Introduction: Planter Made at TechShop Round Rock
I needed a planter for some lucky bamboo and I had an old white lacquered shelf and some old pine in my garage so went to TechShop and made this guy.
Things you will need:
1. Board or boards to use to make planter
2. Water proof glue ( I used tightbound)
3. Tape (to serve as a clamp)
4. Measuring tape
5. Pencil
Tools I used:
1. Table saw
2. Miter Saw
3. Japanese Saw
4. Brad nailer with 2" nails
5. Band Sander
4. Measuring tape
5. Pencil
Tools I used:
1. Table saw
2. Miter Saw
3. Japanese Saw
5. Band Sander
Step 1: Cut Board Down
So I made a basic drawing before I got started thinking that a 6"x6"x7" box would work. I later change those dimensions to 6"x10"x7" to make it more functional. Since my board was already pre-finished and assumably square I took it first to the table saw and set it at 7" cut depth. This cut is basically setting the hight of the planter. After ripping the board on table saw I needed to cut the sides of my planter. I wanted the side joints to be mitered to give a more finished look. So went to miter saw and knowing that I had a finished side and a somewhat unfinished side to my board I made sure to orientate all my cuts so that the finished side would be facing out. I first got started by setting the miter saw at a 45 degree angle then I cut a miter on one side of the board to act as my first corner. Once that was cut I set up a jig that would stop my board at 6' so that all sides would be consistant. I then moved the blade so that it was now at the opposite 45 degree mark and set the mitered edge against my 6" stop. (note you will have to flip flop your miter every cut so that all miters are sloping away from the middle of the board's unfinished side.) I then repeated that process with the next 6" cut. At this time I took both pieces and held them side by side and realized my planter wouldn't be big enough and changed dimensions to 6"x10"x7". So I measured out difference using a tape measure and reset my jig for the last two cuts. Once all side were cut out I did a dry fit then I did a glue up using scotch tape as my clamps.
Step 2: Cutting Bottom for Planter
I already had some pine from home so I flipped my white box over and on the bottom I attached some misc. pine boards, using glue and a brad nailer. Once the pieces were appropriately attached I flipped the box over and used a japanese saw to cut the boards flush to the frame of the planter. You can see in the last pictures all the brad nail marks on the bottum of the frame... ran into a problem with the board I was using being a hollow core... basically had to go a little cray with the brad nailer to make those pine boards stick. Also notice the wet paper towel in the pictures as the surface was pre-finished I could not sand any excess glue so I wiped extra glue off as I went.
Step 3: Sand the Pine Base Flush With Frame
I then took the box over the the band saw and sanded flush the projecting edges of the pine with the planters white sides. While I was doing that I was thinking how I didn't like the shiny white finish so sanded the lacquer a little bit on all four sides... can't say I like the results... I do like the pine bottom detail though...
