Introduction: Pocket Sized Instruments
Pocket sized instruments are very fun for everyone. I'm going to show you how to make a drum, maraca, and panpipes. Most of these are made out of recycled materials.
Note: All of them will require scissors.
Step 1: Maraca
To make the maraca you will need:
- Tape
- Plastic Egg
- Beans/Rice/Pebbles
Step 2: Beans
Add your beans to the bottom half of the egg, then close it.
Step 3: Taping
Tape around the plastic egg to ensure it does not open. Now your maraca is complete, shake away!
Step 4: Straw Panpipes
Materials:
- 4 Straws
- Tape
- String (Optional)
Step 5: Taping
First cut all straws in half, then tape them together (make sure they're straight).
Step 6: Cutting
Lastly cut one end of the straws diagonally. Now blow through the straight end of the straws. The shorter the straw the higher the sound.
Note: If you want you can tape/glue a string on the panpipes so you can wear it around your neck.
Step 7: Drum
For making the drum you will need:
- Toilet Paper Tube
- Parchment Paper
- Rubber Band
- Tooth Picks (Optional)
Step 8: Cutting
Cut a small part of the toilet paper tube off (this is the part you use). Next cut a piece of parchment paper that is bigger than the toilet paper tube.
Step 9:
Put your toilet paper tube on a bottle that is slightly smaller than it. Then take the parchment paper and wrap it around the tube. Next wrap a rubber band tightly around the parchment paper and tube.
Step 10:
Carefully take off the toilet paper tube, and trim off any excess parchment paper. If you want you can use toothpicks as drumsticks. Now your drum is complete!
Step 11:
I hope you enjoyed this instructable. Please comment down below with your thoughts an questions!
