Introduction: Play 3D LC - 139€ DIY 3D Printer
Hello. I'm going to show you how to build a 3D printer for less than 139€.
This is the Low Cost version of the popular Lewihe Play 3D printer
The printer mounts 28BYJ48 motors and Ramps 1.4 electronics. All components (including chassis) can be found in the market for less than 139€.
Specs:
Print size: 90 x 90 x 110 mm.
Print speed: 30 mm/s
Resolution: 0.16 mm.
Prints rigid and elastic filament.
More information and updates: https://plus.google.com/u/0/communities/112603252080735086560
Warning: I can not mount the printer for you. Therefore, you are responsible for the good operation and safety of the mounted printer.
Step 1: Bill of Materials
The Bill Of Materials (BOM). In the following list you will find all the necessary components to mount your 3D printer.
* Links can change. The prices are orientative and you can find some component with different price. I'm not responsible for those changes.
- 1x . Arduino Mega 2560 + Ramps 1.4 - link
1x . Kit Play 3D - Maker Edition (chassis, hotend support, print surface and rods) - link
- 1x . Printer parts
4x . Spring Ø4x0.4x10 mm.
1x . Spring Ø4x0.4x7 mm.
4x . Motor 28BYJ-48 12V - link
6x . Bearing LM6LUU - link
- 17x . Screw DIN 7981 3.9x9.5 mm. ref. FP45456 - link
17x . Screw DIN 7981 2.9x9.5 mm. ref. FP45433 - link
10x . Screw DIN 7981 2.9x16 mm. ref. FP45429 - link
- 5x . Hexagonal screw DIN 933 3x25 mm.
1x . Nut M-3
- 1x . Nut M-6
1x . Poliamide nut M-5 - link
- 2x . Fan 40x40 mm. - link
3x . EndStop - magnetic reed Cs1-g - link
- 1x . 12V 4A AC-DC Power Supply Adaptor - link
- 1x . Connector DC Power - link
- 1x . Cable tie set
- 4x . Nivelation nut M-3 - link
- 1x . Hotend - barrel 40 mm. - link
- 1x . Hotend - heater block - link
- 1x . Hotend - nozzle - link
- 1x . Heater 12V 40W - link
- 1x . 100k Thermistor - link
- 1x . Hobbed MK7 - link
- 1x . Bearing 604zz - link
- 2x . Pulley GT2 - link
- 0.8 mts . GT2 Belt - link
- 2x . GT2 Syncro Pulley Bore 3 mm. - link
- 1x . Flexible coupling Ø5x5 mm. - link
- 3x . Neodymium magnet Ø5x2 mm. - link
Step 2: Printed Parts
These are the STL files you need. You can also download the files on thingiverse
1x . Support_X_EndStop.
1x . Support_X.
- 1x . X_Carriage
1x . X_Motor_Support.
- 1x . X_Support Synchro.
- 1x . Y_front support.
- 1x . Y_back support.
1x . Print_surface_support.
1x . Base_Z.
- 1x . Upper_closure.
- 1x . Bottom_closure.
4x . Seat_block.
* Please follow the printing tips on thingiverse for printing the STL files.
Step 3: Modifying the 28BYJ48 12V Stepper Motor
Now, let's change the 28BYJ-48 motor from unipolar to bipolar. See the pictures.
- Remove the blue cap.
- Cut the red wire and remove it.
- Cut the track with a screwdriver or blade.
Then connect the cables in this order: Pink - orange - yellow - blue (you can use a dupont connector)
You already have a bipolar motor, connect these motors directly to Ramps.
Step 4: Support X EndStop - Assembly
Let's start with the assembly!
For this step you need:
- 1x . "Support_X_EndStop" printed part.
- 1x . LM6LUU Bearing.
- 4x . Screw DIN 7981 2.9x9.5 mm.
- 2x . EndStop - magnetic reed Cs1-g.
- 1x . Pulley GT2.
- 1x . Motor 28BYJ-48 12V.
Follow the instructions in the following video.
Make sure the EndStop is mounted just like the video indications (X and Y).
Step 5: Support X - Assembly
- 1x . "Support_X" printed part.
- 1x . Screw DIN 7981 2.9x16 mm.
- 1x . GT2 Syncro Pulley Bore 3 mm.
Step 6: X Carriage - Assembly
Then mount the X Carriage
- 1x . "X_Carriage" printed part.
- 2x . LM6LUU Bearing.
- 2x . Screw DIN 7981 2.9x9.5 mm.
- 1x . Neodymium magnet Ø5x2 mm.
To mount the magnet, use contact adhesive and place it in the indicated housing.
Step 7: Assembly GROUP X
Now, you will mount the GROUP X.
- 2x . Steel rod Ø6 x 165 mm. (Included in the Kit Maker Play 3D)
- 0.4 mts . GT2 Belt.
The steel rods are pressure-mounted. They do not need any type of adhesive.
To mount the belt, first tie a final part with one of the "X Carriage" bolts. Then go to belt by the pulleys. Tie the belt with the other "X Carriage" bolt. The strap has to be tight, but not too tight.
Step 8: Y Motor Support - Assembly
Then mount the Y Motor Support.
- 1x . "X_Motor_Support" printed part.
- 1x . Pulley GT2.
Step 9: Y Support Synchro - Assembly
And mount the Y Support Synchro.
- 1x . "Y Support Synchro" printed part.
- 1x . GT2 Synchro Pulley bore 3 mm.
Step 10: Assembly GROUP XY
Now, you will mount the GROUP XY.
- 1x . "Y_front_support" printed part.
- 1x . "Y_back_support" printed part.
The steel rods are pressure-mounted. They do not need any type of adhesive. To mount the belt, first tie a final part with one of the "Support X" bolts. Then go to belt by the pulleys. Tie the belt with the other "Support X" bolt. The strap has to be tight, but not too tight.
Step 11: Assembly GROUP Z
Let's go with GROUP Z.
- 1x . "Print_surface_support" printed part.
- 1x . "Base_Z" printed part.
- 1x . Print surface (Included in the Kit Maker Play 3D)
- 5x . Hexagonal screw DIN961 3x20 mm.
- 4x . Spring Ø4x0.4x10 mm.
- 4x . Nivelation nut M-3.
- 1x . Nut M-3.
- 1x . Polyamide nut M-5.
To mount the magnet, use contact adhesive. Then adjust the hexagonal screw approximately to the extent indicated in the figure ( 15 mm.)
Step 12: Mounting the Closures
- 1x . "Upper_closure" printed part.
- 1x . "Bottom_closure" printed part.
- 4x . "Seat_block" printed part.
- 1x . Chassis (Included in the Kit Maker Play 3D)
- 2x . Steel rod Ø6 x 190 mm. (Included in the Kit Maker Play 3D)
- 1x . Threaded rod M-5 (Included in the Kit Maker Play 3D)
- 1x . Fan 40x40 mm.
- 1x . EndStop - magnetic reed Cs1-g.
- 8x . Screw DIN 7981 3.9x9.5 mm.
- 2x . Screw DIN 7981 2.9x16 mm.
To mount the "Seat_blocks" use contact adhesive. Optional fan for electronics cooling.
Step 13: Mounting the GROUP XY in the Chassis
You have to enter the assembly by the top. Once installed, tighten the 8 screws.
Step 14: Electronic Board
Now, you will mount the Electronic board
- 1x . "Ramps_support" printed part.
- 1x . Connector DC power.
You can use the enabled holes in the printed parts to engage the wiring. View details in photos.
Step 15: Extruder
Finally, we will mount the extruder.
- 1x . "Extruder" printed part.
- 1x . "Paw_extruder" printed part.
- 1x . "Fan_support" printed part.
- 4x . Screw DIN 7981 2.9x16 mm.
- 3x . Screw DIN 7981 2.9x9.5 mm.
- 1x . Screw DIN 7981 3.9x9.5 mm.
- 1x . Bearing 624zz
- 1x . Hobbed MK7
- 1x .Spring Ø4x0.4x7 mm.
- 1x . HotEnd:
- 1x . Barrel 40 mm.
- 1x . Heater block.
- 1x . Nozzle
- 1x . Aluminium support for HotEnd (Included in the Kit Maker Play 3D)
- 1x . Nut M-6
To mount the hotend: use the M-6 nut to lock against the aluminum bracket and lock the assembly.
Pay attention to the measure of the extruder spring. This spring must have a length of approximately 5 mm.
Follow the instructions on the images for mounting the thermistor. Make sure that the thermistor capsule is inside the housing of the heating block.
Step 16: Wiring and Connexions
Step 17: Firmware
You can download the software here: http://marlinfw.org/
You must apply these changes:
ENDSTOPS
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
PRINT AREA
// Travel limits after homing
#define X_MAX_POS 90
#define X_MIN_POS 0
#define Y_MAX_POS 90
#define Y_MIN_POS 0
#define Z_MAX_POS 110
#define Z_MIN_POS 0
SPEED, UNITS AND ACCELERATION
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {750, 750, 500, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {841, 841, 40960, 950} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {10, 10, 0.35, 4.17} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {300, 300, 1, 17} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 150 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 17 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 5.0 // (mm/sec)
#define DEFAULT_ZJERK 0.01 // (mm/sec)
#define DEFAULT_EJERK 0.1 // (mm/sec)
Attached profile "Cura" to help set up the printer.
Step 18: Adjustments. Leveling Printer Dock and Z-axis EndStop Regulator
Leveling nuts.
You can level the print base using the four leveling nuts. Unscrew the nut to raise the base.
Z-axix EndStop regulator.
Now, you need to adjust the distance between the nozzle and the printing table.
This distance is fundamental for the adhesion of the first layer. To adjust this distance, you can do this by means of the screw indicated in the photo (on which the magnet is mounted).
If you lower this screw (turning clockwise) the nozzle will get closer to the printing base. If you raise the screw (turning counterclockwise) you will move the nozzle away from the base.
Note that if the nozzle becomes too high, the molten material will not stick as it should to the base. Otherwise, if the nozzle is too close to the printing base, it will make it difficult to get out of the material, causing a jam.
The use of masking tape on the printing base is recommended to improve adhesion and protect the methacrylate.
7 Comments
5 years ago
That's a really neat setup! I'd love to see photos of the finished project :)
Reply 5 years ago
Ok figured it out. The lewihe 3d printer is an incomplete kit. The kit includes the enclosure. The incomplete kit is 69€. The parts not included are what are provided in the bill of materials.
Reply 4 years ago
i just want the enclosure, where do i get one?
Reply 4 years ago
Hi.
Please, send an email to: juan@lewihe.com
Reply 5 years ago
Hi,
At the beginning of the instructable you can see some photos of the finished project and some videos.
Anyway, you can see here the photos and some video too:
5 years ago
Mi más sincera enhorabuena por tan magnifico instructable. Decirte que poseo una Lewihe Play construida según el proyecto original, perfectamente, a la que tengo previsto instalar una cámara caliente a 12v .. ¿Has considerado la opcion de incluir también esta mejora para poder ampliar la lista de materiales imprimibles?
Lo que me ha gustado de tu proyecto es que es tan limpio o mas que el original y has conseguido abaratarlo e incluso compactarlo, cosa que me ha motivado a construir una para fabricar las pequeñas piezas que se necesitan en el día a día en las funciones de mantenimiento industrial
Reply 5 years ago
Gracias por tu comentario!
Me alegro de que estés contento con tu Play.
Esta versión no sustituye a la original, digamos que es una versión "low cost". Tu modelo es más rápido debido a los motores Nema 14 y sistema de movimiento core XY, no obstante este modelo imprime muy bien materiales elásticos al montar extrusor directo.
En cuanto a montar una cama caliente en este modelo, se podría instalar sin ningún problema ya que esta versión y la original comparten el mismo sistema de base Z.
El soporte sería el mismo para los dos modelos: https://www.thingiverse.com/thing:1381247
Un saludo.
