Introduction: Plant Sunlight Alerting Armour
About: Just a person trying to win a competition.
In a yard every one has a favorite plant. Yes and sometimes you wonder is my plant buddy save. Well I alone also thought about the same problem. So with my circuit skills I made an Armour for plants that alerts you when it is not getting sunlight and most importantly with only 2 cells. Well this can be applied at any plant and sometimes it can even alert when someone tries to hit it.
As you know an Armour need to be strong so I have tried my best to install good sensors and a great distracting alarm system. The point is that the sound will stop when there is less light. The list.
  • Speaker or light ( or both)
  • 2 1.5 cells
  • a battery bank
  • A slide switch
  • Main music file ( if you use the speaker and The U1 in the picture is the music file)
  • Sensor (that stops when not exposed to light)
  • Jump wires
  • 6 2 snap wires
  • 1 7 snap wire
  • 1 6 snap wire
  • 2 5 snap wires
  • 1 3 snap wire
  • Your plant
Step 1: Battery Source and Switch Connections
Put the cells in the battery bank and connect it with a slide switch
Step 2: Alerting System Roots
Now connect a 5 snap wire connect with the other end of the switch. Now connect a 3 snap wire at the second last place of the 5 snap wire. Now take a U1 or a music file and connect it with a 3 snap wire. Use a 2 snap wire to connect it at the bottom left corner of the U1 or battery file. Connect a 5 snap wire with the 2 snap wire and the battery bank at its both ends.
Step 3: Sensor
Connect a jump wire at the middle of the 5 snap switch located with the slide switch. Then connect another jump wire at the upper right of the U1 or battery file. Now connect a sensor (that stops when not exposed to light) with the end of the 2 jump wires.
Step 4: Alerting System
Connect 2 snap wire at the bottom right of U1 or music file. Connect another one at the 2nd button at the 5 snap wire located near the slide switch. Now Connect a 7 snap wire at the 2 snap wire at the U1 or main music file that flows and stops to a bulb and connects. Now connect a 6 snap wire at the remaining 2 snap wire that also flows to the bulb but to equalize the length with the 7 snap wire connect another 2 snap wire to the 6 snap wire. Now connect the speaker with the bulb with 2 2 snap wires.
Step 5: Wearing the Armour
Just place the sensor on the plant top.
