Introduction: PlayStation 5 Holder
I made a desktop PS5 controller holder. I made this because my controller kept falling so this gave it somewhere to be
to make this I used a 3D printer anykind works, PC anykind works as long as you have autodesk inventor professional, a flash drive
Step 1: App
Open Autodesk Inventor Professional 2024 and create a new part (.ipt)
Step 2: Sketch
Press sketch and click on the XY plane. Then click rectangle and from the origin make a rectangle with the dimensions of Hight: 5.7in Length:2.4in
Step 3: Extrude
Click finish step and then click extrude and extrude it by .25in
Step 4: 1st Line
Next click new sketch and click on the face of the rectangle. Click on line the add a line 2 in from the top. You can use dimensions to help with the measurements
Step 5: 1st Bend
click finish sketch and then click modify then bend part click on the line and make the angle 130 and radius 0.05
Step 6: 2nd Line and Bend
Of the former rectangle make a new line 1.5in from the bottom on the opposite side. Click finish sketch then modify then bend part click on the newly made line. change the angle to 90 then finish
Step 7: Final Line and Bend
On the same side make another line 0.5in from the bottom. Click finish sketch then modify then bend part click on the newly made line and finish the bend
Step 8: Finished Product
If you have done it right the finished product should look like this.
Step 9:
insert your flash drive click export and then click on pdf file and add it to your flash drive then insert it to the 3d printer and watch the magic
