Pocket-Sized Nightlight, Low Voltage With Timer
3,538
17
19
Introduction: Pocket-Sized Nightlight, Low Voltage With Timer
This little gadget is for the the little kids.
It creates an ever changing palet of colorful lights on the wall and ceiling.
It uses the ever popular 555 timer (gateway drug equivalent in electronics) to turn itself off in 15 (+ or - 3) minutes.
The voltage in low enough to be battery operated but works best with a wall AC to DC transformer. 9 volts is best, plus safe for the kids.
And now for a video:
Step 1: Prepare to Shop at Ebay
Almost all the components used in this instructable was found on ebay.
My ebay search included but is not limited to:
  • Slow fade RGB LED
  • color changing LED
  • 555 timer
  • small tin container
  • transistors
  • MOSFET
  • Capacitors
  • switches
I am a little addicted to ebay.
Step 2: Parts and Tools
Here is the parts list:
  • 10 color changing LEDs. RGB Slow change or Slow fade. Avoid "Fast Blink" RGB LEDS - this is a sleeptime nightlight for the kids, not a disco light system.
  • 1 555 IC
  • 1 power transistor or MOSFET
  • 2 10 KOhm resistors
  • 1 0.01 uF capacitor
  • 1 36 Ohm resistor
  • 1 1.8 M Ohm resistor
  • 1 1 M Ohm resistor
  • 1 470 uF electrolitic capacitor
  • 1 NO momentary push button switch
  • 1 power jack
  • 1 small tin container with a clear lid
  • Some wires
  • Solder
  • Glue
  • a scrap piece of wood
Tools:
  • Soldering iron
  • wire cutters
  • wire strippers
  • dremel
  • drill press or hand drill
  • drill bits
Step 3: The Circuit
What we are using is a 555 IC set up into a "Monostable" configuration. What this means is that the 555 IC would output a signal when the button is pushed. The signal duration is based on the "RC" values. RC stands for Resistor-Capacitor. In our case, we have a 470 uF capacitor that is being charged through a resistor with a value of 1.8 mega ohms. The time it will stay on then turn off is based on RC Time Constant calculations (Google "RC Time Constant Calculator") which is 846 seconds. Now, given resistors can be off on there value + or - 5-10% and capacitor can be off by + or - 5-25%, the monostable signal can be anywhere from 13 minutes to 17 minutes. That's a good amount of time for the kids to get mesmerized by the slowly changing light show on the wall and ceiling and drift off to rainbow filled dreams for the night. the nightlight then turns itself off.
The circuit is so simple that I did not even bother making a circuit board. i just soldered directly to the legs of the 555 chip.
So here is the setup:
  • Pin 1 - connects to ground
  • Pin 2 - Trigger - connect to one side of switch and to one end of a 10 k-Ohm resistor. Connect the other end of the resistor to the POSITIVE side of the power supply. Connect the other side of the switch to GROUND.
  • Pin 3 - Output - connect to 1 M-Ohm resistor. connect other end of resistor to GATE of MOSFET or transistor (more on mosfet below)
  • Pin 4 - reset - connect to 10 k-Ohm resistor. Connect other end of resistor to POSITIVE side of power supply
  • Pin 5 - control - Connect to 0.01 uF capacitor. Connect other end of capacitor to NEGATIVE side of power supply.
  • Pin 6 - threshold monitor - BRIDGE Pin 6 and Pin 7 together. Connect the POSITIVE side of the 470 uF electrolytic capacitor to Pin 6. Connect the NEGATIVE side of the capacitor to the NEGATIVE (GROUND) side of the power supply.
  • Pin 7 - Discharge - connect this pin to the R of or RC circuit. That is the 1.8 m-ohm resistor. Connect the other end of resistor to POSITIVE side of power supply.
  • Pin 8 - VCC - this is the POSITIVE power leg. connect it to the POSITIVE side of the power supply.
I did not have a power transistor but I have a ton of irf610 MOSFETs. Why is a transistor or MOSFET needed. Well, the 555 IC can only handle 200 milliamps max. Ten LED's at 20 milliamps each is pushing that limit. The solution is to send the output signal coming out of PIN 3 into a 1 m-Ohm resistor and connect the resistor to the GATE of a MOSFET. Now the current going through the 555 output pin is probably less than the power to light 1 LED. The MOSFET can handle 1.5 Amps so 200 milliamp is nothing.
MOSFET wiring:
Attach the SOURCE leg of the MOSFET to the NEGATIVE side of the power supply.
Attach the DRAIN leg of the MOSFET to the 36 Ohm resistor. The other end of the resistor connects to the NEGATIVE side of the LEDs.
Attach the POSITIVE side of the LEDs to the POSITIVE side of the power supply.
Step 4: The LED Array
I made a template to make it easier to solder the LEDs together. In my case I wanted to make a star shape. i drilled 5mm holes in a piece of MDF (scrap piece of wood).
I inserted the LEDs into the holes makng sure to line up the legs.
I bent all the NEGATIVE legs into the center of the star. I then bent the POSITIVE leg of each LED so that it is touching the POSITIVE leg of the LED to its right.
So what I have is an array of 10 LEDs connected in Parallel.
I put a large gob of solder in the center to hold the negative leg of all the LEDs.
I soldered each positive leg of an LED to its neighboring LED to the right - positive leg to positive leg.
Trim the excess leads with wire cutters.
Find a 3 volt source and test the LEDs to make sure every one lights up.
Test fit into your container. Glue it down.
Step 5: Final Assembly
Drill a hole in your container for the switch and the power plug.
If using a tin container, insulate your circuit and cram everything in there.
plug into AC-DC transformer and press the button. it should now GLOW. In fifteen minutes (give or take 3 minutes) the light show should turn off.
Since everything is working it is now time to glue the container shut. This is for kids, so it is best if they can't open it.
congratulations. I hope the kids like it.
Pocket Sized Electronics
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    19 Comments
    ritzanab
    ritzanab
    9 years ago
    Sorry also, is the white on black schematic the same thing as the black on white schematic...
    I am having great difficulty reading what the white on black one says.
    MrTinkerer
    MrTinkerer
    I'm sorry. I thought both schematics where black on white background. In any case, the two schematics I have explain two different things, the first one explains how to wire up the 555 timer chip. the second schematic explains how to wire a MOSFET to the output (pin 3) of the 555 timer.
    aanderson-rolfes
    aanderson-rolfes
    9 years ago
    Do 4 pin LED rgb lights work for thi?
    MrTinkerer
    MrTinkerer
    sorry, no. The circuit does not have controls for each individual color of an RGB LED. the circuit is there just to turn the night light off automatically after a set amount of time based on the RC Constant. I used LEDS that are RGB but change color on their own.
    MrTinkerer
    MrTinkerer
    solder the legs of pin 6 and 7 together. :)
    ritzanab
    ritzanab
    9 years ago
    Thank you for ur help!!
    ritzanab
    ritzanab
    9 years ago
    Also what is the casing?
    MrTinkerer
    MrTinkerer
    i did an ebay search for "round tin clear top"
    ritzanab
    ritzanab
    9 years ago
    Thanks!! Can you possibly send me a link to the resistors?
    MrTinkerer
    MrTinkerer
    Here is the link when i did a search for "Resistor Assortment"
    http://www.ebay.com/itm/77Values-metal-film-resistor-assortment-kit-1W-1-3850pcs-/390598832628?pt=LH_DefaultDomain_0&hash=item5af18131f4
    Adarsh_tronix
    Why have you given separate bullets for 555 IC and 555 timer?I thought they were the same,or aren't they?
    MrTinkerer
    MrTinkerer
    You are right. That was a typo. I have corrected it.
    ritzanab
    ritzanab
    9 years ago on Step 2
    Sorry, if possible a link for all resistors...THANKS!!!
    MrTinkerer
    MrTinkerer
    Reply 9 years ago on Step 2
    Cost for the project is perhaps $10-$15. Less if your are really good at shopping. I purchased an assortment pack of resistors at ebay. I made sure the assortment contained the values I needed. you can always chain a series of resistors together to get the value your want too.
    ritzanab
    ritzanab
    Also, if possible can you send me a link on ebay for the 36 Ohm resistor? Thanks.
