Introduction: Pizza Charm
I made a pizza charm because it was requested by rainbow owl and I put perroni on it because that is one of my favorite types of pizza.
So if you want to make a awsome pizza charm read on!
Step 1: Step 1: You Will Need
you will need:
Some black or brown bands for the crust
A bunch of yellow bands for the cheese
Three red bands
A loom
And a hook
Step 2: Step 2: Starting the Pizza
first set your loom like the second picture, next take two bands and go up one on the loom then go diagonal should also look like the second picture
Step 3: Step 3: Making the Pepperoni
now we are making the pepperoni, take one red band and twist it around your hook four times. Next take one yellow band and then pull the red rubber band onto the yellow band. Now make three of them.
Step 4: Step 4: Putting the Pepperoni in Place and Finishing With the Cheese
now using one band go to the right diagonal the take one pepperoni piece and put that on top of the one band,next from the middle go up two and on the second to the third pin put another pepperoni piece like we did before then go two more up with the yellow.now on the left go up two and on the second to third pin put your last pepperoni piece on the loom like it shows in the picture.
Now make sure your pizza looks like the last picture so far.
Step 5: Step 5: Starting the Crust
first I forgot is to take one yellow band and twist it once and place it at the bottom where all three pegs meet up.Put the next twisted yellow band up one and then do NOT twist the third yellow rubber band.it should look a bit like the last picture without the crust.for the crust take two rubber bands from the last left peg go up one do that with the other two pegs then on all the last three pegs put a cap band and twist it round the peg three times it should now look like the third picture.
Step 6: Step 6: Still the Crust
first for the crust take two rubber bands and place them next to each other but not so they touch each other. Next put one of the cap bands on the left and one on the right and rap it around three times like it shows in the picture.Now hook both the small crust like the second picture.like the sixth picture take two rubber bands and put it right in the middle of the crusts so the crusts join up to make one large crust.then take the outside loop on each side over and onto the middle crust.now very carefully bring it and put it where the cheese changes into the crust, you have now finished your crust!
Step 7: Step 7:
now starting from the top of the crust hook all the way down until you get to the slip knot stage.
Step 8: Step 8:
Now once you have hooked the last one put your hook thew the middle loop of the last peg and then put a rubber band on your hook and hold it and then bring your hook back up thew the middle loop of the last peg and then do the simple slip knot by putting one side of the band inside of the other then pull to make a slip knot.
Step 9: Step 9:
now peel your pizza charm off the loom starting from the crust so the pizza does not brake now your pizza charm should sort of look like this!
Hope you liked making this pizza charm I am going to be making loads more charms, because I am doing a series about how to make food charms you can message me on what food you would like me to make next and also message me to show me how you did!
Looking forward to hearing from you!
See you soon!
