Introduction: Pocket Hole Jig Station. DIY. Cheap and Simple
Hello!
Today i will show you how to make quick and easy Pocket Hole Jig Station. Pocket holes are one of many methods of joining wood together. It uses the simplest of joinery- right angle cuts mostly, and relies on the mechanical strength of screws to hold an assembly together. Although glue is sometimes used to augment it, the screws themselves do most of the work.
Step 1:
Original kreg jigs are very expensive. My project will allow you to save lots of money and you can spend them for some other tools. Besides the jig can be dismounted and used freely about the workpiece.
Step 2:
Step 3:
Lets start! I took an oak Board and mark center. Then i cut two pieces of board. I will use them as a support for pocket hole jig. I used jig and drilled holes in this supports. Add some glue and fixed with screws.
Step 4:
If you do everything right, then you will get flat surface with right angle.
Step 5:
Now I will make a mount for the vacuum cleaner. I cut two pieces of board 8*8 cm and add one more pieces between them. The vacuum cleaner pipe is attached very tightly.
Step 6:
Now we shuld make a fixing clamp. I take F Clamp and replace one pice (as shown on the picture)
Step 7:
Now we need to fix this clamp to the base. I cut two pieces of wood and drilled holes in it. Fixed with screws.
Step 8:
Thats it, we all done! Our Pocket Hole Jig System is ready and we a redy to try it in work. Thanks to this clamp we can fixed wood with different width. Vacuum dust remover work perfect.
Step 9:
I spend about $ 15 on this project, but it works just as well as the $150 original jig.
I hope you like it! Thanks for watching and have a nice day!
Build a Tool Contest
1 Person Made This Project!
- hugofc made it!
14 Comments
7 months ago
¡Qué buenísima idea, gracias por compartirla Polkilo!
¡Internet es una hermosa herramienta!
2 years ago on Step 9
the link to clamp is for the wrong size clamp it would be helpfull if you specifyed the size clamp you used. Nice projject.
2 years ago
Well done!
Question 2 years ago on Introduction
Can I use something other than oak (3/4 inch ply for example) to make it less expensive)? Do you have specific dimensions for the project?
Answer 2 years ago
you can also use plywood. I just had some scraps of oak wood left. you can choose any size. I designed a compact station, you can make a large one. if you need specific dimensions, I can measure my station
Reply 2 years ago
Dimensions would be great. I prefer working off somewhat of a plan. A bit of a newbie to woodworking.
Awesome, what a great idea.
2 years ago on Step 3
This is a good idea and I can see how it could be incorporated into a work bench for larger material.
2 years ago
Top 16 !
Great great idea !
Reply 2 years ago
Thank you so much 👍😊
2 years ago
Thank you!! I absolutely hate my Kreg Jig Master.
Ralph
Reply 2 years ago
You are welcome:)
2 years ago
What a great tool! Thank you for sharing!
Reply 2 years ago
Thank you so much 👍
