Introduction: Pocket Sonic Ruler
This a pocket sized Ultrasonic scale you could carry in your pocket and measure the length of object.
You could measure your height, furniture heights etc.,
I am writing this instructable on the assumption that you know how to install Arduino IDE and upload code to arduino uno using it.
So Lets get Started.
Components used:
Arduino Uno
TM1637 - 7 segment display
HC-SR04 Ultrasonic scale
Switch
Arduino power jack
9V battery and its connector
Step 1: Connections and Code
Ultrasonic has 4 pins: echo, trigger, vcc, gnd
Connect VCC to pin 8 of arduino
echo --> pin 7
trig --> pin 6
gnd --> ground of arduino
TM1637 display has 4 pins CLK, DIO , VCC, GND
CLK --> Pin 2 of arduino
DIO --> Pin 3 of arduino
VCC-->5v
GND-->GND
Download the code from this link and copy-paste in Arduino IDE.
Upload the code to Arduino Uno
Step 2: Put It in a Box
After all connection put them together in a box.
Take a pocket sized box and cut holes for ultrasonic sensor, switch and display.
Switch connection you could see from image.
You could add your own modifications.
Step 3: Product Images and Video
Pocket-Sized Speed Challenge
2 Comments
Question 3 years ago
Where did you get thisTM1637Display.h library from?
Reply 3 years ago
In the Library manager search TM1637 and install TM1637 library by Avishay Orpaz.
