Pocket Cheerio Catapult
Intro: Pocket Cheerio Catapult
Have you ever had an extremely annoying boss, co-worker, or classmate?Have you ever been pranked and you need to redeem yourself and earn revenge?The solution is this pocket-sized, long range mini catapult.You can launch just about anything from a grain of rice to a pea over 30 ft!The materials needed to make this project are extremely easy to find, and you will most likely already have them.
I thought of making this over the summer when I was extremely bored and I decided to make something that shoots, and considering that I already had a large collection of pop can tabs, I figured that this was the perfect idea.The great part about this shooter is that it can be made on the spot in 2-3 minutes!
Created by the Think, Plan Create Clan as a part of our instructables sponsorship guide.
STEP 1: Materials
Materials
*1 Popsicle stick.
*1 soda can tab with the little “o” in the bottom part as shown above
*1 small to medium sized rubber band. (small is best)
*Scotch tape
Tools
* A coping saw or craft knife
STEP 2: Preparing the Popscicle Stick
Slip the top circle of the pop can tab onto the Popsicle stick about ½ of an inch from the bottom. I found that this distance away from the bottom results in farthest shooting. Tape right above the pop can tab so it won’t move up and down on the Popsicle stick. Using the coping saw or craft knife, cut one notch at the top of the Popsicle stick. This will hold the rubber band.
STEP 3: Prepare the Rubber Band.
Take the rubber band and if it is longer than half of the Popsicle stick, then hold the rubber band in a circle, cross it so it makes a figure 8, and then align the top and bottom circles of the eight.This should make the rubber band half of its original size. In this project, the tighter the rubber band, the better the performance.
STEP 4: Attatching the Rubber Band
Tie a knot in the center of the rubber band. Hook the rubber band onto the pop can tab’s little “o” shaped ring the way I did it on the picture, because that way, no matter how hard you pull, the rubber band won't come off. Hook the other end of the rubber band onto the notch at the top.
STEP 5: Enjoy!
To shoot, place your ammo onto the pop can tab as shown in the picture, pull it back, and shoot! Don't let your boss beat you in the next office war, just bring this along with you, and you'll win every battle. Questions and Comments are appreciated so please post them below! Enjoy!
-Doctordv
9 Comments
sickdevotee63 10 years ago
Nate230 10 years ago
urtlesquirt 12 years ago
mrbubbles9868 11 years ago
imboredalot 11 years ago
DoctorDv 11 years ago
-Doctordv
Servelan 11 years ago
boom man56 11 years ago
Paracord Ninja 12 years ago
