Introduction: Poker Chip Portable Minicase
This Minicase allows the user to not haul around the large heavy case that the poker chips originally came in.
- 1 used toilet paper roll
- 5 x 12-inch piece of poster paper
- Tape
Step 1: Step 1
From the 5x12 poster board paper, on 2 corners cut out a 1 1/4 x 4-inch rectangle.
Step 2: Step 2
Tape the two edges together. This will create a pocket for the chips. If the tape is not strong enough and the paper is causing the tape to fall off, you may need to use tape on the inside also.
Step 3: Step 3
On the side with a full circle, tape the leftover strip of paper to the end and tape it to the cylinder. Make sure it is very strong because it will be supporting the bulk of the weight from the poker chips.
Step 4: Step 4
Get the toilet paper roll and slide it over the cylinder. This will act as a cap for the Minicase. Then you are finished!
