Introduction: Plywood Cutting Board
Tools Needed
-Table Saw
-Clamps
-Planer
-Slide Miter Saw
-Drum Sander (recommended)
-Palm Sander
Step 1: Cut Plywood Strips
-Acquire 1/2" plywood and set the table saw at 1 1/4"
-Cut 18 strips as shown
Step 2: Glue
Generously apply glue to each of the strips face and clamp them together like a sandwich.
Step 3: Run Through Planer
-After the glue has dried, run the piece through the planer
-Plane until the piece is flat on both sides as shown
Step 4: Square the Imperfect Edges
-Use a slide miter saw to square up each edge
-Try to cut as little material off as possible
Step 5: Run Through Drum Sander
If available to you, run the piece through the drum sander to smooth the surface.
Step 6: Round the Edges
-Trace around a round object on each edge to keep consistency
-Move to the disc sander to round the edges
-Sand down to pencil line
Step 7: Cut Dado Cuts to for Visual Appeal
This step is optional
-Set up the the sled on the table saw as shown
-Set appropriate blade height to cut in 1/8"
-Cut 1" from the edge of the cutting board
Step 8: Paint Dado Cuts
-Tape off each dado slot for accuracy
-Paint the inside edge of each dado cut for visual appeal
Step 9: Sand Through the Grits
-Start at 80 grit sand paper and attach it to a vibrating palm sander
-Take your time sanding through the grits (80, 100, 120, 150, 180, 220, 240, 320, 400)
Step 10: Finish With Tung Oil
-apply tung oil generously
-let it dry overnight and apply a second coat
-allow a week for the second coat to cure before use
