Introduction: Play PS2 Copied Games (Hack)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
Step 1: If You Have Backed Up a Game for Ps2, You're Going to Need a Mod Chip or Swap Magic for Your Ps2 So It Can Read the Disc, So First Things First, BUY a MODIFICATION TOOL!!!
Step 2: You Should Try Using Swap Magic, Because It's the Easiest, and You Won't Need to Modify Your PlayStation Too Much.
Step 3: But If You Use SWAP MAGIC, You Will Also Need a Special Mod Chip, SLIDE TOOL, or a FLIP TOP COVER, You Can Learn More About Those on the Swapmagic Website
Step 4: Read Directions on the Installation of Mod Chip, and Swap Magic Before You Do Anything (you Don't Want to Mess Up, or Else Your Ps2 Won't Work Properly).
Step 5: Install Your Modchip/flip Top Cover/slide Tool.
 (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
Step 6: Follow Directions That Came With Your Swap Magic Discs, and You're Basically Ready to Go!
Step 7: HOW TO USE SWAP MAGIC
Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Step 8: Now Insert the Swap Magic Disc Into the Ps2,
Step 9: Press Power on Button Until Screens Comes Up.
  • 1. With option that says load cd open the top cover of the flip top.
  • 2. And take out the cd when it stops spinning.
Step 10: Now Insert Your Copied Game and Click Load CD.
Step 11: Its That Easy
