the 8-bit!
Coasters made using little squares of various hardwoods as the palette for pixel art.
This instructable does two of my favourite things....pixel art, and using up bits of wood that are too small for anything else. It's also worth noting that this is a guide to making quite a lot of coasters, so with Christmas on the horizon this could get a few people off the pressie list.
Please leave a comment if you've got any advice on how this could be done better/easier, and be sure to check out my other projects!
Step 1: Make a Lot of Sticks
The first step was to gather up off cuts of woods of various colours. I was just using up bits that were too small for anything else and had some beech, oak, iroko, sycamore, mahogany, and walnut.
I aimed to make them around 6mm square as this is as small as my thicknesser can handle. After making them all equal thickness I cut them to width with a little breathing room on my table saw, then a few more passes on the thickenesser to make the sides uniform.
I cut the sticks into bits about 10cm long with a mitre saw.
Step 2: Plan Design and Prep for Gluing
I needed to make the design/designs as small as possible so I wouldn't end up with oversized coasters. I started a new project in Photoshop with the canvas at a size of 14px x 14ps and set about clicking pixels to shoehorn in some classic Mario sprites. Be sure to be aware of the limitations of your palette, and how much of each colour you've got to work with.
I also made a gluing jig out of some softwood and lined it with plastic. This needed to be a nice snug fit for the sticks with one edge loose so pressure could be clamped in to squeeze out excess glue.
Step 3: Glue
Using Gorilla wood glue on each individual stick I carefully glued up the designs. It's a bit of a race against setting glue here, but don't rush and get pixels in the wrong place!
Once all the pieces were in place I clamped the floating edge of the jig to help squeeze out some of the excess glue. After an hour or so the glue was dry and the solid block could be released from the jig. I had to remove a side from the jig to get the leverage but a bit of mould release spray or something could make this easier.
Step 4: Slice, Mount, and Frame
Now that I had these blocks I had to slice them up. Although it would have been a lot quicker to use the mitre saw I thought that the blade was a bit greedy and I didn't want to lose too much to sawdust, so instead I went with my thinnest bladed saw. I managed to get 7 or 8 coasters out of each block.
They were getting a little delicate at this point so I mounted them on some 3.5mm plywood. Once they were squared up on a mitre trimmer I glued a thin wood edge around each one to frame and protect the coaster.
Step 5: Sand Flush, Varnish, and Felt the Bottom.
I made a jig to hold the coasters and set about sanding the face flush with the edging with a belt sander. After doing a few times I found things moved much faster with a bench sander (so no pic).
I did the finishing sand with a random orbit sander loaded with 120g paper.
To finish them off I gave them a few coats of polyurethane varnish and glued some felt onto the bottom. I later peeled this off and went with cork instead which looked way better (sorry no pic again)
I was really pleased with how these came out, and they make great little gift for any gamer friends!
Comment with any tips & tricks on how you would do this, and please be sure to check out my other 'ibles!
Be the First to Share
    • Game Design: Student Design Challenge
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    13 Comments
    dudus
    dudus
    4 years ago
    Great idea to make a block like a stick of rock, make a slice, they all look real nice!
    Good job!
    KyleD14
    KyleD14
    4 years ago
    Hadn’t been on Instructibles for months, so I was pleasantly surprised to find this project today. Coincidentally, I’m in the middle of a similar project, using ~12mm blocks glued up into a cutting board (about 980 pieces). Great ideas in this ‘ible, wish I’d seen it earlier. Viva la Nintendo!
    Dutchboy1
    Dutchboy1
    4 years ago
    Great job and inventive! I was thinking bandsaw while reading this when trying to figure out how all it was done. Glad to see you didn't cut tiny tiles up then glue them together. Also thickness sander once glued up l know sounds expensive but all kinds of tools worth adding to your shop! Keep it up.
    lolamatic
    lolamatic
    Question 4 years ago on Step 1
    Any ideas/tips on how to try this without a planer or table saw? I can get access to a table saw for a few hours as needed but not a planer :(
    1up Living
    1up Living
    Answer 4 years ago
    I'd hunt around and see if you can find somewhere that sells wood in tiny stock sizes and skip the machining step completely. You also may be able to get away with skipping the planer...it really helps to get the rods uniform and fit together nice n' tight, but some careful machining on table saw will get you pretty darn close.
    mtairymd
    mtairymd
    4 years ago
    Those look pretty cool. Nice job!
    ttemple2
    ttemple2
    4 years ago
    Great work! For glue-ups, get some repositional craft glue, spray a flat surface with glue, lay out your row of "pixels", brush entire area with wood glue and then stack them in your jig. Can do entire row vs one stick at a time. You should around 5-7 min working time with the glue.
    1up Living
    1up Living
    Reply 4 years ago
    Now that's a much more efficent way of doing things! Great tip.
    attosa
    attosa
    4 years ago
    Very well done. They look awesome :)
    handmadewithashley
    handmadewithashley
    4 years ago on Step 5
    These look awesome! Great work! :) I’ve been wanting to make something like this. I like the jig you made for the glue up phase.
