Pneumatic Squib for On-Actor Film Blood Effects
Intro: Pneumatic Squib for On-Actor Film Blood Effects
This Instructable is derived from available Internet resources on fabricating special-effect blood-shooter devices from hand-pumped garden sprayers. It seeks mainly to minaturise the design.
This particular design grew out of a general dissatisfaction with the restrictions the garden-sprayer style of blood-shooter placed on the staging and choreography of blood effect shots.
The goal was to create a device that could replace the garden-sprayer design in all situations, and add flexibility in staging effect shots.
STEP 1: Building the Control Hose
The Control Hose carries air between the hand-held remote section of the device and the effect section of the device. It is the simplest element to construct, so we'll build it first.
The control line consists of only two unique components: the hosing and identical fittings at either end. The hosing is 1/8" OD urethane line. The fittings are 90º universal fittings with 10-32 threads
Clippard Parts List:
2x UT0-2
1x 1/16" internal diameter polyurethane hose.
Substitution Option:
2x Beswick Engineering MLS-1008-1-303 instead of the UT0-2
Beswick makes the smaller, square swivels with countersunk screw-heads that work just as well as the hexagonal UT0-2 fitting from Clippard, but they don't sell them individually.
2x UT0-2
STEP 2: Build the Hand Held Control
The control unit allows the device to be charged with air, and holds pressure in the device until the actor triggers the effect. It is a design that was originally developed as a pilot trigger for an air cannon.
1x 3-way toggle valve (TV-3S)
1x Check-Valve ( I used a MCV-1BB and a short coupling 11999 - you can save a part and use a MCV-1AB)
Then, use one of the following air inlet designs
Design 1
1x 1/8" barb with 10-32 threads (CT4) capped with a
1/x short piece of 1/8" ID 1/4" OD urethane hose.
Design 2
A Quick Disconnect assembly made up of:
1x MJQC-VMT 10-32 threaded valve body
1x MJQC-CB4 1/8 barb quick disconnect cap
1. The check valve will have an arrow on it. If you ordered the valve with the suffix AA, screw a short coupling into the end of the valve the arrow points at. If you ordered the valve with the suffix AB, this end of the valve will already have male threads.
2. Screw the check valve into the bottom of the 3-way toggle so the arrow points towards the 3-way valve.
3. Screw either of the inlet assemblies described above into the open end of the check valve.
4. There is one remaining threaded port on the 3-way (the output)- attach your signal/control line to that port. The smaller, non-threaded opening on the 3-way is the exhaust and it should not be obstructed.
That's it - you should have something resembling the pictures from the above tutorial.
Design 1
Design 2
STEP 3: Build the Effect Assembly
The effect unit was designed as a miniature pneumatic cannon.
1x 2-cubic-inch volume chamber (MAT-2.0)
1x 10-32 solid plug (11755)
1x 10-32 miniature quick exhaust valve (MEV-2)
2x 1/8" barbs with 10-32 threads (CT4)
1x 10-32 bulkhead fitting (15027)
1x short piece of 1/8" ID urethane hose.
1x long piece of 3/8" ID hose. (A foot of 3/8" hose holds 20 mL of stage blood. The squib can eject all the stage blood from 3 feet of hose, so the length of this hose will detemine how "juicy" your squib is.)
OPTION: Substitute 1 4CQ4 fitting (1/4" NPT to 1/8" Barb) for the 15027 (Bulkhead fitting) and one of the CT4 (10-32 to 1/8" barb) elements.
1. Screw the solid plug into one of the ports on the Volume Chamber.
2. Screw the quick exhaust valve into the other port on the volume chamber. There's only one male port on the QEV, so you can't get this wrong. (but for clarity, it's labelled "C")
3. One of the remaining ports on the QEV will be marked "E". This is the port you attach the effect tube to. Screw one of the 10-32 threaded 1/8" barbs into the port.
4. Attach a short piece of 1/4" OD urethane line to the barb.
5. Screw another 1/8" barb into the hexagon-shaped end of one of the 10-32 bulkhead fittings. Plug the barbed end of this fitting into the short piece of 1/4" OD line. You may remove the retaining nut and lock-washer from the bulkhead fitting - you don't need them.
6. Work about a foot of the 3/8" vinyl tubing onto the bulkhead fitting. It will be a tight fit. I used needle-nosed pliers to stretch the hose to fit the fitting.
7. Attach one end of your control line to the remaining port on the QEV - it will be marked "L"
8. Squash the unconnected end of the 3/8" tubing flat and tape it shut with a strong waterproof tape.
9. Pierce or cut a port near the taped end of the hose which will act as the nozzle through which the stage blood will be ejected.
STEP 4: Using the Effect
Use of the Effect:
1. Fill the effect tube and cover the output hole with the smallest possible piece of low-tack masking tape.
2. Tape the effect under the actor's clothing in the appropriate orientation. If the tube must be oriented with the output hole higher than the quick-exhaust, I recommend pushing a plug of banana down the hose before filling it with stage-blood.
3. Dress the actor in the outer costume and pass the control module down the actor's sleeve to their hand.
4. Make a very small cut in the costume over the output hole of the effect. The smaller the hole, the more blood will stay on the actor's clothes. The larger the hole, the more blood will spray away from the actor.
5. Flip the switch towards the control line fitting and connect your air supply to the air inlet. Pressurise to between 60 and 100 PSI. (use a pump with a gauge, or a compressor with a regulator)
6. Disconnect your air supply and film the scene - the check valve will keep the squib pressurised.
7. When the actor is ready, he can flip the switch and the effect will trigger.
53 Comments
seangroves71 2 years ago
1) My bike pump can not over come the check valve for the infill.
2) when trying to fill the effect all the air is just immediately flowing out the exhaust of to the effect line.
Thoughts?
ninglesby 10 years ago
Crosius 10 years ago
You'd still need a 12V, 6.5W power circuit to trigger the squib, but you can probably build something inexpensive around a 555 set up as a monostable pulse generator that would trigger the solenoid effectively.
brotherbones 11 years ago
MFXPYRO 12 years ago
Crosius 12 years ago
The miniature valves that also incorporate manual controls at that size have lower flow rates than the exhaust valve.
My other reason for using this configuration was to separate the control & the effect by a long distance, while keeping the distance from the air supply to the effect tube as short as possible.
If the effect tube was being cleared by air passing through a long tube from the switch, there would be a very different attack/decay to the effect "burst". It would start and stop less dramatically.
kanzume 12 years ago
Cheers!
I know Clippard has limited distribution outside of the Americas. You could try ASCO. They make similar valves and they have distributors in Australia.
ScubaSteve 14 years ago
Crosius 14 years ago
If you have a local reseller like Wainbee, you may want to have them order the parts for you.
If you can't find a local source for Clippard parts, a company by the name of Pneumadyne makes similar products.
RavingMadStudios 14 years ago
1. Adding a tee fitting (Clippard # 15002-3) to move the check valve next to the cylinder and substituting a 2-way valve (Clippard # TV-2S) for the three-way valve greatly increases the concealability of the trigger.
2. We have found that using small amounts of poster-tack style removable putty adhesive to seal the hole in the effect tube (rather than the low-tack masking tape), seems to reduce premature blood leakage when the actors have to wear their loaded squib for extended periods before firing it, or when they have to move around a lot onstage before activating the effect. The effect still works perfectly with the poster-tack, as long as you don't use way too much.
3. I highly recommend purchasing extra screw plugs (Clippard # 11755, the same as used to seal the top of the air cylinder) for use as a safety. Actors can be kind of clumsy sometimes, and the last thing you want during a performance is someone accidentally triggering a squib backstage. The screw plug is used to seal the exhaust hole in the toggle valve, and prevents the squib from firing even if the toggle switch is flipped. A stagehand simply removes the plug with a screwdriver at the appropriate time to "arm" the device. You could also use a second toggle valve attached into the trigger line for this purpose, but this would increase the expense a bit. Either way, a safety of some kind is a very good idea.
Anyway, this is a great effect, and it's really giving our production a very polished and professional look. Thanks once again to Crosius for sharing it with us.
Also, great solution for avoiding early triggering. Too bad it will only work with the two-way valve, though, as the three-way's exhaust isn't threaded 10-32 and the plug won't screw into it - if I wasn't using 3-ways on my squibs, I'd be using that on the next set.
