Introduction: Polariod 350 Operation and Battery Modification
this instructable shows you basic operation, cleanup, and a simple battery modification on a polaroid 350 land camera.
Step 1: Materials
CLEANING
1. Q tips
2. paper towels
OPERATION
3. film (for 350 I used Fujifilm fp3000b which is black and white for color use fp100c)
4. AAA batteries (if you use battery mod. if not use the Eveready A24PX)
BATTERY MODIFICATION
5. 2x AAA batter holder
6. soldering iron
7. solder
8. heat shrink tubing or electrical tape
Step 2: Clean-up: Opening Back
open back using the lever at the bottom of the camera
Step 3: Clean-up: Cleaning Rollers
pull red roller release lever and lift rollers. for cleaning use Q tips and paper towels if needed to clean rollers
Step 4: Clean-up: Cleaning Back Lens
well this step seems pretty self explanatory. if there is something that wont come off with the Q tips, use a glasses cleaner and cloth.
Step 5: Clean-up: Left Over Film Chemicals
wipe down the area where the film box goes
Step 6: Clean-up: Open Camera Front
to take cover off lift lip at top and pull down. push clip at bottom of camera in to remove cover. lift view finder. lift tab with arrow on it up and pull front lens out
Step 7: Clean-up: Front Lens
do as you did with back lens. and same with the electronic eye
Step 8: Clean-up: Veiw Finder
wow I don't think you can get a step more self explanatory than that
Step 9: Clean-up: Camera Skirt
wipe down the skirt with Q tips and paper towels
Step 10: Battery Mod: Remove Battery Holder
unscrew the two screws holding the battery holder in and lift out.
Step 11: Battery Mod: Remove Battery Snaps
cut and strip a small portion of wire just behind the snaps
Step 12: Battery Mod: Connect Battery Holder
connect positive end to white and negative to black. solder positive to positive and negative to negative and cover with electrical tape or heat shrink tubing.
Step 13: Battery Mod: Put Holder in Camera.
yet another self explanatory step.
Step 14: Operation: Put Batteries in Camera
well um yeah do that
Step 15: Operation: Load Film
open back of camera and put film cartridge in. DO NOT PULL THE PEICE OF PAPER OVER FILM!!! this will ruin all the film. put the cartridge in the camera and thread the paper through the #4 slot and close the camera.
Step 16: Operation: Load Shutter
push shutter lever (#3) down to load shutter
Step 17: Operation: Lighten/darken Control and Film Speed
set dial to one line towards lighten. on bottom of camera set film speed to correct speed by turning wheel.
Step 18: Operation: Focus
look through view finder and move focus lever to focus on object.
Step 19: Operation: Take Picture
to take picture press shutter release (#2). then reload shutter by pushing #3
Step 20: Operation: Getting Photograph
after shutter button has been pressed pull white tab smoothly then do the same with the black tab. wait recommended time then peel negative from picture.
Step 21: Troubleshooting: Lighten/ Darken
1&2 were both too dark so you adjust lighten/ darken
4. black tab was pulled too slowly or you squeezed camera in the area where you pulled the black tab.
make sure rollers are clean before each use. or you will and up with repeated white lines throughout a photo
DO NOT OPEN CAMERA WITH FILM LOADED
Step 22: Troubleshooting: Picture 3
3. adjust focus
Step 23: Troubleshooting: Picture 4
Step 24: General Stuff
