Polymer Bar Pendant
15,541
188
14
Featured
Introduction: Polymer Bar Pendant
This pendant is simple to make using only a few tools and a couple materials.
Needed:
File divider
Polymer Clay
Pliers
Hammer
Drill & drill bit
Sand paper
Soldering paste
Silver solder
Heat source
Step 1: Another Use for a File Divider
Cut out the strip to a file divider. Use a pair of pliers to bend the end at 90 degrees. Make sure the bend is squarely bent.
Move down the metal strip until you reach your desired length. Bend both ends down at 90 degrees until you have a rectangle. Cut the free end as flush as you can to the pendant.
Step 2: Solder and Drill
Apply soldering pasted to the joint. Add a little piece of silver solder. Apply heat until it’s joined.
Place the rectangle back onto the pliers and use a punch to make a starting mark for the drill bit. Do this on both sides. Drill a hole and keep the drill bit handy.
Step 3: Polish
Wrap sand paper around a drill bit and spin it round. Use this improvised sander to polish the pendant. Use a buffing wheel to further polish.
Step 4: Fill and Bake
Fill the pendant with polymer clay. Place a plastic bag over the pendant and use a rolling pin to roll out the excess clay. Place the drill bit into the drilled hole while you fill it.
Bake the pendant following the instructions for the clay.
14 Comments
9 years ago on Introduction
I love that you used a file folder. There are so many of those deserted at my work.
9 years ago on Step 4
Love the look of this one, sort of modern. Does the clay bake to a shiny finish, or did you polish it more after baking?
10 years ago on Step 4
And he does it again!
10 years ago on Introduction
Gosh this pendant is really classy
Wonderfull idea! Thanks for posting it.
Very very nice. I really liked that you got the metal part from a file divider, that's a big high-five for taking something ordinary and making it into something beautiful.
Inspired I am.
There is so much crap (material) that is thrown out where I work that I have pendants dancin' in my head.
Good pictures, to-the-point instructions.
Top Notch, Yo.
Fantastic. Beautiful piece, easy instructions, and wonderful upcycling!
Nice 'ible. Very simple in practice, but kudos for getting the metalwork part done so easily, and for recylcing used things :)
Cheers,
Daniel
Reply 10 years ago on Step 4
Thanks
I think you forgot in the "Needed" items list:
Soldering paste, silver solder and a heat source.
And kind sir, once again you came up with something astoundingly beautiful and simply elegant with common "ordinary" things.
Thanks and fixed.
Very simple, but effective.
Very cool. You have an amazing imagination! I love the result. ;)
