Introduction: Play Midi Files From an SD Card Using Your Arduino UNO
About: Retired Electrical Engineer pursuing my hobby
Save Midi files to an SD Card and using a SD shield connected to your Arduino, play the songs on a Midi device.
This project shows how to make a Arduino based midi player. The Arduino is connected to a DS1307 Data Logger Shield which contains a SD Card reader. The Arduino outputs a midi stream of a midi file saved to the SD card in the Data Logger Shield. This midi stream can be connected to any midi synthesizer or midi device that can play the music.
Arduino Uno
PCB Mount MIDI Female DIN5 Jack
MC74HC14A Hex Schmitt-Trigger Inverter
2 x 220 Ohm Resistor
Push button
Midi Cable
Step 1: DS1307 Data Logger Shield
This Arduino shield is available from multiple sources; Amazon, eBay and aliExpress to name a few.
There is an excellent overview of the version 2 of the shield published by Adafruit
https://learn.adafruit.com/adafruit-data-logger-shield/overview
The shield used in this project is the version 1 of the hardware and differs from the one described by Adafruit. However, all the code and examples work with the version 1.
The DS1307 is a Real Time Clock chip and is used to provide precise time values. It can be used with a battery backup so will not lose time if power to surrounding circuits is switched off.
The data logger shield used in this project includes a DS1307 and a SD card reader. The primary use of the shield is to log data from sensors with a precise time stamp added to the reading. This information is stored on a SD card and can be retrieved at any time for analysis.
For this specific project, we are not using the DS1307 capabilities, only the SD card reader (sorry).
See above for a picture of the shield.
Some interesting features of the shield
  • The shield comes with a prototyping area, this will be useful later
  • The Arduino headers are available on the shield and can be accessed by soldering wires to the thru holes adjacent to the header
  • The shield includes two built in LED’s complete with resistors. Your circuit can connect to them via the wiring points.
  • Be aware that the Chip Select (CS) for the SD card reader is attached to Arduino pin 10 for this shield
The Arduino communicates with the SD card via SPI interface. Pin assignment in the picture.
Before wiring up the shield, test that the SD card is working via the following steps:
  • Format an SD card in your computer. It must be formatted as FAT32 (or FAT16 if you are nostalgic)
  • Copy a few files to the card. Because of the limitations of the reader, files names cannot exceed 8 characters with file extension limited to 3 characters (remember MSDOS)
  • The Arduino IDE should come with the SD library preinstalled. Check under File→ Examples for SD. If not install the library.
  • Attach shield to your Arduino and insert the SD card. Upload the program listfiles and run it. If everything is working, the serial monitor should list all files on the SD card.
Step 2: MC74HC14A Hex Schmitt-Trigger Inverter
The Schmitt trigger inverter is used to ensure that the midi signal comprises clean square waves of the correct voltage. A Schmitt trigger circuit includes hysteresis which ensures precise transitions from HIGH to LOW and from LOW to HIGH in a digital signal.
Link to a data sheet
https://www.mouser.com/datasheet/2/308/MC74HC14A-D-601265.pdf
If you are interested in how a Schmitt trigger inverter works, there are numerous articles on the internet describing their operation.
Step 3: The Circuit
See the schematic of the circuit.
The schematic does not show the 5V power and ground connections required for the MC74HC14 chip. These are wired 5V to pin 14 and Ground to pin 7.
The two LED’s and resistors are built into the shield. To use them, bridge Arduino Pin 5 and 6 to the L1 and L2 thru holes.
The midi stream is sent from the TX pin of the Arduino. By default, this is wired to pin 1 on an Arduino board. In the program, a Serial.write command will send the midi commands to pin 1 and on to the midi output circuit.
Step 4: Wire Up the Shield
The circuit as shown is wired up on the prototype area of the shield. This requires some fine work but is possible. See pictures of the completed shield.
As an alternative, the circuit can be constructed on a solder less breadboard. Refer to an article at www.midi.org that describes this approach
https://www.midi.org/midi-articles/arduino-midi-output-basics
Once complete, connect the shield to the Arduino.
Step 5: Add Libraries
In order for the code to work, the following libraries need to be installed.
SdFat (library used to access the SD Card)
MD_MIDIFile (library used to play midi files from the SD Card)
Use Tools → Manage Libraries to install.
The documentation for the Midi library is located at these two links
https://github.com/MajicDesigns/MD_MIDIFile
https://majicdesigns.github.io/MD_MIDIFile/
The examples included in the GitHub repository give an overview of how the library works. Also, some example midi files are included.
Step 6: Play MIDI File
To play a midi file, follow the following steps:
  • Load a midi file on the formatted SD card. The file name cannot be more than eight characters followed by the extension “.mid”
  • Open the sketch “MinimalMidiPlayer” in the Arduino IDE
  • In the Arduino sketch, change the declaration line [const char *loopfile = “LOOPDEMO.MID”] to specify the file on the SD Card
  • Make sure SD_SELECT = 10
  • Upload the sketch to the Arduino
  • Disconnect the Arduino from power source
  • Insert the SD card into the reader.
  • Connect the midi output jack via a midi cable to a synthesizer or midi player.
  • Connect the Arduino to a power source. Don't use the USB connector to provide power, it may not have enough capability to power the shield and Arduino. Rather use a source connected to the DC in jack on the Arduino
  • Push the button on the shield and the song will play. Success!
Step 7: Play Multiple MIDI Files
As an enhancement to this minimal midi player, it is possible to play multiple songs from the SD Card. Here are the instructions:
  • Load multiple midi files on the SD Card. The files must all be in the root directory. Files in sub folders will not play. The file names cannot be more than eight characters and must be followed by the extension “.mid”
  • Open the sketch “MultiTrackMidiPlayer” in the Arduino IDE. Adjust the delay (approx line 82) to allow for longer or shorter pauses between songs
  • Push the button on the shield and the songs will play in sequence until all songs ae played. Success!
