Introduction: Platform IoT Cayenne Mydevices & ESP8266 12E NodeMCU
About: Share - Learn - Makers. Projects, Articles, #automation, #PLC, #Arduino, #IoT and More PDAControl
This time the test is performed on the well-known Cayenne platform.
What is Cayenne? It is a solution for building IoT applications based on platforms known as Arduino, Raspberry pi, ESP8266 and Serial devices,Wi-Fi, Lora devices, also includes a Mqtt API to connect any MQTT client which to use in this case, in This tutorial will explain the following: This tutorial will take a tour of the Cayenne platform.
Official website : cayenne mydevices
This tutorial will show the Connection of an ESP8266 12E NodeMCU and Cayenne.
Tutorial completo: PDAControl Español
Introduccion Plataforma IoT Cayenne mydevices & ESP8266
Full Tutorial: PDAControl English
Introduction Platform IoT Cayenne mydevices & ESP8266
Step 1: Tutorial Platform IoT Cayenne My Devices and ESP8266 Part 1/2
Tutorial Platform IoT Cayenne my devices and ESP8266 Part 1/2
1- Create a Starter account in cayenne
2-Download libraries and examples
3- Modifying Arduino IDE Examples
Step 2: Signal Conditioning & Arduino IDE - Components and Materials Required for Testing
ADC(0) Signal Conditioning
You must be very careful when using ADC (0) pin ESP8266 12E, TOUT, ADC (0) or pin 6 are some names by which this input will be identified, its resolution is 10 bits from 0 to 1.0V maximum, We have created a circuit based on a voltage divider and a diode to limit the input voltage in parallel to our light sensor, photoresist or LDR.
Arduino IDE
During tests it is denoted that cayenne allows to send values and the dashboard allows to preview the value and it facilitates when adding the associated widgets to that value. For the control of the Led in Arduino IDE, the function log of cayenne by default is configured, which technically listens to the parameters of any channel that sends data from Cayenne to the ESP, in this case the widget button. It takes the value of the channel assigned to the button and that value goes from String to int to activate the GPIO 04.
Components and materials required for testing
ESP8266 01
ESP8266 03
ESP8266 12F
Diode led
Resistors
Converter TTL -USB
Protoboard
Wires
Step 3: Tutorial Platform IoT Cayenne My Devices and ESP8266 Part 2/2
Tutorial Read LDR and Turn on a led from Cayenne
In this case you use a module ESP8266 NodeMCU:
1-Download Arduino IDE
2-Configuration and creation of Widgets
-We will control GPIO 04 (Led) in this case should make changes to the default example.
-We will read the ADC0 (LDR).
Step 4: Complete Info
- Dashboards Cayenne
More Info: Conecctions & Donwloads
More info:cayenne.mydevices.com
