Introduction: Plane
You need 1 white cylinder shape ( measurement : 131.95 mm for length and 19.30 mm for diameter)
Step 1: Step 2
you need two white paraboloid shapes one for front and one for back
( measurement : 20.40 mm for length and 22 mm for diameter ) for front
( measurement : 40 mm for length and 17 mm for diameter ) for back
Step 2: Step 3
attach the short paraboloid to the front and long paraboloid to the back
Step 3: Step 4
you need white 3 box shape as for the fins
( measurement : 30 mm for length, 10 mm for width and 2 mm for height )
Step 4: Step 5
rotate the 2 box shape 90 degrees clockwise or anticlockwise horizontally. rotate the other box shape 90 degrees clockwise or anticlockwise vertically and attach it all together at the long paraboloid.
Step 5: Step 6
you need white 2 box shape plane wings , 2 white box shape for tail of the plane wings , 2 white roof
( measurement : 73.70 mm for length, 21.30 mm for width and for 1 mm for height ) for plane wings
( measurement : 19.80 mm for length, 1.55 mm for width and 3 mm for height ) for tail of the plane wings
( measurement : 19.89 mm for length, 18.96 mm for width and 1.20 mm for height ) for attachment for plane
Step 6: Step 7
Rotate the 2 plane wings 45 degrees and other 135 degrees and do, same for other shape and to attach all together for wings and group the two plane wing together.
Step 7: Step 8
attach the one plane wings to one side each and group it all together
Step 8: Step 9
you need 32 light blue box shape for window , 4 dark grey box shape for the door
( measurement : 3 mm for length, width and height ) for window
( measurement : 12 mm for length, 6 mm for width and 2 mm for height ) for door
Step 9: Step 10
rotate the 4 dark grey shape 90 degrees vertically
Put 14 windows on each side, 2 door at the end each on cylinder
Step 10: Step 11
Put 2 cubes in front and 1 cubes each side of the short paraboloid
Step 11: Step 12
You need 3 white cylinders and 3 black tubes as wheel of the plane
( measurement : 5 mm length, 4 mm width and 20 mm height ) for cylinders
( measurement : 5 mm width, 6 mm length and 6 mm height ) for tubes
Step 12: Step 13
Attach tube and cylinder together, rotate it 90 degrees clockwise or anticlockwise vertically
Step 13: Step 14
Put one wheel in front and other two wheels on the back
Step 14: Step 15
You need two white cylinders, two white paraboloids and eight black box shapes for to combine as jet
( measurement : 20 mm length, width and height is 21 mm ) for cylinder
( measurement : 20 mm length , width and 20 mm in height ) for paraboloid
( measurement : 18.50 mm length, 2 mm width and height ) for box shape
Step 15: Step 16
Rotate one box shape normal, one 45 degrees, one negative 45 degrees, another 90 degrees, rotate cylinder 90 degree, paraboloid and combine all together.
Step 16: Step 17
Put one jet on one wing each and you are finish.
