Introduction: Polyhedric Marbled Candleholder
With this Instructable I will show you step by step how to create
Polyhedric cement marbled candleholders with grey cardboard
and tape.
I have used 1,5mm cardboard because my candleholders
weren`t too big so bare in mind if you want to create a bigger mold
use plexiglas or other stronger material because the cardboard
will bulge under the cement mix.
For the mold :
- Grey cardboard 1,5mm thick.
- Brown cardboard 4,5mm thick.
- Tape.
- Glue.
For modling:
- 5 kg of Cement (grey or white).
- 1 Old tablecloth, preferably plastic.
- 1 Mixing bucket.
- 1 Pair of plastic gloves.
- 1 Old cup.
- Water
- 1 Wood stick.
For marbling :
- 1 Mixing bucket.
- 1 Pair of gloves.
- Marbling colors, (like marabu easy marble).
- Water
Step 1: STEP 1 : Prepare Your Template
For the geometric candleholder you have to cut out the template on
your grey cardboard and also lightly cut where you are going to fold
the sides.
Personally I have used a lasercutter for this step but you can also do it by hand.
- Remove parts of your polyhedra as shown in the picture (black stripes)
and then prep both sides with tape to make it waterproof.
- Remove the top part of your mold and retape the edges.
Step 2: STEP 2 : Prep the "STUMP"
I wanted to use 40 mm wide candles so I had to create a
cylinder to make the cavity for the candle.
- You will want to make your cylinder about 42mm wide and
also 5mm taller than the candle.
- Use brown 4,5 mm thick cardboard In order to be able to remove
the stump from the cement.
- Tape all the sides.
Step 3: STEP 3 : Put the Pieces Together
Because the candleholder is going to me molded "upside down"
you have to cut out a piece of grey cardboard the size of the opening
of your mold.
Again you will have to tape both sides to make if waterproof.
- Place the cylinder in the middle of the cut out pentagon and glue or
tape it down.
This will prevent the cylinder to bob to the surface and makes the finishes
easier.
YOU ARE NOW READY TO MIX THE CEMENT !!!
Step 4: STEP 4 : Prep Prep Prep....
You will really want to protect everything you can from your
cement mix, you are going to need :
- 1 Mixing bucket.
- 1 Old cup.
- Water
- 1 Wood stick.
- Measure 1 unit of cement and mix in 1 unit of water at the
beginning slowly to avoid clumps and to get to a thick pancake
consistency. If you have to adjust by adding water or cement.
- Mix all well with the stick and if needed with a gloved hand to remove
eventual lumps. Gently tap tap your mold to remove airbubbles and
let it rest.
Step 5: STEP 5 : UN-mold and Sanding
Your candleholders will have to rest for about 24 hours to fully
set.
-Personally I unmolded them 12-14 hours after I poured the
cement to be able to remove some exess cement with a cutter.
- After 24 hours you can sand your candleholders, use
first rough and then finesanding paper.
I sanded the bare minimum because I wanted to keep the
textures created by the tape from the mold.
Step 6: STEP 6 : the Marbling
For the marbling you will need :
- 1 Mixing bucket.
- 1 Pair of gloves.
- Water.
- Wooden sticks
- Fill up the bucket with water and drop the marbling color onto
the waters surface and make swirls with a wooden stick.
-When you are satisfied with your design take your candleholders
and dip them into the water. The color will stick to the cement.
-The outcome of your design will depend on how you place the
candleholder onto the color aka . dip, let it fall, dip and swril etc.
Step 7: STEP 7 : Sit Back and Enjoy
You are done and can finally rejoice in your hard work !!!
As you can see the shape of the candleholders can wary
which will make them unique and a perfect present for
family and friends.
How about making a flower pot now?
