Introduction: Pontoon Boat Picnic Table
a great way to enjoy a day on the lake
Step 1: Cutting and Shaping Foam
I started off with 2 inch 4x8ft sheets of foam board and cut them into thirds then glued them together with glidden gripper exterior paint. making sure to stay about 2inches away from all edges so it didn't interfere with the hot wire cutter
Step 2: Extra Support and Rub Rail
I added a 2x4 on the bottom of the hull of each pontoon to take the majority of the abuse. also to strengthen and give me a point to bolt each pontoon to the picnic table
Step 3:
I added more foam on the sides of the pontoons as well as a built-in cooler on one and a dry storage in the other by means of a bucket and lid
Step 4: Motor Mount
I used 1/2" gas pipe and angle iron to build a motor mount
Step 5: Fiberglassing
I put 2 layers of fiberglass and finished it with a T-shirt material
Step 6: Attaching the Pontoons
each pontoon is attached with threaded rod from the bottom all the way threw the pontoon and into the bench supports of the seat
Step 7: Attaching the Motor and Steering
the motor is a Johnson 9.9 and I made my own brackets and ran and designed my own steering from a dolly rim attached to a playground captains wheel. next is throttle and forward and reverse cables and levers and add an umbrella and lights and it's ready for the water
