Introduction: Playing Cards Clock
In this Instructables, we will use an old clock and playing cards to change it into a brand new one !
Do not forget to vote for me on the clock contest :)
You will need basic tools :
Scissors
Ruler
Glue stick
Spraypaint (black)
Flat screwdriver
Cardboard
And obviously :
Playing cards
An old clock
Step 1: Recover the Clock
First you will recover the clock using a flat screwdriver and remove the clockwises.
Step 2: Paint the Clock
Then you will paint the clock with a black spraypaint. Let it dry the time it needs.
Step 3: Cut the Clock Basis
Once the clock is dry, measure its intern radius and cut a sheet of cardboard that fit in it.
We will use a little bit a trigonometry to mark it !
Draw lines as shown in the picture, at every quarter of it width and high.
We so have marked the place for every card we will glue.
Step 4: Choose Your Cards
Then you can choose the cards you will glue on your clock and practice how you will do it.
Be carefull that your last cards go under your first.
Step 5: Glue Your Cards
It's time to glue your cards on the round cardboard sheet as shown in the picture.
Step 6: Cut the Cards Corners
Then you must cut the corners of the cards and drill the center of your center card (mine was first the king but finally I chose the joker). You can glue it on the center of your cards.
Step 7: Put Everything Together
Finally glue the cards on the clock, put everything back together and you are done !!!
