Pocket First Aid Kit
Intro: Pocket First Aid Kit
Out hiking or just for a walk and don't want to carry a bulky kit? This will fit into your pocket no trouble!
The ever so versatile Altoids Tin becomes a First Aid Kit to carry with you. Just add stuff from the following steps (or similar).
STEP 1: Stuff to Stuff In
I've addded a few thing sI might find handy, things not everyone will have around.
A suture kit (mine isn't sterile, the package got ripped)
Bands Aids (6 large, 6 small)
Moist Towelettes (optional)
Rubber Bands
Tape
Aspirin
Swabs
Paper Towel (or gauze if you have it)
Razor Blades
Super Glue
Betadine
Isopropyl Alcohol
Rubber Bands
Tape
Aspirin
Swabs
Razor Blades
Super Glue
Betadine
Isopropyl Alcohol
STEP 2: Box Prep
On the back side of the box I put 4 layers of tape. A good storage area and easy to get to.
On the front I trimmed down my Red Cross sticker to fit.
STEP 3: Inside Cover
Here I taped the 2 Razor blades and the Aspirin. Easier to get to then digging though the box.
STEP 4: 1st Layer
I added the bulky/big things here first. The bottles are must small enough to fit and the suture kit lays nice and flat on the bottom. Be sure to sterilize the suture before use with the Betadine or alcohol.
STEP 5: Layer 2
Swabs (ends in little bags) and small band aids fit in here.
STEP 6: Layer 3
I added a few small pads of paper towel above the small band aids. If you have gauze use that instead.
STEP 7: Layer 4
I folded over the edges of the towelettes to help them fit, these are optional as you have gauze(paper towels) and alcohol.
STEP 8: Last Layer
The big old band aids sit on top, make sure you can close up the tin after this step. Rearrange if need be.
STEP 9: Final Prep
Close tight and wrap the rubber bands around the case. These can be used for tourniquets or to hold things in place where tape doesn't work.
STEP 10: Pocket and Go
All done, now put it in your pocket and go.
Any suggestions are appreciated!
37 Comments
LanceL16 6 months ago
I wrap my bandage tape around a cut-down popsicle stick. I don’t know if that preserves the adhesive better than your method or not. I may try yours. There is also a lot to be said about using duct tape instead.
I would add:
• Triple antibiotic wipes (or micro tube). A must for small injuries.
• Disinfectant wipes (for hands). Replace the towelettes with these is space is needed.
• To your gauze pads add some Mole Skin. A life saver if a blister develops.
• To your pills I would add/change:
- A couple of Benadryl for allergic reaction.
- 3 Imodium tablets. Eating something that brings about the runs WILL cause dehydration & that is serious.
- Exchange aspirin for Tylenol. Aspirin is a blood thinner. Not good if your already bleeding. Also more caustic on your gut.
If space permits and you’re going for a scouting first aid badge, consider
• 1+ Bug bite wipe (analgesic).
• Sting ease packet. Bee stings can be very distracting. Nice compliment to the Benedryl.
• Burn cream packet.
• Finally, a pair of tweezers. Taking home a splinter is not a good souvenir.
To round out your personal protection array for a day of adventuring, in addition to this first aid kit include:
• plenty of water
• electrolyte supplement
• 1 protein bar.
• sun screen SPF 50
• 1 or more bandanas. (exposure protection, additional bandaging, tourniquet, a fashion statement)
• hat & sun glasses.
porcupinemamma 15 years ago
WereCheetah 14 years ago
SashasDoc 2 years ago
Rubber bands aren't the best choice though. Narrow items like rubber bands and shoelaces damage the underlying tissues and should the limb be salvageable once the victim receives medical care, using narrow items as tourniquets can result in permanent nerve and vascular damage. Ideally, the item used for a tourniquet should be about 1" wide, but--that said--applying it when needed to preserve life is more important that the other considerations.
oawv803 15 years ago
nnygamer 15 years ago
buggvin 12 years ago
MakerCL 11 years ago
Great solution nnygamer! Love the whole thing!
Slamjam 9 years ago
Great idea. Can't seem to find any containers small enough to put alcohol or betadine in though. Also I am confused by the first slide. I see what appears to be gauze on the bottom (outside) of the tin.
Is the tape under the gauze? Why is the gauze on the outside and not on the inside?
sarah209 7 years ago
Sephora has teeny sample vials that would be perfect. Maybe include a sample of sunblock since you are hanging out at Sephora bumming vials, anyway.
MicheleF 9 years ago
try eye drops bottles for your alcohol and betadine
candogoods 10 years ago
cowtipper97 16 years ago
nnygamer 16 years ago
Maybe adding a second tin to put more stuff in would work and still keep it pocket size.
