Introduction: Pneumatic Syringe Elevator
Before the project, here is some information about hydraulic and pneumatic power:
Hydraulics: Are something using WATER moving through something for power to move something else. They are used in Wings and Rudders, Excavating Equipment, and Hydraulic Brakes.
Pneumatics: Are something using AIR moving through something for power to move something else. For example: Air Brakes, Exercise Machines, Compressed-air Engines, and more.
They both harness a section of matter to move something using pressure.
The syringe-evator uses pneumatics.
Step 1: Get Suplies
What is needed:
A large cardboard box
8 syringes
3-4 ft. tubing
scissors
hot glue and hot glue gun
Step 2: Measure and Cut Cardboard
You will need 2 6x11 in. rectangles, an 8x11 in. rectangle, and a 6.5x5 in. rectangle.
Step 3: Cut Two Holes.
In one of the 6x11 rectangles cut two holes that your syringes can slide into. One 3.5 in. up and the other 6 in. up, and the one on the top should be 1 in. to the right of the other one.
Step 4: Put Syringes in the Holes
Insert the syringes into the holes you made in the previous step. Label the lower one 1b and the upper one 3b.
Step 5: Measure Where Two More Syringes Will Go
Take another syringe and fully extend it and hold it up to 1b and take a not extended syringe and hold it up to 3b the tops of the plungers should align. Hot glue them in place and label the lower one 2b and the upper one 4b.
Step 6: Add the Tubing to the Sringes
Attach the tubing to the syringes.
Step 7: Cut 2 Holes for Tubing
Next to syringe 1b cut a 1/4 in. hole and slide the tubing attached to 4b through it. Than cut a hole or triangle at the bottom and slide the tubing for 2b through it.
Step 8: Attach the Other Syringes
Take the last four syringes and attach them to the tubes and label them correspondingly (1b to 1a, 2a to 2b, ext.)
Step 9: Add the Other Panels
Using hot glue attach to pander with the syringes to the side of the 8x11 in. rectangle. On the other side of the 8x11 in. rectangle add the other 6x11 in rectangle.
Step 10: Add the Stoppers
Take the Styrofoam and cut 3 little rectangular prisms out of it. Add one of them every wall and the tops should be slightly over the top of syringe 2b.
Step 11: Create Two Ts Out of Popsicle Sticks
Create two Ts out of Popsicle sticks one should be bigger than the other. Attach the bigger T to top of syringe 2b, and have the flat side against the wall. Add the smaller T to the top of syringe 4b have the flat side away from the wall.
Step 12: Cut a Hole for the Upper T
Cut a hole for the Popsicle stick touching the wall so 3b can fully retract, then extend the hole up by about 3/4 in.
Step 13: Cut the Smallest Piece of Cardboard
Cut the smallest piece of cardboard so that when it goes up from the stoppers it doesn't get caught on anything.
Step 14: How to Use
Extend 1b by pressing on the syringe 1a. Then extend 2b with 2a. After that press on 3a to extend 3b pushing 4b under the platform. Press on 4a to make 4b lift the platform up.
