Introduction: Plasma Car Wheel Upgrades
Plasma Cars are awesome and strong enough for a (flexible-ish) adult to ride. But it relies on front wheel friction to move and the plastic wheels it ships with just aren't all that great. They slip, making it hard to get started, and all four wheels will leave small gouge marks on hardwood floors.
So upgrade the wheels to 84mm inline skate wheels. Upgrading the fronts is trivial. The rears take more work.
I used 84mm hard indoor inline skate wheels. Indoor wheels will degrade faster if used outdoors, but kids don't weigh as much as adults so I think they'll probably hold up just fine. A pack of 10 wheels was about $25 so you can have plenty of spares on hand if you need them.
And you don't need to buy bearings. The Plasma Car uses standard ABEC-7 inline skate wheel bearings. You just pop those out and of the plastic wheels and into your new inline skate wheels.
Step 1: Replace the Fronts
Just remove the one nut holding each front wheel. Pop out the bearings by placing a screwdriver just barely under the back edge of the top bearing and lever up. Insert the bearings into the inline skate wheel, reattach with the nut, and you're good to go.
This alone will be a huge upgrade and you can stop here if you like. But if you keep the plastic back wheels, you'll want to sand them down to remove the hard center line ridge; this is what will gouge your floors.
You might also want to consider the tennis ball mod seen in the photo. The baby front wheels aren't actually wheels--they don't spin. They're really just there to catch you if you turn too sharply and lean out of balance. But those baby front wheels will also mark and gouge the floor. So I removed them and replaced them with the tennis ball.
If you go ahead with replacing the rear wheels, you'll see how I've repurposed those baby wheels to finish off the rear upgrade.
Step 2: Gather Materials for a Rear Axle
A 5/16" threaded rod fits perfectly inside the Plasma Car's standard ABEC-7 wheel bearings. You'll need about 14" of rod. Expect to have to cut the rod down to size.
You'll need the rod plus nuts, lock washers, and fender washers.
You might need some regular small washers just to finish off the spacing at the very end.
I used a Dremel metal cutting wheel to trim the threaded rod.
Step 3: Preassemble and Mark Rod Length
The rear wheels just pull straight out if you push and pull them a bit from side-to-side.
Inline skate wheels are wider than the Plasma Car's rear wheels. So you won't be able to mount them in the wheel housing using the original brackets. That's where the axle design comes in. It has the added bonus of guaranteeing that your rear wheels are perfectly parallel.
With the rear wheels removed you're left with an open U-shaped channel where the mounting brackets had been. Your new rear axle will sit in this channel, but this isn't ideal since there's nothing keeping the axle in there. However, by using washers and bolts we can dial in enough pressure to do a good enough job of keeping the axle in that groove.
On both sides of each wheel housing add a fender washer, lock washer, and nut.
Leave enough room at the end of the rod to attach the baby front wheels and a nut. I used the baby wheels here to act as furniture and parent ankle protectors! I didn't want kids whizzing by with the metal rod or exposed nuts protruding from the outside of the Plasma Car. The baby front wheels are recessed enough to keep the end nut out of harm's way.
Once everything is spaced out you can mark the threaded rod where it needs to be cut down. The rod I got was 24" and I had to cut about 10" off of it.
Step 4: Cut the Rod and Final Tighten
First time I've ever tried to cut a metal rod. Pretty dang awesome! The cut edge will be a bit raw and sharp so take care.
With the rod cut, assemble everything and dial in the tension on either side of the wheel housing. It'll bow in. Just leave enough room so the wheel isn't squeezed and can still spin freely. Cap off the ends with the baby wheels. You may need a washer to push the nut out so that it fully covers the raw edge of the threaded rod.
And that's it! Go ride!
5 Comments
4 years ago on Step 4
Thanks so much for this info stating the correct size wheel...I'm 61 and ride this downhill to Walmart where I hang it on the shopping cart through the store, then push the cart back home ...while my bluetooth speaker is blaring pop music.
Found 2 in our apartments trash and cleaned up the bearings easy. Now a gang of adult wiggle plasma cart (skate boards with steering wheels) riders terrorize our totally paved, slightly sloped, neighborhood....Hey what do they expect? It holds up to 220 lbs. besides our world has been blacktopped smooth....and its legal to smoke pot ....so what does anyone expect?
Only replaced the back wheels, because according to another youtube vid, it flips too easy if the front flater wheels are upgraded.
Also Added a comment after comment of no need for extra axle work just flex the black plastic and shove the white plastic...its only half centimeter.
6 years ago
Do you realize that you can simply take the back wheels off, pull out
the retaining devices that contain the short axles, slide them through
the roller blade wheels, and snap the assembly right back into place? I
went out, bought all the supplies, cut the rod, and was getting
frustrated with the jimmy-rigged nature of the axle system and the
potential for the axle to simply pop out of the rear wheel brackets. Then I picked up the original retaining devices, slid them through one of the roller blade wheels, popped them together and back into the original housings, and there it was. Super fast, very silent, no more hardwood floor damage, and the way the Plasma Car was designed in the beginning. Now I have a few more nuts, washers, and threaded rods to add to my assorted collection in the garage.
8 years ago on Introduction
nice work! how long did this project take you?
Oh, and I should add that the idea came from someone else who mentioned it in an Amazon review for the Plasma Car. There's also a video on YouTube but they don't offer much info. I had to work out the details but I don't claim the idea as my own!
Picking up supplies at the hardware store and cutting the metal rod is basically the extent of the effort. Ordered the 10-pack of wheels from Amazon. With all materials on hand it's easily done in less than an hour.
