Introduction: Pocket Launcher
The Pocket Launcher is a miniature sling shot designed to fit inside your pocket. While tiny, this item is robust and will be by your side through many adventures.
  • Scissors
  • Measurement device
  • 2 Rubber bands
  • Felt
  • Poms
  • 3D printer
Step 1: 3D Print the Body
  • Download .stl file
  • Upload to slicer
  • Print to desired settings
  • Duration (1 hour)
Step 2: Use Scissors to Cut 2 Rubber Bands in Half
Step 3: Cut a 30 MM X 100 MM Rectangle From Felt
Step 4: Fold in Half
Step 5: Fold Again "hotdog" Style for Added Strength
Step 6: Use Scissors to Cut a Small Slit in Felt
  • Cut a slit on the left and right side of felt
  • Be careful not to cut too much
  • Do not cut too close to the edge
Step 7: Slip 1 End of Rubber Band Through the Slit in Felt
Step 8: Tie the Rubber Band in a Knot and Trim Excess
Step 9: Use Scissors to Cut a Sharp Angle on the Other End of Rubber Band
Step 10: Poke the Tapered Rubber Band End Through Hole in Body
Step 11: Tie Rubber Band in a Knot and Trim Excess With Scissors
  • Repeat steps 6-11 to other side
Step 12: Pull Sling Back and Ensure All Knots Are Secure
