Introduction: Poor Man's AVR Music Box
This is a simple AVR music box, costing about 10$ to build.
DISCLAIMER: This project is what you would call a SMOP, a "simple matter of programming". That means it is of trivial complexity but lengthy... so unless you can tolerate boredom to the extent where it borders self-annihilation, you will find this painful to work on.
Knowledge of assembly language, basic electronics, and microcontrollers is assumed. This isn't simple, but it's not rocket surgery either.
The music box has 4 stages: Song storage, Sound generation, Amplification and Power.
It can produce a full 8 octaves of square wave music, that's just under 100 notes on a logarithmic scale from 5 kilohertz to just under 20 hertz. The quality is approximately that of old game consoles or the very first midi sound cards.
Sound generation:
There isn't that much to describe. It accepts parallel port input through PORTB, and outputs a variable frequency square wave on PORTA, PIN1. Runs on a attiny26l-8pu, at 1Mhz. Doubling clock speed raises notes an octave higher, useful if you've made a miscalculation, like I did (I doubled it to 2Mhz, the final song sounded much better).
Low power consumption and simplicity were paramount in this project, that is why I didn't design some sort of serial/parallel DAC to give me proper sine wave output. I also wasn't willing to trash an mp3 player (the other design option for this project) for something I could do adequately with 10$ worth of parts.
It is designed such that a second AVR sits right next to it, and contains the song information.
Song Storage:
An atmega16 @4Mhz sends 8-bit numbers out it's PORTA for set durations, each number corresponding to a note on the other AVR... basically the simplest possible sound format, there's not even volume control right now, but if I did add it I would use PORTB on the "song info" chip to give me 8 levels of volume, each pin raised high would cause the "song interpreter" chip to use an additional pin as output. They'd all connect to an opamp through a resistor network, such that more pins--> more voltage on the amp input.
I originally used another attiny26l-8pu for song storage, but the memory (2k) was not sufficient for the song of 313 notes (~2800 lines of code). The only working chip I had lying about unused was an atmega16.
Amplification:
A two stage amplifier was constructed using 2x N2222 NPN transistors (darlington pair). It sends output to a piezo buzzer. I noticed some buzzers worked, others did not... headphones/speakers always worked.
Deep magic: if you connect pin0, port A to the base of the first transistor in the darlington pair, you get audio output. If you ALSO connect pin7 to the first stage of the darlington pair, the ouput becomes VERY LOUD. I suspect I accidentally defined pin 7 as the output in the source... but the darlington pair is sensitive enough to pick up some leakage somewhere and it still works fine but a little quietly. I ended up connecting the first stage of the darlington pair to pin0, and the second stage to both the output of the first stage and PIN7. This produced the optimal volume for my purposes. See edit in the first source code file, near the start.
Power:
Nothing fancy here. A 9v battery and a TL780 voltage regulator.
Sound generation:
Song Storage:
Amplification:
Power:
Step 1: Source Code, Sound Generation
START:
.INCLUDE "tn26def.inc"
clr r23
clr r24
clr r25
clr r26
clr r27
clr r28
clr r29
clr r30
clr r31
ldi r25, 0b10000000 ;here is where I defined the wrong output pin... It shoud be
ldi r26, 0b00000000 ; 0b00000001 I think. Just use 0b11111111 for testing if unsure.
out DDRA, r25
nop
out PORTA, r26
nop
out DDRB, r26
nop
INPUT:
;96 notes possible, plus silence (zero)
out PORTA, r26 ;Silence if no input
nop
in r28, PINB
mov r31, r28
cpi r28, 0b00000000
breq INPUT
D8S:
;5.1khz
cpi r28, 0b00000001
brne D8
ldi r29, 0b00010000
ldi r30, 0b00000001
D8:
;4.63khz
cpi r28, 0b00000010
brne C8S
ldi r29, 0b00010010
ldi r30, 0b00000001
C8S:
;4.42khz
cpi r28, 0b00000011
brne C8
ldi r29, 0b00010011
ldi r30, 0b00000001
C8:
;4.24khz
cpi r28, 0b00000100
brne B7
ldi r29, 0b00010100
ldi r30, 0b00000001
rjmp B7
INPUT91:
rjmp INPUT
B7:
;3.91khz
cpi r28, 0b00000101
brne A7S
ldi r29, 0b00010110
ldi r30, 0b00000001
A7S:
;3.70khz
cpi r28, 0b00000110
brne A7
ldi r29, 0b00010111
ldi r30, 0b00000001
A7:
;3.57khz
cpi r28, 0b00000111
brne G7
ldi r29, 0b00011001
ldi r30, 0b00000001
G7:
;3.13khz
cpi r28, 0b00001000
brne F7S
ldi r29, 0b00011010
ldi r30, 0b00000001
F7S:
;2.94khz
cpi r28, 0b00001001
brne F7
ldi r29, 0b00011110
ldi r30, 0b00000001
F7:
;2.78khz
cpi r28, 0b00001010
brne E7
ldi r29, 0b00100000
ldi r30, 0b00000001
E7:
;2.63khz
cpi r28, 0b00001011
brne D7S
ldi r29, 0b00100010
ldi r30, 0b00000001
D7S:
;2.50khz
cpi r28, 0b00001100
brne D7
ldi r29, 0b00100101
ldi r30, 0b00000001
D7:
;2.33khz
cpi r28, 0b00001101
brne C7S
ldi r29, 0b00100111
ldi r30, 0b00000001
C7S:
;2.22khz
cpi r28, 0b00001110
brne C7
ldi r29, 0b00101010
ldi r30, 0b00000001
C7:
;2.08khz
cpi r28, 0b00001111
brne B6
ldi r29, 0b00101100
ldi r30, 0b00000001
rjmp B6
INPUT92:
rjmp INPUT91
B6:
;1.96khz
cpi r28, 0b00010000
brne A6S
ldi r29, 0b00101111
ldi r30, 0b00000001
A6S:
;1.85khz
cpi r28, 0b00010001
brne A6
ldi r29, 0b00110010
ldi r30, 0b00000001
A6:
;1.75khz
cpi r28, 0b00010010
brne G6S
ldi r29, 0b00110101
ldi r30, 0b00000001
G6S:
;1.67khz
cpi r28, 0b00010011
brne G6
ldi r29, 0b00111001
ldi r30, 0b00000001
G6:
;1.56khz
cpi r28, 0b00010100
brne F6S
ldi r29, 0b00111100
ldi r30, 0b00000001
F6S:
;1.47khz
cpi r28, 0b00010101
brne F6
ldi r29, 0b01000000
ldi r30, 0b00000001
F6:
;1.39khz
cpi r28, 0b00010110
brne E6
ldi r29, 0b01000100
ldi r30, 0b00000001
E6:
;1.32khz
cpi r28, 0b00010111
brne D6S
ldi r29, 0b01001000
ldi r30, 0b00000001
D6S:
;1.25khz
cpi r28, 0b00011000
brne D6
ldi r29, 0b01001101
ldi r30, 0b00000001
D6:
;1.18khz
cpi r28, 0b00011001
brne C6S
ldi r29, 0b01010010
ldi r30, 0b00000001
C6S:
;1.11khz
cpi r28, 0b00011010
brne C6
ldi r29, 0b01010111
ldi r30, 0b00000001
C6:
;1.04khz
cpi r28, 0b00011011
brne B5
ldi r29, 0b01011100
ldi r30, 0b00000001
rjmp B5
INPUT93:
rjmp INPUT92
B5:
;990Hz
cpi r28, 0b00011100
brne A5S
ldi r29, 0b01100010
ldi r30, 0b00000001
A5S:
;935Hz
cpi r28, 0b00011101
brne A5
ldi r29, 0b01101000
ldi r30, 0b00000001
A5:
;877Hz
cpi r28, 0b00011110
brne G5S
ldi r29, 0b01101110
ldi r30, 0b00000001
G5S:
;833Hz
cpi r28, 0b00011111
brne G5
ldi r29, 0b01110101
ldi r30, 0b00000001
G5:
;781Hz
cpi r28, 0b00100000
brne F5S
ldi r29, 0b01111100
ldi r30, 0b00000001
F5S:
;741Hz
cpi r28, 0b00100001
brne F5
ldi r29, 0b10000100
ldi r30, 0b00000001
F5:
;699Hz
cpi r28, 0b00100010
brne E5
ldi r29, 0b10001100
ldi r30, 0b00000001
E5:
;658Hz
cpi r28, 0b00100011
brne D5S
ldi r29, 0b10010100
ldi r30, 0b00000001
D5S:
;621Hz
cpi r28, 0b00100100
brne D5
ldi r29, 0b10011101
ldi r30, 0b00000001
D5:
;588Hz
cpi r28, 0b00100101
brne C5S
ldi r29, 0b10100111
ldi r30, 0b00000001
C5S:
;555Hz
cpi r28, 0b00100110
brne C5
ldi r29, 0b10110001
ldi r30, 0b00000001
C5:
;524Hz
cpi r28, 0b00100111
brne B4
ldi r29, 0b10111100
ldi r30, 0b00000001
rjmp B4
INPUT94:
rjmp INPUT93
B4:
cpi r28, 0b00101000
brne A4S
ldi r29, 0b11000111
ldi r30, 0b00000001
A4S:
cpi r28, 0b00101001
brne A4
ldi r29, 0b11010011
ldi r30, 0b00000001
A4:
cpi r28, 0b00101010
brne G4S
ldi r29, 0b11100000
ldi r30, 0b00000001
G4S:
cpi r28, 0b00101011
brne G4
ldi r29, 0b11101101
ldi r30, 0b00000001
G4:
cpi r28, 0b00101100
brne F4S
ldi r29, 0b11111100
ldi r30, 0b00000001
F4S:
cpi r28, 0b00101101
brne F4
ldi r29, 0b00101011
ldi r30, 0b00000101
F4:
cpi r28, 0b00101110
brne E4
ldi r29, 0b00101101
ldi r30, 0b00000101
E4:
cpi r28, 0b00101111
brne D4S
ldi r29, 0b00110000
ldi r30, 0b00000101
D4S:
cpi r28, 0b00110000
brne D4
ldi r29, 0b00110011
ldi r30, 0b00000101
D4:
cpi r28, 0b00110001
brne C4S
ldi r29, 0b00110110
ldi r30, 0b00000101
C4S:
cpi r28, 0b00110010
brne C4
ldi r29, 0b00111010
ldi r30, 0b00000101
C4:
cpi r28, 0b00110011
brne B3
ldi r29, 0b00111101
ldi r30, 0b00000101
rjmp B3
INPUT95:
rjmp INPUT94
B3:
cpi r28, 0b00110100
brne A3S
ldi r29, 0b01000001
ldi r30, 0b00000101
A3S:
cpi r28, 0b00110101
brne A3
ldi r29, 0b01000101
ldi r30, 0b00000101
A3:
cpi r28, 0b00110110
brne G3S
ldi r29, 0b01001001
ldi r30, 0b00000101
G3S:
cpi r28, 0b00110111
brne G3
ldi r29, 0b01001110
ldi r30, 0b00000101
G3:
cpi r28, 0b00111000
brne F3S
ldi r29, 0b01010011
ldi r30, 0b00000101
F3S:
cpi r28, 0b00111001
brne F3
ldi r29, 0b01011000
ldi r30, 0b00000101
F3:
cpi r28, 0b00111010
brne E3
ldi r29, 0b01011101
ldi r30, 0b00000101
E3:
cpi r28, 0b00111011
brne D3S
ldi r29, 0b01100011
ldi r30, 0b00000101
D3S:
cpi r28, 0b00111100
brne D3
ldi r29, 0b01101000
ldi r30, 0b00000101
D3:
cpi r28, 0b00111101
brne C3S
ldi r29, 0b01101111
ldi r30, 0b00000101
C3S:
cpi r28, 0b00111110
brne C3
ldi r29, 0b01110101
ldi r30, 0b00000101
C3:
cpi r28, 0b01111111
brne B2
ldi r29, 0b01111101
ldi r30, 0b00000101
rjmp B2
INPUT96:
rjmp INPUT95
B2:
cpi r28, 0b01000000
brne A2S
ldi r29, 0b10000101
ldi r30, 0b00000101
A2S:
cpi r28, 0b01000001
brne A2
ldi r29, 0b10001101
ldi r30, 0b00000101
A2:
cpi r28, 0b01000010
brne G2S
ldi r29, 0b10010101
ldi r30, 0b00000101
G2S:
cpi r28, 0b01000011
brne G2
ldi r29, 0b10011110
ldi r30, 0b00000101
G2:
cpi r28, 0b01000100
brne F2S
ldi r29, 0b10101000
ldi r30, 0b00000101
F2S:
cpi r28, 0b01000101
brne F2
ldi r29, 0b10110010
ldi r30, 0b00000101
F2:
cpi r28, 0b01000110
brne E2
ldi r29, 0b10111100
ldi r30, 0b00000101
E2:
cpi r28, 0b01000111
brne D2S
ldi r29, 0b11001000
ldi r30, 0b00000101
D2S:
cpi r28, 0b01001000
brne D2
ldi r29, 0b11010100
ldi r30, 0b00000101
D2:
cpi r28, 0b01001001
brne C2S
ldi r29, 0b11100001
ldi r30, 0b00000101
C2S:
cpi r28, 0b01001010
brne C2
ldi r29, 0b11101110
ldi r30, 0b00000101
C2:
cpi r28, 0b01001011
brne B1
ldi r29, 0b11111100
ldi r30, 0b00000101
rjmp B1
INPUT97:
rjmp INPUT96
B1:
cpi r28, 0b01001011
brne A1S
ldi r29, 0b00111111
ldi r30, 0b00011001
A1S:
cpi r28, 0b01001100
brne A1
ldi r29, 0b01000010
ldi r30, 0b00011001
A1:
cpi r28, 0b01001101
brne G1S
ldi r29, 0b01000110
ldi r30, 0b00011001
G1S:
cpi r28, 0b01001110
brne G1
ldi r29, 0b01001011
ldi r30, 0b00011001
G1:
cpi r28, 0b01001111
brne F1S
ldi r29, 0b01001111
ldi r30, 0b00011001
F1S:
cpi r28, 0b01010000
brne F1
ldi r29, 0b01010100
ldi r30, 0b00011001
F1:
cpi r28, 0b01010001
brne E1
ldi r29, 0b01011001
ldi r30, 0b00011001
E1:
cpi r28, 0b01010010
brne D1S
ldi r29, 0b01011111
ldi r30, 0b00011001
D1S:
cpi r28, 0b01010011
brne D1
ldi r29, 0b01100101
ldi r30, 0b00011001
D1:
cpi r28, 0b01010100
brne C1S
ldi r29, 0b01101011
ldi r30, 0b00011001
C1S:
cpi r28, 0b01010101
brne C1
ldi r29, 0b01110001
ldi r30, 0b00011001
C1:
cpi r28, 0b01010110
brne B0
ldi r29, 0b01111000
ldi r30, 0b00011001
rjmp B0
INPUT98:
rjmp INPUT97
B0:
cpi r28, 0b01010111
brne A0S
ldi r29, 0b01111111
ldi r30, 0b00011001
A0S:
cpi r28, 0b01011000
brne A0
ldi r29, 0b10000111
ldi r30, 0b00011001
A0:
cpi r28, 0b01011001
brne G0S
ldi r29, 0b10001111
ldi r30, 0b00011001
G0S:
cpi r28, 0b01011010
brne G0
ldi r29, 0b10011000
ldi r30, 0b00011001
G0:
cpi r28, 0b01011011
brne F0S
ldi r29, 0b10100001
ldi r30, 0b00011001
F0S:
cpi r28, 0b01011100
brne F0
ldi r29, 0b10101011
ldi r30, 0b00011001
F0:
cpi r28, 0b01011101
brne E0
ldi r29, 0b10110101
ldi r30, 0b00011001
E0:
cpi r28, 0b01011110
brne D0S
ldi r29, 0b11000000
ldi r30, 0b00011001
D0S:
cpi r28, 0b01011111
brne D0
ldi r29, 0b11001011
ldi r30, 0b00011001
D0:
cpi r28, 0b01100000
brne C0S
ldi r29, 0b11011000
ldi r30, 0b00011001
C0S:
cpi r28, 0b01100001
brne C0
ldi r29, 0b11100101
ldi r30, 0b00011001
C0:
cpi r28, 0b01100010
brne hi
ldi r29, 0b11110010
ldi r30, 0b00011001
rjmp hi
INPUT99:
rjmp INPUT98
hi:
out PORTA, r25
clr r27
nop ;To compensate for INPUT1 function, making hi/lo equal lengths
nop
nop
nop
nop
TIMER0h: ;5 cpu cycles per count
inc r24
nop
cp r24,r29
brne TIMER0h
rjmp TIMER1h
TIMER1h: ;6 cpu cycles per count
clr r24
inc r27
cp r27, r30
nop
brne TIMER0h
rjmp lo
lo:
out PORTA, r26
clr r27
TIMER0l: ;5 cpu cycles per count
inc r24
nop
cp r24,r29
brne TIMER0l
rjmp TIMER1l
TIMER1l: ;6 cpu cycles per count
inc r27
nop
clr r24
cp r27,r30
brne TIMER0l
rjmp INPUT1
INPUT1: ;Check to see if input has changed, if not, continue output
in r28,PINB ;5 cycles in this function
cp r28, r31
brne INPUT99
rjmp hi
clr r23
clr r24
clr r25
clr r26
clr r27
clr r28
clr r29
clr r30
clr r31
out DDRA, r25
nop
out PORTA, r26
nop
out DDRB, r26
nop
INPUT:
nop
in r28, PINB
mov r31, r28
cpi r28, 0b00000000
breq INPUT
D8S:
;5.1khz
cpi r28, 0b00000001
brne D8
ldi r29, 0b00010000
ldi r30, 0b00000001
D8:
;4.63khz
cpi r28, 0b00000010
brne C8S
ldi r29, 0b00010010
ldi r30, 0b00000001
C8S:
;4.42khz
cpi r28, 0b00000011
brne C8
ldi r29, 0b00010011
ldi r30, 0b00000001
C8:
;4.24khz
cpi r28, 0b00000100
brne B7
ldi r29, 0b00010100
ldi r30, 0b00000001
rjmp B7
INPUT91:
rjmp INPUT
B7:
;3.91khz
cpi r28, 0b00000101
brne A7S
ldi r29, 0b00010110
ldi r30, 0b00000001
A7S:
;3.70khz
cpi r28, 0b00000110
brne A7
ldi r29, 0b00010111
ldi r30, 0b00000001
A7:
;3.57khz
cpi r28, 0b00000111
brne G7
ldi r29, 0b00011001
ldi r30, 0b00000001
G7:
;3.13khz
cpi r28, 0b00001000
brne F7S
ldi r29, 0b00011010
ldi r30, 0b00000001
F7S:
;2.94khz
cpi r28, 0b00001001
brne F7
ldi r29, 0b00011110
ldi r30, 0b00000001
F7:
;2.78khz
cpi r28, 0b00001010
brne E7
ldi r29, 0b00100000
ldi r30, 0b00000001
E7:
;2.63khz
cpi r28, 0b00001011
brne D7S
ldi r29, 0b00100010
ldi r30, 0b00000001
D7S:
;2.50khz
cpi r28, 0b00001100
brne D7
ldi r29, 0b00100101
ldi r30, 0b00000001
D7:
;2.33khz
cpi r28, 0b00001101
brne C7S
ldi r29, 0b00100111
ldi r30, 0b00000001
C7S:
;2.22khz
cpi r28, 0b00001110
brne C7
ldi r29, 0b00101010
ldi r30, 0b00000001
C7:
;2.08khz
cpi r28, 0b00001111
brne B6
ldi r29, 0b00101100
ldi r30, 0b00000001
rjmp B6
INPUT92:
rjmp INPUT91
B6:
;1.96khz
cpi r28, 0b00010000
brne A6S
ldi r29, 0b00101111
ldi r30, 0b00000001
A6S:
;1.85khz
cpi r28, 0b00010001
brne A6
ldi r29, 0b00110010
ldi r30, 0b00000001
A6:
;1.75khz
cpi r28, 0b00010010
brne G6S
ldi r29, 0b00110101
ldi r30, 0b00000001
G6S:
;1.67khz
cpi r28, 0b00010011
brne G6
ldi r29, 0b00111001
ldi r30, 0b00000001
G6:
;1.56khz
cpi r28, 0b00010100
brne F6S
ldi r29, 0b00111100
ldi r30, 0b00000001
F6S:
;1.47khz
cpi r28, 0b00010101
brne F6
ldi r29, 0b01000000
ldi r30, 0b00000001
F6:
;1.39khz
cpi r28, 0b00010110
brne E6
ldi r29, 0b01000100
ldi r30, 0b00000001
E6:
;1.32khz
cpi r28, 0b00010111
brne D6S
ldi r29, 0b01001000
ldi r30, 0b00000001
D6S:
;1.25khz
cpi r28, 0b00011000
brne D6
ldi r29, 0b01001101
ldi r30, 0b00000001
D6:
;1.18khz
cpi r28, 0b00011001
brne C6S
ldi r29, 0b01010010
ldi r30, 0b00000001
C6S:
;1.11khz
cpi r28, 0b00011010
brne C6
ldi r29, 0b01010111
ldi r30, 0b00000001
C6:
;1.04khz
cpi r28, 0b00011011
brne B5
ldi r29, 0b01011100
ldi r30, 0b00000001
rjmp B5
INPUT93:
rjmp INPUT92
B5:
;990Hz
cpi r28, 0b00011100
brne A5S
ldi r29, 0b01100010
ldi r30, 0b00000001
A5S:
;935Hz
cpi r28, 0b00011101
brne A5
ldi r29, 0b01101000
ldi r30, 0b00000001
A5:
;877Hz
cpi r28, 0b00011110
brne G5S
ldi r29, 0b01101110
ldi r30, 0b00000001
G5S:
;833Hz
cpi r28, 0b00011111
brne G5
ldi r29, 0b01110101
ldi r30, 0b00000001
G5:
;781Hz
cpi r28, 0b00100000
brne F5S
ldi r29, 0b01111100
ldi r30, 0b00000001
F5S:
;741Hz
cpi r28, 0b00100001
brne F5
ldi r29, 0b10000100
ldi r30, 0b00000001
F5:
;699Hz
cpi r28, 0b00100010
brne E5
ldi r29, 0b10001100
ldi r30, 0b00000001
E5:
;658Hz
cpi r28, 0b00100011
brne D5S
ldi r29, 0b10010100
ldi r30, 0b00000001
D5S:
;621Hz
cpi r28, 0b00100100
brne D5
ldi r29, 0b10011101
ldi r30, 0b00000001
D5:
;588Hz
cpi r28, 0b00100101
brne C5S
ldi r29, 0b10100111
ldi r30, 0b00000001
C5S:
;555Hz
cpi r28, 0b00100110
brne C5
ldi r29, 0b10110001
ldi r30, 0b00000001
C5:
;524Hz
cpi r28, 0b00100111
brne B4
ldi r29, 0b10111100
ldi r30, 0b00000001
rjmp B4
INPUT94:
rjmp INPUT93
B4:
cpi r28, 0b00101000
brne A4S
ldi r29, 0b11000111
ldi r30, 0b00000001
A4S:
cpi r28, 0b00101001
brne A4
ldi r29, 0b11010011
ldi r30, 0b00000001
A4:
cpi r28, 0b00101010
brne G4S
ldi r29, 0b11100000
ldi r30, 0b00000001
G4S:
cpi r28, 0b00101011
brne G4
ldi r29, 0b11101101
ldi r30, 0b00000001
G4:
cpi r28, 0b00101100
brne F4S
ldi r29, 0b11111100
ldi r30, 0b00000001
F4S:
cpi r28, 0b00101101
brne F4
ldi r29, 0b00101011
ldi r30, 0b00000101
F4:
cpi r28, 0b00101110
brne E4
ldi r29, 0b00101101
ldi r30, 0b00000101
E4:
cpi r28, 0b00101111
brne D4S
ldi r29, 0b00110000
ldi r30, 0b00000101
D4S:
cpi r28, 0b00110000
brne D4
ldi r29, 0b00110011
ldi r30, 0b00000101
D4:
cpi r28, 0b00110001
brne C4S
ldi r29, 0b00110110
ldi r30, 0b00000101
C4S:
cpi r28, 0b00110010
brne C4
ldi r29, 0b00111010
ldi r30, 0b00000101
C4:
cpi r28, 0b00110011
brne B3
ldi r29, 0b00111101
ldi r30, 0b00000101
rjmp B3
INPUT95:
rjmp INPUT94
B3:
cpi r28, 0b00110100
brne A3S
ldi r29, 0b01000001
ldi r30, 0b00000101
A3S:
cpi r28, 0b00110101
brne A3
ldi r29, 0b01000101
ldi r30, 0b00000101
A3:
cpi r28, 0b00110110
brne G3S
ldi r29, 0b01001001
ldi r30, 0b00000101
G3S:
cpi r28, 0b00110111
brne G3
ldi r29, 0b01001110
ldi r30, 0b00000101
G3:
cpi r28, 0b00111000
brne F3S
ldi r29, 0b01010011
ldi r30, 0b00000101
F3S:
cpi r28, 0b00111001
brne F3
ldi r29, 0b01011000
ldi r30, 0b00000101
F3:
cpi r28, 0b00111010
brne E3
ldi r29, 0b01011101
ldi r30, 0b00000101
E3:
cpi r28, 0b00111011
brne D3S
ldi r29, 0b01100011
ldi r30, 0b00000101
D3S:
cpi r28, 0b00111100
brne D3
ldi r29, 0b01101000
ldi r30, 0b00000101
D3:
cpi r28, 0b00111101
brne C3S
ldi r29, 0b01101111
ldi r30, 0b00000101
C3S:
cpi r28, 0b00111110
brne C3
ldi r29, 0b01110101
ldi r30, 0b00000101
C3:
cpi r28, 0b01111111
brne B2
ldi r29, 0b01111101
ldi r30, 0b00000101
rjmp B2
INPUT96:
rjmp INPUT95
B2:
cpi r28, 0b01000000
brne A2S
ldi r29, 0b10000101
ldi r30, 0b00000101
A2S:
cpi r28, 0b01000001
brne A2
ldi r29, 0b10001101
ldi r30, 0b00000101
A2:
cpi r28, 0b01000010
brne G2S
ldi r29, 0b10010101
ldi r30, 0b00000101
G2S:
cpi r28, 0b01000011
brne G2
ldi r29, 0b10011110
ldi r30, 0b00000101
G2:
cpi r28, 0b01000100
brne F2S
ldi r29, 0b10101000
ldi r30, 0b00000101
F2S:
cpi r28, 0b01000101
brne F2
ldi r29, 0b10110010
ldi r30, 0b00000101
F2:
cpi r28, 0b01000110
brne E2
ldi r29, 0b10111100
ldi r30, 0b00000101
E2:
cpi r28, 0b01000111
brne D2S
ldi r29, 0b11001000
ldi r30, 0b00000101
D2S:
cpi r28, 0b01001000
brne D2
ldi r29, 0b11010100
ldi r30, 0b00000101
D2:
cpi r28, 0b01001001
brne C2S
ldi r29, 0b11100001
ldi r30, 0b00000101
C2S:
cpi r28, 0b01001010
brne C2
ldi r29, 0b11101110
ldi r30, 0b00000101
C2:
cpi r28, 0b01001011
brne B1
ldi r29, 0b11111100
ldi r30, 0b00000101
rjmp B1
INPUT97:
rjmp INPUT96
B1:
cpi r28, 0b01001011
brne A1S
ldi r29, 0b00111111
ldi r30, 0b00011001
A1S:
cpi r28, 0b01001100
brne A1
ldi r29, 0b01000010
ldi r30, 0b00011001
A1:
cpi r28, 0b01001101
brne G1S
ldi r29, 0b01000110
ldi r30, 0b00011001
G1S:
cpi r28, 0b01001110
brne G1
ldi r29, 0b01001011
ldi r30, 0b00011001
G1:
cpi r28, 0b01001111
brne F1S
ldi r29, 0b01001111
ldi r30, 0b00011001
F1S:
cpi r28, 0b01010000
brne F1
ldi r29, 0b01010100
ldi r30, 0b00011001
F1:
cpi r28, 0b01010001
brne E1
ldi r29, 0b01011001
ldi r30, 0b00011001
E1:
cpi r28, 0b01010010
brne D1S
ldi r29, 0b01011111
ldi r30, 0b00011001
D1S:
cpi r28, 0b01010011
brne D1
ldi r29, 0b01100101
ldi r30, 0b00011001
D1:
cpi r28, 0b01010100
brne C1S
ldi r29, 0b01101011
ldi r30, 0b00011001
C1S:
cpi r28, 0b01010101
brne C1
ldi r29, 0b01110001
ldi r30, 0b00011001
C1:
cpi r28, 0b01010110
brne B0
ldi r29, 0b01111000
ldi r30, 0b00011001
rjmp B0
INPUT98:
rjmp INPUT97
B0:
cpi r28, 0b01010111
brne A0S
ldi r29, 0b01111111
ldi r30, 0b00011001
A0S:
cpi r28, 0b01011000
brne A0
ldi r29, 0b10000111
ldi r30, 0b00011001
A0:
cpi r28, 0b01011001
brne G0S
ldi r29, 0b10001111
ldi r30, 0b00011001
G0S:
cpi r28, 0b01011010
brne G0
ldi r29, 0b10011000
ldi r30, 0b00011001
G0:
cpi r28, 0b01011011
brne F0S
ldi r29, 0b10100001
ldi r30, 0b00011001
F0S:
cpi r28, 0b01011100
brne F0
ldi r29, 0b10101011
ldi r30, 0b00011001
F0:
cpi r28, 0b01011101
brne E0
ldi r29, 0b10110101
ldi r30, 0b00011001
E0:
cpi r28, 0b01011110
brne D0S
ldi r29, 0b11000000
ldi r30, 0b00011001
D0S:
cpi r28, 0b01011111
brne D0
ldi r29, 0b11001011
ldi r30, 0b00011001
D0:
cpi r28, 0b01100000
brne C0S
ldi r29, 0b11011000
ldi r30, 0b00011001
C0S:
cpi r28, 0b01100001
brne C0
ldi r29, 0b11100101
ldi r30, 0b00011001
C0:
cpi r28, 0b01100010
brne hi
ldi r29, 0b11110010
ldi r30, 0b00011001
rjmp hi
INPUT99:
rjmp INPUT98
hi:
out PORTA, r25
clr r27
nop
nop
nop
nop
inc r24
nop
cp r24,r29
brne TIMER0h
rjmp TIMER1h
clr r24
inc r27
cp r27, r30
nop
brne TIMER0h
rjmp lo
lo:
out PORTA, r26
clr r27
inc r24
nop
cp r24,r29
brne TIMER0l
rjmp TIMER1l
inc r27
nop
clr r24
cp r27,r30
brne TIMER0l
rjmp INPUT1
cp r28, r31
brne INPUT99
rjmp hi
Step 2: Source Code Explained
The program flows as follows:
Start:
Clear registers
Set data direction on ports of interest
Loop0:
if no input, produce no output
if input, continue
Note0:
is input=note0?
if so, load values into timer registers that let the output functions produce the correct square wave frequency
if not, continue
(Produce a NoteX loop for every possible note over 8 octaves)
Hi:
raise output high (1)
timerhi:
defines how long the output stays high
lo:
Render output to low (0)
timerlo:
defines how long the output stays low (0)
input:
check to see if the input has changed
if so, use dirty tricks to get back to loop0
if not, go to hi
There are many "rjmp islands" that let the program return to the start... this microcontroller does not support the jmp opcode, and rjmp can only bring you to a function within a distance of a certain number of instructions. We solve this by "seeding" the program with rjmp statements that are skipped on the way "down" to program, but can be used to climb back up to the program start.
BUG WARNING: Somewhere 3/4 the way down the scale, there is a cluster of a few (3-4) notes that aren't quite right. Out of the 3 values used for r30, I suspect the highest one used is incorrect (too low), I probably miscalculated the number of clock cycles somewhere, or perhaps put a wrong value for r29 somewhere... I'm just going to work around it, fix it if you like (and tell me where the mistake was!)
INEFFICIENCY WARNING: I know, I could have just used PWM and some EEPROM table, but by the time I thought of it, it was already working this way.
Start:
Clear registers
Loop0:
if input, continue
Note0:
is input=note0?
if not, continue
Hi:
timerhi:
lo:
timerlo:
input:
if not, go to hi
Step 3: Song Storage Source Code
START:
.INCLUDE "m16def.inc"
ldi r16, (1< out TCCR0, r16
ldi r21, 0xFF
out DDRA, r21
ldi r19, 0b00000001
clr r20
clr r23
timer1:
in r17, TIFR
cpi r17, 0b00000001
breq clr0
cpi r17, 0b00000011
breq clr0
rjmp timer1
clr0:
ldi r16, (1<
out TIFR, r16
loop1:
inc r18
cp r18,r19
breq incnote
rjmp timer1
incnote: ;note# stored in r20,and r23. Note length in r19, note pitch in r22
cpi r20, 0xFF
breq incnote2
inc r20
rjmp song
incnote2: ;This allows the song to be up to 512 notes long
inc r23 ;If I used both registers in the other way, it would allow for 65k notes,
; but would increase program complexity a bit, and more importantly, execution time.
song:
clr r18
n1:
cpi r20,0x01 ;Start with some silence silence between song loops
brne n2
ldi r19, 0x40
ldi r22, 0x00
out PORTA, r22
rjmp n2
bogo2:
rjmp timer1
n2:
cpi r20,0x02 ;Start with some silence silence between song loops
brne n3
ldi r19, 0x20
ldi r22, 0x00
out PORTA, r22
rjmp n3
n3:
cpi r20,0x03 ;a3, 250msec
brne n4
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n4:
cpi r20,0x04 ;b3, 250msec
brne n5
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n5:
cpi r20,0x05 ;c4, 250msec
brne n6
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n6:
cpi r20,0x06 ;e3, 250msec
brne n7
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n7:
cpi r20,0x07 ;c4, 250msec
brne n8
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n8:
cpi r20,0x08 ;e3, 250msec
brne n9
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n9:
cpi r20,0x09 ;c4, 250msec
brne n10
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n10
bogo3:
rjmp bogo2
n10:
cpi r20,0x0A ;e3, 250msec
brne n11
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n11:
cpi r20,0x0B ;c4, 250msec
brne n12
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n12:
cpi r20,0x0C ;e3, 250msec
brne n13
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n13:
cpi r20,0x0D ;d4, 250msec
brne n14
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n14:
cpi r20,0x0D ;e3, 250msec
brne n15
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n15:
cpi r20,0x0E ;c4, 250msec
brne n16
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n16:
cpi r20,0x0F ;e3, 250msec
brne n17
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n17:
cpi r20,0x19 ;b3, 250msec
brne n18
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n18:
cpi r20,0x11 ;e3, 250msec
brne n19
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n19
bogo4:
rjmp bogo3
n19:
cpi r20,0x12 ;b3, 250msec
brne n20
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n20:
cpi r20,0x13 ;e3, 250msec
brne n21
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n21:
cpi r20,0x14 ;b3, 130msec
brne n22
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n22:
cpi r20,0x15 ;e3, 130msec
brne n23
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n23:
cpi r20,0x16 ;b3, 250msec
brne n24
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n24:
cpi r20,0x17 ;e3, 250msec
brne n25
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n25:
cpi r20,0x18 ;c4, 250msec
brne n26
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n26:
cpi r20,0x19 ;e3, 250msec
brne n27
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n27:
cpi r20,0x1A ;b3, 250msec
brne n28
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n28:
cpi r20,0x1B ;e3, 380msec
brne n29
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n29:
cpi r20,0x1C ;a3, 260msec
brne n30
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
rjmp n30
bogo5:
rjmp bogo4
n30:
cpi r20,0x1D ;rest, 30msec
brne n31
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n31:
cpi r20,0x1E ;a3, 20msec
brne n32
ldi r19, 0x04
ldi r22, 0b00110110
out PORTA, r22
n32:
cpi r20,0x1F ;rest, 20msec
brne n33
ldi r19, 0x04
ldi r22, 0b00000000
out PORTA, r22
n33:
cpi r20,0x20 ;b3, 30msec
brne n34
ldi r19, 0x05
ldi r22, 0b00110100
out PORTA, r22
n34:
cpi r20,0x21 ;rest, 30msec
brne n35
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n35:
cpi r20,0x22 ;a3, 280msec, two notes on decompiled midi...
brne n36
ldi r19, 0x1C
ldi r22, 0b00110110
out PORTA, r22
n36:
cpi r20,0x23 ;b3, 40msec
brne n37
ldi r19, 0x04
ldi r22, 0b00110100
out PORTA, r22
n37:
cpi r20,0x24 ;a3, 320msec, two notes on decompiled midi... now note# and row number are aligned
brne n38 ; on my spreadsheet. Before they weren't because of the two initial pauses.
ldi r19, 0x20 ; Convenient for me!
ldi r22, 0b00110110
out PORTA, r22
n38:
cpi r20,0x25 ;b3
brne n39
ldi r19, 0x07
ldi r22, 0b00110100
out PORTA, r22
n39:
cpi r20,0x26 ;a3
brne n40
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
rjmp n40
bogo6:
rjmp bogo5
n40:
cpi r20,0x27 ;g3
brne n41
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n41:
cpi r20,0x28 ;e3
brne n42
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n42:
cpi r20,0x29 ;d3
brne n43
ldi r19, 0x19
ldi r22, 0b00111101
out PORTA, r22
n43:
cpi r20,0x2A ;e3
brne n44
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n44:
cpi r20,0x2B ;a3
brne n45
ldi r19, 0x36
ldi r22, 0b00110110
out PORTA, r22
n45:
cpi r20,0x2C ;b3
brne n46
ldi r19, 0x36
ldi r22, 0b00110100
out PORTA, r22
n46:
cpi r20,0x2D ;c4
brne n47
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n47:
cpi r20,0x2F ;e3
brne n48
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n48:
cpi r20,0x30 ;c4
brne n49
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n49:
cpi r20,0x31 ;e3
brne n50
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n50
bogo7:
rjmp bogo6
n50:
cpi r20,0x32 ;c4
brne n51
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n51:
cpi r20,0x33 ;e3
brne n52
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n52:
cpi r20,0x34 ;c4
brne n53
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n53:
cpi r20,0x35 ;e3
brne n54
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n54:
cpi r20,0x36 ;d4
brne n55
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n55:
cpi r20,0x37 ;e3
brne n56
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n56:
cpi r20,0x38 ;c4
brne n57
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n57:
cpi r20,0x39 ;e3
brne n58
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n58:
cpi r20,0x3A ;b3
brne n59
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n59:
cpi r20,0x3B ;e3
brne n60
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n60
bogo8:
rjmp bogo7
n60:
cpi r20,0x3C ;b3
brne n61
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n61:
cpi r20,0x3D ;e3
brne n62
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n62:
cpi r20,0x3E ;b3
brne n63
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n63:
cpi r20,0x3F ;e3
brne n64
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n64:
cpi r20,0x40 ;b3
brne n65
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n65:
cpi r20,0x41 ;null
brne n66
ldi r19, 0x06
ldi r22, 0b00000000
out PORTA, r22
n66:
cpi r20,0x42 ;e3
brne n67
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n67:
cpi r20,0x43 ;c4
brne n68
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n68:
cpi r20,0x44 ;e3
brne n69
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n69:
cpi r20,0x45 ;b3
brne n70
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
rjmp n70
bogo9:
rjmp bogo8
n70:
cpi r20,0x46 ;e3
brne n71
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n71:
cpi r20,0x47 ;a3
brne n72
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n72:
cpi r20,0x48 ;a3
brne n73
ldi r19, 0x04
ldi r22, 0b00110110
out PORTA, r22
n73:
cpi r20,0x49 ;b3
brne n74
ldi r19, 0x05
ldi r22, 0b00110100
out PORTA, r22
n74:
cpi r20,0x4A ;null
brne n75
ldi r19, 0x04
ldi r22, 0b00000000
out PORTA, r22
n75:
cpi r20,0x4B ;a3
brne n76
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n76:
cpi r20,0x4C ;a3
brne n77
ldi r19, 0x06
ldi r22, 0b00110110
out PORTA, r22
n77:
cpi r20,0x4D ;b3
brne n78
ldi r19, 0x06
ldi r22, 0b00110100
out PORTA, r22
n78:
cpi r20,0x4E ;a3
brne n79
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n79:
cpi r20,0x4F ;null
brne n80
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
rjmp n80
bogo10:
rjmp bogo9
n80:
cpi r20,0x50 ;a3
brne n81
ldi r19, 0x08
ldi r22, 0b00110110
out PORTA, r22
n81:
cpi r20,0x51 ;b3
brne n82
ldi r19, 0x09
ldi r22, 0b00110100
out PORTA, r22
n82:
cpi r20,0x52 ;a3
brne n83
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n83:
cpi r20,0x53 ;g3
brne n84
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n84:
cpi r20,0x54 ;e3
brne n85
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n85:
cpi r20,0x55 ;d3
brne n86
ldi r19, 0x40
ldi r22, 0b00111101
out PORTA, r22
n86:
cpi r20,0x56 ;e3
brne n87
ldi r19, 0x40
ldi r22, 0b00111011
out PORTA, r22
n87:
cpi r20,0x57 ;a3
brne n88
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n88:
cpi r20,0x58 ;b3
brne n89
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n89:
cpi r20,0x59 ;c4
brne n90
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n90
bogo11:
rjmp bogo10
n90:
cpi r20,0x5A ;e3
brne n91
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n91:
cpi r20,0x5B ;c4
brne n92
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n92:
cpi r20,0x5C ;e3
brne n93
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n93:
cpi r20,0x5D ;c4
brne n93b
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n93b:
cpi r20,0x5E ;e3
brne n94
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n94:
cpi r20,0x5F ;e3
brne n95
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n95:
cpi r20,0x60 ;c4
brne n96
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n96:
cpi r20,0x61 ;e3
brne n97
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n97:
cpi r20,0x62 ;d4
brne n98
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n98:
cpi r20,0x63 ;e3
brne n99
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n99:
cpi r20,0x64 ;c4
brne n100
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n100
bogo12:
rjmp bogo11
n100:
cpi r20,0x65 ;e3
brne n101
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n101:
cpi r20,0x66 ;b3
brne n102
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n102:
cpi r20,0x67 ;e3
brne n103
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n103:
cpi r20,0x68 ;b3
brne n104
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n104:
cpi r20,0x69 ;e3
brne n105
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n105:
cpi r20,0x6A ;b3
brne n106
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n106:
cpi r20,0x6B ;e3
brne n107
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n107:
cpi r20,0x6C ;b3
brne n108
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n108:
cpi r20,0x6D ;e3
brne n109
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n109:
cpi r20,0x6E ;c4
brne n110
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n110
bogo13:
rjmp bogo12
n110:
cpi r20,0x6F ;e3
brne n111
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n111:
cpi r20,0x70 ;b3
brne n112
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n112:
cpi r20,0x71 ;e3
brne n113
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n113:
cpi r20,0x72 ;a3
brne n114
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n114:
cpi r20,0x73 ;a3
brne n115
ldi r19, 0x05
ldi r22, 0b00110110
out PORTA, r22
n115:
cpi r20,0x74 ;null
brne n116
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n116:
cpi r20,0x75 ;b3
brne n117
ldi r19, 0x06
ldi r22, 0b00110100
out PORTA, r22
n117:
cpi r20,0x76 ;a3
brne n118
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n118:
cpi r20,0x77 ;a3
brne n119
ldi r19, 0x07
ldi r22, 0b00110110
out PORTA, r22
n119:
cpi r20,0x78 ;b3
brne n120
ldi r19, 0x07
ldi r22, 0b00110100
out PORTA, r22
rjmp n120
bogo14:
rjmp bogo13
n120:
cpi r20,0x79 ;a3
brne n121
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n121:
cpi r20,0x7A ;a3
brne n122
ldi r19, 0x08
ldi r22, 0b00110110
out PORTA, r22
n122:
cpi r20,0x7B ;null
brne n123
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n123:
cpi r20,0x7C ;b3
brne n124
ldi r19, 0x08
ldi r22, 0b00110100
out PORTA, r22
n124:
cpi r20,0x7D ;a3
brne n125
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n125:
cpi r20,0x7E ;g3
brne n126
ldi r19, 0x05
ldi r22, 0b00111000
out PORTA, r22
n126:
cpi r20,0x7F ;e3
brne n127
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n127:
cpi r20,0x80 ;g3
brne n128
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n128:
cpi r20,0x81 ;a3
brne n129
ldi r19, 0x4A
ldi r22, 0b00110110
out PORTA, r22
n129:
cpi r20,0x82 ;a3
brne n130
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
rjmp n130
bogo15:
rjmp bogo14
n130:
cpi r20,0x83 ;null
brne n131
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n131:
cpi r20,0x84 ;b3
brne n132
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n132:
cpi r20,0x85 ;null
brne n133
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n133:
cpi r20,0x86 ;c4
brne n134
ldi r19, 0x4D
ldi r22, 0b00110011
out PORTA, r22
n134:
cpi r20,0x87 ;d4
brne n135
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n135:
cpi r20,0x88 ;c4
brne n136
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n136:
cpi r20,0x89 ;b3
brne n137
ldi r19, 0x4D
ldi r22, 0b00110100
out PORTA, r22
n137:
cpi r20,0x8A ;c4
brne n138
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n138:
cpi r20,0x8B ;b3
brne n139
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n139:
cpi r20,0x8C ;a3
brne n140
ldi r19, 0x40
ldi r22, 0b00110110
out PORTA, r22
rjmp n140
bogo16:
rjmp bogo15
n140:
cpi r20,0x8D ;null
brne n141
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n141:
cpi r20,0x8E ;null
brne n142
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n142:
cpi r20,0x8F ;b3
brne n143
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n143:
cpi r20,0x90 ;a3
brne n144
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n144:
cpi r20,0x91 ;g3
brne n145
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n145:
cpi r20,0x92 ;null
brne n146
ldi r19, 0x03
ldi r22, 0b00000000
out PORTA, r22
n146:
cpi r20,0x93 ;e3
brne n147
ldi r19, 0x4D
ldi r22, 0b00111011
out PORTA, r22
n147:
cpi r20,0x94 ;a3
brne n148
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n148:
cpi r20,0x95 ;b3
brne n149
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n149:
cpi r20,0x96 ;c4
brne n150
ldi r19, 0x33
ldi r22, 0b00110011
out PORTA, r22
rjmp n150
bogo17:
rjmp bogo16
n150:
cpi r20,0x97 ;b3
brne n151
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n151:
cpi r20,0x98 ;c4
brne n152
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n152:
cpi r20,0x99 ;d4
brne n153
ldi r19, 0x26
ldi r22, 0b00110001
out PORTA, r22
n153:
cpi r20,0x9A ;c4
brne n154
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n154:
cpi r20,0x9B ;d4
brne n155
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n155:
cpi r20,0x9C ;e4
brne n156
ldi r19, 0x26
ldi r22, 0b00101111
out PORTA, r22
n156:
cpi r20,0x9D ;a3
brne n157
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n157:
cpi r20,0x9E ;b3
brne n158
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n158:
cpi r20,0x9F ;c4
brne n159
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n159:
cpi r20,0xA0 ;d4
brne n160
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
rjmp n160
bogo18:
rjmp bogo17
n160:
cpi r20,0xA1 ;c4
brne n161
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n161:
cpi r20,0xA2 ;b3
brne n162
ldi r19, 0x22
ldi r22, 0b00110100
out PORTA, r22
n162:
cpi r20,0xA3 ;c4
brne n163
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n163:
cpi r20,0xA4 ;b3
brne n164
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n164:
cpi r20,0xA5 ;a3
brne n165
ldi r19, 0x26
ldi r22, 0b00110110
out PORTA, r22
n165:
cpi r20,0xA6 ;null
brne n166
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n166:
cpi r20,0xA7 ;b3
brne n167
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n167:
cpi r20,0xA8 ;null
brne n168
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n168:
cpi r20,0xA9 ;a3
brne n169
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n169:
cpi r20,0xAA ;g3
brne n170
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
rjmp n170
bogo19:
rjmp bogo18
n170:
cpi r20,0xAB ;e3
brne n171
ldi r19, 0x33
ldi r22, 0b00111011
out PORTA, r22
n171:
cpi r20,0xAC ;a3
brne n172
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n172:
cpi r20,0xAD ;b3
brne n173
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n173:
cpi r20,0xAE ;c4
brne n174
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n174:
cpi r20,0xAF ;d4
brne n175
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n175:
cpi r20,0xB0 ;c4
brne n176
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n176:
cpi r20,0xB1 ;b3
brne n177
ldi r19, 0x26
ldi r22, 0b00110100
out PORTA, r22
n177:
cpi r20,0xB2 ;a3
brne n178
ldi r19, 0x22
ldi r22, 0b00110110
out PORTA, r22
n178:
cpi r20,0xB3 ;null
brne n179
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n179:
cpi r20,0xB4 ;g3
brne n180
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
rjmp n180
bogo20:
rjmp bogo19
n180:
cpi r20,0xB5 ;null
brne n181
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n181:
cpi r20,0xB6 ;b3
brne n182
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n182:
cpi r20,0xB7 ;a3
brne n183
ldi r19, 0x65
ldi r22, 0b00110110
out PORTA, r22
n183:
cpi r20,0xB8 ;a3
brne n184
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n184:
cpi r20,0xB9 ;null
brne n185
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n185:
cpi r20,0xBA ;b3
brne n186
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n186:
cpi r20,0xBB ;null
brne n187
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n187:
cpi r20,0xBC ;c4
brne n188
ldi r19, 0x3E
ldi r22, 0b00110011
out PORTA, r22
n188:
cpi r20,0xBD ;null
brne n189
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n189:
cpi r20,0xBE ;d4
brne n190
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
rjmp n190
bogo21:
rjmp bogo20
n190:
cpi r20,0xBF ;null
brne n191
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n191:
cpi r20,0xC0 ;c4
brne n192
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n192:
cpi r20,0xC1 ;null
brne n193
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n193:
cpi r20,0xC2 ;b3
brne n194
ldi r19, 0x3E
ldi r22, 0b00110100
out PORTA, r22
n194:
cpi r20,0xC3 ;null
brne n195
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n195:
cpi r20,0xC4 ;c4
brne n196
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n196:
cpi r20,0xC5 ;null
brne n197
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n197:
cpi r20,0xC6 ;b3
brne n198
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n198:
cpi r20,0xC7 ;null
brne n199
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n199:
cpi r20,0xC8 ;a3
brne n200
ldi r19, 0x34
ldi r22, 0b00110110
out PORTA, r22
rjmp n200
bogo22:
rjmp bogo21
n200:
cpi r20,0xC9 ;null
brne n201
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n201:
cpi r20,0xCA ;b3
brne n202
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n202:
cpi r20,0xCB ;a3
brne n203
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n203:
cpi r20,0xCC ;g3
brne n204
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n204:
cpi r20,0xCD ;null
brne n205
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n205:
cpi r20,0xCE ;e3
brne n206
ldi r19, 0x3E
ldi r22, 0b00111011
out PORTA, r22
n206:
cpi r20,0xCF ;null
brne n207
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n207:
cpi r20,0xD0 ;a3
brne n208
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n208:
cpi r20,0xD1 ;null
brne n209
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n209:
cpi r20,0xD2 ;b3
brne n210
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
rjmp n210
bogo23:
rjmp bogo22
n210:
cpi r20,0xD3 ;null
brne n211
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n211:
cpi r20,0xD4 ;c4
brne n212
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n212:
cpi r20,0xD5 ;b3
brne n213
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n213:
cpi r20,0xD6 ;c4
brne n214
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n214:
cpi r20,0xD7 ;d4
brne n215
ldi r19, 0x30
ldi r22, 0b00110001
out PORTA, r22
n215:
cpi r20,0xD8 ;c4
brne n216
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n216:
cpi r20,0xD9 ;d4
brne n217
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n217:
cpi r20,0xDA ;e4
brne n218
ldi r19, 0x65
ldi r22, 0b00101111
out PORTA, r22
n218:
cpi r20,0xDB ;a3
brne n219
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n219:
cpi r20,0xDC ;b3
brne n220
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
rjmp n220
bogo24:
rjmp bogo23
n220:
cpi r20,0xDD ;c4
brne n221
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n221:
cpi r20,0xDE ;d4
brne n222
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n222:
cpi r20,0xDF ;c4
brne n223
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n223:
cpi r20,0xE0 ;b3
brne n224
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n224:
cpi r20,0xE1 ;c4
brne n225
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n225:
cpi r20,0xE2 ;b3
brne n226
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n226:
cpi r20,0xE3 ;a3
brne n227
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
n227:
cpi r20,0xE4 ;null
brne n228
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n228:
cpi r20,0xE5 ;b3
brne n229
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n229:
cpi r20,0xE6 ;null
brne n230
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n230
bogo25:
rjmp bogo24
n230:
cpi r20,0xE7 ;a3
brne n231
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n231:
cpi r20,0xE8 ;g3
brne n232
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n232:
cpi r20,0xE9 ;e3
brne n233
ldi r19, 0x30
ldi r22, 0b00111011
out PORTA, r22
n233:
cpi r20,0xEA ;a3
brne n234
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n234:
cpi r20,0xEB ;b3
brne n235
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n235:
cpi r20,0xEC ;c4
brne n236
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n236:
cpi r20,0xED ;d4
brne n237
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n237:
cpi r20,0xEE ;c4
brne n238
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n238:
cpi r20,0xEF ;b3
brne n239
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n239:
cpi r20,0xF0 ;a3
brne n240
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
rjmp n240
bogo26:
rjmp bogo25
n240:
cpi r20,0xF1 ;null
brne n241
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n241:
cpi r20,0xF2 ;g3
brne n242
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n242:
cpi r20,0xF3 ;null
brne n243
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n243:
cpi r20,0xF4 ;b3
brne n244
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n244:
cpi r20,0xF5 ;a3
brne n245
ldi r19, 0x65
ldi r22, 0b00110110
out PORTA, r22
n245:
cpi r20,0xF6 ;c4
brne n246
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n246:
cpi r20,0xF7 ;null
brne n247
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n247:
cpi r20,0xF8 ;d4
brne n248
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n248:
cpi r20,0xF9 ;e4
brne n249
ldi r19, 0x0C
ldi r22, 0b00101111
out PORTA, r22
n249:
cpi r20,0xFA ;null
brne n250
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n250
bogo27:
rjmp bogo26
n250:
cpi r20,0xFB ;d4
brne n251
ldi r19, 0x30
ldi r22, 0b00110001
out PORTA, r22
n251:
cpi r20,0xFC ;null
brne n252
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n252:
cpi r20,0xFD ;c4
brne n253
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n253:
cpi r20,0xFE ;d4
brne n254
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n254:
cpi r20,0xFF ;e4
brne n255
ldi r19, 0x34
ldi r22, 0b00101111
out PORTA, r22
n255:
cpi r23,0x01 ;null, also register switch from r20 to r23 here
brne n256
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n256:
cpi r23,0x02 ;d4
brne n257
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n257:
cpi r23,0x03 ;c4
brne n258
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n258:
cpi r23,0x04 ;d4
brne n259
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n259:
cpi r23,0x05 ;c4
brne n260
ldi r19, 0x25
ldi r22, 0b00110011
out PORTA, r22
rjmp n260
bogo28:
rjmp bogo27
n260:
cpi r23,0x06 ;b3
brne n261
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n261:
cpi r23,0x07 ;c4
brne n262
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n262:
cpi r23,0x08 ;d4
brne n263
ldi r19, 0x34
ldi r22, 0b00110001
out PORTA, r22
n263:
cpi r23,0x09 ;null
brne n264
ldi r19, 0x0D
ldi r22, 0b00000000
out PORTA, r22
n264:
cpi r23,0x0A ;c4
brne n265
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n265:
cpi r23,0x0B ;b3
brne n266
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n266:
cpi r23,0x0C ;c4
brne n267
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n267:
cpi r23,0x0D ;a3
brne n268
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n268:
cpi r23,0x0E ;b3
brne n269
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n269:
cpi r23,0x0F ;c4
brne n270
ldi r19, 0x3E
ldi r22, 0b00110011
out PORTA, r22
rjmp n270
bogo29:
rjmp bogo28
n270:
cpi r23,0x10 ;b3
brne n271
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n271:
cpi r23,0x11 ;null
brne n272
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n272:
cpi r23,0x12 ;a3
brne n273
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n273:
cpi r23,0x13 ;null
brne n274
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n274:
cpi r23,0x14 ;g3
brne n275
ldi r19, 0x50
ldi r22, 0b00111000
out PORTA, r22
n275:
cpi r23,0x15 ;null
brne n276
ldi r19, 0x18
ldi r22, 0b00000000
out PORTA, r22
n276:
cpi r23,0x16 ;a3
brne n277
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n277:
cpi r23,0x17 ;null
brne n278
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n278:
cpi r23,0x18 ;b3
brne n279
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n279:
cpi r23,0x19 ;c4
brne n280
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
rjmp n280
bogo30:
rjmp bogo29
n280:
cpi r23,0x1A ;null
brne n281
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n281:
cpi r23,0x1B ;b3
brne n282
ldi r19, 0x25
ldi r22, 0b00110100
out PORTA, r22
n282:
cpi r23,0x1C ;null
brne n283
ldi r19, 0x0D
ldi r22, 0b00000000
out PORTA, r22
n283:
cpi r23,0x1D ;a3
brne n284
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n284:
cpi r23,0x1E ;c4
brne n285
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n285:
cpi r23,0x1F ;b3
brne n286
ldi r19, 0x4B
ldi r22, 0b00110100
out PORTA, r22
n286:
cpi r23,0x20 ;c4
brne n287
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n287:
cpi r23,0x21 ;null
brne n288
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n288:
cpi r23,0x22 ;b3
brne n289
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n289:
cpi r23,0x23 ;null
brne n290
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n290
bogo31:
rjmp bogo30
n290:
cpi r23,0x24 ;c4
brne n291
ldi r19, 0x25
ldi r22, 0b00110011
out PORTA, r22
n291:
cpi r23,0x25 ;null
brne n292
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n292:
cpi r23,0x26 ;b3
brne n293
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n293:
cpi r23,0x27 ;a3
brne n294
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n294:
cpi r23,0x28 ;null
brne n295
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n295:
cpi r23,0x29 ;g3
brne n296
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n296:
cpi r23,0x2A ;null
brne n297
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n297:
cpi r23,0x2B ;e3
brne n298
ldi r19, 0x34
ldi r22, 0b00111011
out PORTA, r22
n298:
cpi r23,0x2C ;null
brne n299
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n299:
cpi r23,0x2D ;a3
brne n300
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
rjmp n300
bogo32:
rjmp bogo31
n300:
cpi r23,0x2E ;b3
brne n301
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n301:
cpi r23,0x2F ;c4
brne n302
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n302:
cpi r23,0x30 ;d4
brne n303
ldi r19, 0x25
ldi r22, 0b00110001
out PORTA, r22
n303:
cpi r23,0x31 ;null
brne n304
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n304:
cpi r23,0x32 ;c4
brne n305
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n305:
cpi r23,0x33 ;null
brne n306
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n306:
cpi r23,0x34 ;b3
brne n307
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n307:
cpi r23,0x35 ;a3
brne n308
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
n308:
cpi r23,0x36 ;null
brne n309
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n309:
cpi r23,0x37 ;g3
brne n310
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
rjmp n310
bogo33:
inc r24
cpi r24, 0b11111111 ;Timing tweak
breq bogo32
rjmp bogo33
n310:
cpi r23,0x38 ;b3
brne n312
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
;n311:
;cpi r23,0x39 ;null
;brne n312
;ldi r19, 0x05
;ldi r22, 0b00000000
;out PORTA, r22
;n312:
;cpi r23,0x3A ;a3, not necessary
;brne n313
;ldi r19, 0x4B
;ldi r22, 0b00110110
;out PORTA, r22
n312:
cpi r23, 0x3B
ldi r24, 0b00000000
brne bogo33
clr r23
clr r20
clr r17
ldi r22, 0b00000000
out PORTA, r22
rjmp bogo33
ldi r16, (1<
ldi r21, 0xFF
out DDRA, r21
ldi r19, 0b00000001
clr r20
clr r23
timer1:
in r17, TIFR
cpi r17, 0b00000001
breq clr0
cpi r17, 0b00000011
breq clr0
rjmp timer1
clr0:
ldi r16, (1<
out TIFR, r16
loop1:
inc r18
cp r18,r19
breq incnote
rjmp timer1
cpi r20, 0xFF
breq incnote2
inc r20
rjmp song
song:
clr r18
n1:
brne n2
ldi r19, 0x40
ldi r22, 0x00
out PORTA, r22
rjmp n2
bogo2:
rjmp timer1
n2:
brne n3
ldi r19, 0x20
ldi r22, 0x00
out PORTA, r22
rjmp n3
n3:
brne n4
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n4:
brne n5
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n5:
brne n6
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n6:
brne n7
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n7:
brne n8
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n8:
brne n9
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n9:
brne n10
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n10
bogo3:
rjmp bogo2
n10:
brne n11
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n11:
brne n12
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n12:
brne n13
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n13:
brne n14
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n14:
brne n15
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n15:
brne n16
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n16:
brne n17
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n17:
brne n18
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n18:
brne n19
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n19
bogo4:
rjmp bogo3
n19:
brne n20
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n20:
brne n21
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n21:
brne n22
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n22:
brne n23
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n23:
brne n24
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n24:
brne n25
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n25:
brne n26
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n26:
brne n27
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n27:
brne n28
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n28:
brne n29
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n29:
brne n30
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
rjmp n30
bogo5:
rjmp bogo4
n30:
brne n31
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n31:
brne n32
ldi r19, 0x04
ldi r22, 0b00110110
out PORTA, r22
n32:
brne n33
ldi r19, 0x04
ldi r22, 0b00000000
out PORTA, r22
n33:
brne n34
ldi r19, 0x05
ldi r22, 0b00110100
out PORTA, r22
n34:
brne n35
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n35:
brne n36
ldi r19, 0x1C
ldi r22, 0b00110110
out PORTA, r22
n36:
brne n37
ldi r19, 0x04
ldi r22, 0b00110100
out PORTA, r22
n37:
ldi r22, 0b00110110
out PORTA, r22
n38:
cpi r20,0x25 ;b3
brne n39
ldi r19, 0x07
ldi r22, 0b00110100
out PORTA, r22
n39:
cpi r20,0x26 ;a3
brne n40
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
rjmp n40
bogo6:
rjmp bogo5
n40:
cpi r20,0x27 ;g3
brne n41
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n41:
cpi r20,0x28 ;e3
brne n42
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n42:
cpi r20,0x29 ;d3
brne n43
ldi r19, 0x19
ldi r22, 0b00111101
out PORTA, r22
n43:
cpi r20,0x2A ;e3
brne n44
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n44:
cpi r20,0x2B ;a3
brne n45
ldi r19, 0x36
ldi r22, 0b00110110
out PORTA, r22
n45:
cpi r20,0x2C ;b3
brne n46
ldi r19, 0x36
ldi r22, 0b00110100
out PORTA, r22
n46:
cpi r20,0x2D ;c4
brne n47
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n47:
cpi r20,0x2F ;e3
brne n48
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n48:
cpi r20,0x30 ;c4
brne n49
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n49:
cpi r20,0x31 ;e3
brne n50
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n50
bogo7:
rjmp bogo6
n50:
cpi r20,0x32 ;c4
brne n51
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n51:
cpi r20,0x33 ;e3
brne n52
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n52:
cpi r20,0x34 ;c4
brne n53
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n53:
cpi r20,0x35 ;e3
brne n54
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n54:
cpi r20,0x36 ;d4
brne n55
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n55:
cpi r20,0x37 ;e3
brne n56
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n56:
cpi r20,0x38 ;c4
brne n57
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n57:
cpi r20,0x39 ;e3
brne n58
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n58:
cpi r20,0x3A ;b3
brne n59
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n59:
cpi r20,0x3B ;e3
brne n60
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
rjmp n60
bogo8:
rjmp bogo7
n60:
cpi r20,0x3C ;b3
brne n61
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n61:
cpi r20,0x3D ;e3
brne n62
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n62:
cpi r20,0x3E ;b3
brne n63
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n63:
cpi r20,0x3F ;e3
brne n64
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n64:
cpi r20,0x40 ;b3
brne n65
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n65:
cpi r20,0x41 ;null
brne n66
ldi r19, 0x06
ldi r22, 0b00000000
out PORTA, r22
n66:
cpi r20,0x42 ;e3
brne n67
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n67:
cpi r20,0x43 ;c4
brne n68
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n68:
cpi r20,0x44 ;e3
brne n69
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n69:
cpi r20,0x45 ;b3
brne n70
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
rjmp n70
bogo9:
rjmp bogo8
n70:
cpi r20,0x46 ;e3
brne n71
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n71:
cpi r20,0x47 ;a3
brne n72
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n72:
cpi r20,0x48 ;a3
brne n73
ldi r19, 0x04
ldi r22, 0b00110110
out PORTA, r22
n73:
cpi r20,0x49 ;b3
brne n74
ldi r19, 0x05
ldi r22, 0b00110100
out PORTA, r22
n74:
cpi r20,0x4A ;null
brne n75
ldi r19, 0x04
ldi r22, 0b00000000
out PORTA, r22
n75:
cpi r20,0x4B ;a3
brne n76
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n76:
cpi r20,0x4C ;a3
brne n77
ldi r19, 0x06
ldi r22, 0b00110110
out PORTA, r22
n77:
cpi r20,0x4D ;b3
brne n78
ldi r19, 0x06
ldi r22, 0b00110100
out PORTA, r22
n78:
cpi r20,0x4E ;a3
brne n79
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n79:
cpi r20,0x4F ;null
brne n80
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
rjmp n80
bogo10:
rjmp bogo9
n80:
cpi r20,0x50 ;a3
brne n81
ldi r19, 0x08
ldi r22, 0b00110110
out PORTA, r22
n81:
cpi r20,0x51 ;b3
brne n82
ldi r19, 0x09
ldi r22, 0b00110100
out PORTA, r22
n82:
cpi r20,0x52 ;a3
brne n83
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n83:
cpi r20,0x53 ;g3
brne n84
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n84:
cpi r20,0x54 ;e3
brne n85
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n85:
cpi r20,0x55 ;d3
brne n86
ldi r19, 0x40
ldi r22, 0b00111101
out PORTA, r22
n86:
cpi r20,0x56 ;e3
brne n87
ldi r19, 0x40
ldi r22, 0b00111011
out PORTA, r22
n87:
cpi r20,0x57 ;a3
brne n88
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n88:
cpi r20,0x58 ;b3
brne n89
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n89:
cpi r20,0x59 ;c4
brne n90
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n90
bogo11:
rjmp bogo10
n90:
cpi r20,0x5A ;e3
brne n91
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n91:
cpi r20,0x5B ;c4
brne n92
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n92:
cpi r20,0x5C ;e3
brne n93
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n93:
cpi r20,0x5D ;c4
brne n93b
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n93b:
cpi r20,0x5E ;e3
brne n94
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n94:
cpi r20,0x5F ;e3
brne n95
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n95:
cpi r20,0x60 ;c4
brne n96
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n96:
cpi r20,0x61 ;e3
brne n97
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n97:
cpi r20,0x62 ;d4
brne n98
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n98:
cpi r20,0x63 ;e3
brne n99
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n99:
cpi r20,0x64 ;c4
brne n100
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n100
bogo12:
rjmp bogo11
n100:
cpi r20,0x65 ;e3
brne n101
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n101:
cpi r20,0x66 ;b3
brne n102
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n102:
cpi r20,0x67 ;e3
brne n103
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n103:
cpi r20,0x68 ;b3
brne n104
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n104:
cpi r20,0x69 ;e3
brne n105
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n105:
cpi r20,0x6A ;b3
brne n106
ldi r19, 0x0D
ldi r22, 0b00110100
out PORTA, r22
n106:
cpi r20,0x6B ;e3
brne n107
ldi r19, 0x0C
ldi r22, 0b00111011
out PORTA, r22
n107:
cpi r20,0x6C ;b3
brne n108
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n108:
cpi r20,0x6D ;e3
brne n109
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n109:
cpi r20,0x6E ;c4
brne n110
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
rjmp n110
bogo13:
rjmp bogo12
n110:
cpi r20,0x6F ;e3
brne n111
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n111:
cpi r20,0x70 ;b3
brne n112
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n112:
cpi r20,0x71 ;e3
brne n113
ldi r19, 0x26
ldi r22, 0b00111011
out PORTA, r22
n113:
cpi r20,0x72 ;a3
brne n114
ldi r19, 0x1A
ldi r22, 0b00110110
out PORTA, r22
n114:
cpi r20,0x73 ;a3
brne n115
ldi r19, 0x05
ldi r22, 0b00110110
out PORTA, r22
n115:
cpi r20,0x74 ;null
brne n116
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n116:
cpi r20,0x75 ;b3
brne n117
ldi r19, 0x06
ldi r22, 0b00110100
out PORTA, r22
n117:
cpi r20,0x76 ;a3
brne n118
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n118:
cpi r20,0x77 ;a3
brne n119
ldi r19, 0x07
ldi r22, 0b00110110
out PORTA, r22
n119:
cpi r20,0x78 ;b3
brne n120
ldi r19, 0x07
ldi r22, 0b00110100
out PORTA, r22
rjmp n120
bogo14:
rjmp bogo13
n120:
cpi r20,0x79 ;a3
brne n121
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n121:
cpi r20,0x7A ;a3
brne n122
ldi r19, 0x08
ldi r22, 0b00110110
out PORTA, r22
n122:
cpi r20,0x7B ;null
brne n123
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n123:
cpi r20,0x7C ;b3
brne n124
ldi r19, 0x08
ldi r22, 0b00110100
out PORTA, r22
n124:
cpi r20,0x7D ;a3
brne n125
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n125:
cpi r20,0x7E ;g3
brne n126
ldi r19, 0x05
ldi r22, 0b00111000
out PORTA, r22
n126:
cpi r20,0x7F ;e3
brne n127
ldi r19, 0x19
ldi r22, 0b00111011
out PORTA, r22
n127:
cpi r20,0x80 ;g3
brne n128
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n128:
cpi r20,0x81 ;a3
brne n129
ldi r19, 0x4A
ldi r22, 0b00110110
out PORTA, r22
n129:
cpi r20,0x82 ;a3
brne n130
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
rjmp n130
bogo15:
rjmp bogo14
n130:
cpi r20,0x83 ;null
brne n131
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n131:
cpi r20,0x84 ;b3
brne n132
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n132:
cpi r20,0x85 ;null
brne n133
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n133:
cpi r20,0x86 ;c4
brne n134
ldi r19, 0x4D
ldi r22, 0b00110011
out PORTA, r22
n134:
cpi r20,0x87 ;d4
brne n135
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n135:
cpi r20,0x88 ;c4
brne n136
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n136:
cpi r20,0x89 ;b3
brne n137
ldi r19, 0x4D
ldi r22, 0b00110100
out PORTA, r22
n137:
cpi r20,0x8A ;c4
brne n138
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n138:
cpi r20,0x8B ;b3
brne n139
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n139:
cpi r20,0x8C ;a3
brne n140
ldi r19, 0x40
ldi r22, 0b00110110
out PORTA, r22
rjmp n140
bogo16:
rjmp bogo15
n140:
cpi r20,0x8D ;null
brne n141
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n141:
cpi r20,0x8E ;null
brne n142
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n142:
cpi r20,0x8F ;b3
brne n143
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n143:
cpi r20,0x90 ;a3
brne n144
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n144:
cpi r20,0x91 ;g3
brne n145
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n145:
cpi r20,0x92 ;null
brne n146
ldi r19, 0x03
ldi r22, 0b00000000
out PORTA, r22
n146:
cpi r20,0x93 ;e3
brne n147
ldi r19, 0x4D
ldi r22, 0b00111011
out PORTA, r22
n147:
cpi r20,0x94 ;a3
brne n148
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n148:
cpi r20,0x95 ;b3
brne n149
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n149:
cpi r20,0x96 ;c4
brne n150
ldi r19, 0x33
ldi r22, 0b00110011
out PORTA, r22
rjmp n150
bogo17:
rjmp bogo16
n150:
cpi r20,0x97 ;b3
brne n151
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n151:
cpi r20,0x98 ;c4
brne n152
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n152:
cpi r20,0x99 ;d4
brne n153
ldi r19, 0x26
ldi r22, 0b00110001
out PORTA, r22
n153:
cpi r20,0x9A ;c4
brne n154
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n154:
cpi r20,0x9B ;d4
brne n155
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n155:
cpi r20,0x9C ;e4
brne n156
ldi r19, 0x26
ldi r22, 0b00101111
out PORTA, r22
n156:
cpi r20,0x9D ;a3
brne n157
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n157:
cpi r20,0x9E ;b3
brne n158
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n158:
cpi r20,0x9F ;c4
brne n159
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n159:
cpi r20,0xA0 ;d4
brne n160
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
rjmp n160
bogo18:
rjmp bogo17
n160:
cpi r20,0xA1 ;c4
brne n161
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n161:
cpi r20,0xA2 ;b3
brne n162
ldi r19, 0x22
ldi r22, 0b00110100
out PORTA, r22
n162:
cpi r20,0xA3 ;c4
brne n163
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n163:
cpi r20,0xA4 ;b3
brne n164
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n164:
cpi r20,0xA5 ;a3
brne n165
ldi r19, 0x26
ldi r22, 0b00110110
out PORTA, r22
n165:
cpi r20,0xA6 ;null
brne n166
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n166:
cpi r20,0xA7 ;b3
brne n167
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n167:
cpi r20,0xA8 ;null
brne n168
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n168:
cpi r20,0xA9 ;a3
brne n169
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n169:
cpi r20,0xAA ;g3
brne n170
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
rjmp n170
bogo19:
rjmp bogo18
n170:
cpi r20,0xAB ;e3
brne n171
ldi r19, 0x33
ldi r22, 0b00111011
out PORTA, r22
n171:
cpi r20,0xAC ;a3
brne n172
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n172:
cpi r20,0xAD ;b3
brne n173
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n173:
cpi r20,0xAE ;c4
brne n174
ldi r19, 0x26
ldi r22, 0b00110011
out PORTA, r22
n174:
cpi r20,0xAF ;d4
brne n175
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n175:
cpi r20,0xB0 ;c4
brne n176
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n176:
cpi r20,0xB1 ;b3
brne n177
ldi r19, 0x26
ldi r22, 0b00110100
out PORTA, r22
n177:
cpi r20,0xB2 ;a3
brne n178
ldi r19, 0x22
ldi r22, 0b00110110
out PORTA, r22
n178:
cpi r20,0xB3 ;null
brne n179
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n179:
cpi r20,0xB4 ;g3
brne n180
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
rjmp n180
bogo20:
rjmp bogo19
n180:
cpi r20,0xB5 ;null
brne n181
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n181:
cpi r20,0xB6 ;b3
brne n182
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n182:
cpi r20,0xB7 ;a3
brne n183
ldi r19, 0x65
ldi r22, 0b00110110
out PORTA, r22
n183:
cpi r20,0xB8 ;a3
brne n184
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n184:
cpi r20,0xB9 ;null
brne n185
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n185:
cpi r20,0xBA ;b3
brne n186
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n186:
cpi r20,0xBB ;null
brne n187
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n187:
cpi r20,0xBC ;c4
brne n188
ldi r19, 0x3E
ldi r22, 0b00110011
out PORTA, r22
n188:
cpi r20,0xBD ;null
brne n189
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n189:
cpi r20,0xBE ;d4
brne n190
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
rjmp n190
bogo21:
rjmp bogo20
n190:
cpi r20,0xBF ;null
brne n191
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n191:
cpi r20,0xC0 ;c4
brne n192
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n192:
cpi r20,0xC1 ;null
brne n193
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n193:
cpi r20,0xC2 ;b3
brne n194
ldi r19, 0x3E
ldi r22, 0b00110100
out PORTA, r22
n194:
cpi r20,0xC3 ;null
brne n195
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n195:
cpi r20,0xC4 ;c4
brne n196
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n196:
cpi r20,0xC5 ;null
brne n197
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n197:
cpi r20,0xC6 ;b3
brne n198
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n198:
cpi r20,0xC7 ;null
brne n199
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n199:
cpi r20,0xC8 ;a3
brne n200
ldi r19, 0x34
ldi r22, 0b00110110
out PORTA, r22
rjmp n200
bogo22:
rjmp bogo21
n200:
cpi r20,0xC9 ;null
brne n201
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n201:
cpi r20,0xCA ;b3
brne n202
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n202:
cpi r20,0xCB ;a3
brne n203
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n203:
cpi r20,0xCC ;g3
brne n204
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n204:
cpi r20,0xCD ;null
brne n205
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n205:
cpi r20,0xCE ;e3
brne n206
ldi r19, 0x3E
ldi r22, 0b00111011
out PORTA, r22
n206:
cpi r20,0xCF ;null
brne n207
ldi r19, 0x14
ldi r22, 0b00000000
out PORTA, r22
n207:
cpi r20,0xD0 ;a3
brne n208
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n208:
cpi r20,0xD1 ;null
brne n209
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n209:
cpi r20,0xD2 ;b3
brne n210
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
rjmp n210
bogo23:
rjmp bogo22
n210:
cpi r20,0xD3 ;null
brne n211
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n211:
cpi r20,0xD4 ;c4
brne n212
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n212:
cpi r20,0xD5 ;b3
brne n213
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n213:
cpi r20,0xD6 ;c4
brne n214
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n214:
cpi r20,0xD7 ;d4
brne n215
ldi r19, 0x30
ldi r22, 0b00110001
out PORTA, r22
n215:
cpi r20,0xD8 ;c4
brne n216
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n216:
cpi r20,0xD9 ;d4
brne n217
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n217:
cpi r20,0xDA ;e4
brne n218
ldi r19, 0x65
ldi r22, 0b00101111
out PORTA, r22
n218:
cpi r20,0xDB ;a3
brne n219
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n219:
cpi r20,0xDC ;b3
brne n220
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
rjmp n220
bogo24:
rjmp bogo23
n220:
cpi r20,0xDD ;c4
brne n221
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n221:
cpi r20,0xDE ;d4
brne n222
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n222:
cpi r20,0xDF ;c4
brne n223
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n223:
cpi r20,0xE0 ;b3
brne n224
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n224:
cpi r20,0xE1 ;c4
brne n225
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n225:
cpi r20,0xE2 ;b3
brne n226
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n226:
cpi r20,0xE3 ;a3
brne n227
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
n227:
cpi r20,0xE4 ;null
brne n228
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n228:
cpi r20,0xE5 ;b3
brne n229
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n229:
cpi r20,0xE6 ;null
brne n230
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n230
bogo25:
rjmp bogo24
n230:
cpi r20,0xE7 ;a3
brne n231
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n231:
cpi r20,0xE8 ;g3
brne n232
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n232:
cpi r20,0xE9 ;e3
brne n233
ldi r19, 0x30
ldi r22, 0b00111011
out PORTA, r22
n233:
cpi r20,0xEA ;a3
brne n234
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n234:
cpi r20,0xEB ;b3
brne n235
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n235:
cpi r20,0xEC ;c4
brne n236
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n236:
cpi r20,0xED ;d4
brne n237
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n237:
cpi r20,0xEE ;c4
brne n238
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n238:
cpi r20,0xEF ;b3
brne n239
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n239:
cpi r20,0xF0 ;a3
brne n240
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
rjmp n240
bogo26:
rjmp bogo25
n240:
cpi r20,0xF1 ;null
brne n241
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n241:
cpi r20,0xF2 ;g3
brne n242
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
n242:
cpi r20,0xF3 ;null
brne n243
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n243:
cpi r20,0xF4 ;b3
brne n244
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n244:
cpi r20,0xF5 ;a3
brne n245
ldi r19, 0x65
ldi r22, 0b00110110
out PORTA, r22
n245:
cpi r20,0xF6 ;c4
brne n246
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n246:
cpi r20,0xF7 ;null
brne n247
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n247:
cpi r20,0xF8 ;d4
brne n248
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n248:
cpi r20,0xF9 ;e4
brne n249
ldi r19, 0x0C
ldi r22, 0b00101111
out PORTA, r22
n249:
cpi r20,0xFA ;null
brne n250
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n250
bogo27:
rjmp bogo26
n250:
cpi r20,0xFB ;d4
brne n251
ldi r19, 0x30
ldi r22, 0b00110001
out PORTA, r22
n251:
cpi r20,0xFC ;null
brne n252
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n252:
cpi r20,0xFD ;c4
brne n253
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n253:
cpi r20,0xFE ;d4
brne n254
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n254:
cpi r20,0xFF ;e4
brne n255
ldi r19, 0x34
ldi r22, 0b00101111
out PORTA, r22
n255:
brne n256
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n256:
cpi r23,0x02 ;d4
brne n257
ldi r19, 0x19
ldi r22, 0b00110001
out PORTA, r22
n257:
cpi r23,0x03 ;c4
brne n258
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n258:
cpi r23,0x04 ;d4
brne n259
ldi r19, 0x0C
ldi r22, 0b00110001
out PORTA, r22
n259:
cpi r23,0x05 ;c4
brne n260
ldi r19, 0x25
ldi r22, 0b00110011
out PORTA, r22
rjmp n260
bogo28:
rjmp bogo27
n260:
cpi r23,0x06 ;b3
brne n261
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n261:
cpi r23,0x07 ;c4
brne n262
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n262:
cpi r23,0x08 ;d4
brne n263
ldi r19, 0x34
ldi r22, 0b00110001
out PORTA, r22
n263:
cpi r23,0x09 ;null
brne n264
ldi r19, 0x0D
ldi r22, 0b00000000
out PORTA, r22
n264:
cpi r23,0x0A ;c4
brne n265
ldi r19, 0x19
ldi r22, 0b00110011
out PORTA, r22
n265:
cpi r23,0x0B ;b3
brne n266
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n266:
cpi r23,0x0C ;c4
brne n267
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n267:
cpi r23,0x0D ;a3
brne n268
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n268:
cpi r23,0x0E ;b3
brne n269
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n269:
cpi r23,0x0F ;c4
brne n270
ldi r19, 0x3E
ldi r22, 0b00110011
out PORTA, r22
rjmp n270
bogo29:
rjmp bogo28
n270:
cpi r23,0x10 ;b3
brne n271
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n271:
cpi r23,0x11 ;null
brne n272
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n272:
cpi r23,0x12 ;a3
brne n273
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n273:
cpi r23,0x13 ;null
brne n274
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n274:
cpi r23,0x14 ;g3
brne n275
ldi r19, 0x50
ldi r22, 0b00111000
out PORTA, r22
n275:
cpi r23,0x15 ;null
brne n276
ldi r19, 0x18
ldi r22, 0b00000000
out PORTA, r22
n276:
cpi r23,0x16 ;a3
brne n277
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n277:
cpi r23,0x17 ;null
brne n278
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n278:
cpi r23,0x18 ;b3
brne n279
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n279:
cpi r23,0x19 ;c4
brne n280
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
rjmp n280
bogo30:
rjmp bogo29
n280:
cpi r23,0x1A ;null
brne n281
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n281:
cpi r23,0x1B ;b3
brne n282
ldi r19, 0x25
ldi r22, 0b00110100
out PORTA, r22
n282:
cpi r23,0x1C ;null
brne n283
ldi r19, 0x0D
ldi r22, 0b00000000
out PORTA, r22
n283:
cpi r23,0x1D ;a3
brne n284
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
n284:
cpi r23,0x1E ;c4
brne n285
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n285:
cpi r23,0x1F ;b3
brne n286
ldi r19, 0x4B
ldi r22, 0b00110100
out PORTA, r22
n286:
cpi r23,0x20 ;c4
brne n287
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n287:
cpi r23,0x21 ;null
brne n288
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n288:
cpi r23,0x22 ;b3
brne n289
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n289:
cpi r23,0x23 ;null
brne n290
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
rjmp n290
bogo31:
rjmp bogo30
n290:
cpi r23,0x24 ;c4
brne n291
ldi r19, 0x25
ldi r22, 0b00110011
out PORTA, r22
n291:
cpi r23,0x25 ;null
brne n292
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n292:
cpi r23,0x26 ;b3
brne n293
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
n293:
cpi r23,0x27 ;a3
brne n294
ldi r19, 0x0C
ldi r22, 0b00110110
out PORTA, r22
n294:
cpi r23,0x28 ;null
brne n295
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n295:
cpi r23,0x29 ;g3
brne n296
ldi r19, 0x19
ldi r22, 0b00111000
out PORTA, r22
n296:
cpi r23,0x2A ;null
brne n297
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n297:
cpi r23,0x2B ;e3
brne n298
ldi r19, 0x34
ldi r22, 0b00111011
out PORTA, r22
n298:
cpi r23,0x2C ;null
brne n299
ldi r19, 0x08
ldi r22, 0b00000000
out PORTA, r22
n299:
cpi r23,0x2D ;a3
brne n300
ldi r19, 0x19
ldi r22, 0b00110110
out PORTA, r22
rjmp n300
bogo32:
rjmp bogo31
n300:
cpi r23,0x2E ;b3
brne n301
ldi r19, 0x19
ldi r22, 0b00110100
out PORTA, r22
n301:
cpi r23,0x2F ;c4
brne n302
ldi r19, 0x30
ldi r22, 0b00110011
out PORTA, r22
n302:
cpi r23,0x30 ;d4
brne n303
ldi r19, 0x25
ldi r22, 0b00110001
out PORTA, r22
n303:
cpi r23,0x31 ;null
brne n304
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n304:
cpi r23,0x32 ;c4
brne n305
ldi r19, 0x0C
ldi r22, 0b00110011
out PORTA, r22
n305:
cpi r23,0x33 ;null
brne n306
ldi r19, 0x05
ldi r22, 0b00000000
out PORTA, r22
n306:
cpi r23,0x34 ;b3
brne n307
ldi r19, 0x30
ldi r22, 0b00110100
out PORTA, r22
n307:
cpi r23,0x35 ;a3
brne n308
ldi r19, 0x25
ldi r22, 0b00110110
out PORTA, r22
n308:
cpi r23,0x36 ;null
brne n309
ldi r19, 0x0A
ldi r22, 0b00000000
out PORTA, r22
n309:
cpi r23,0x37 ;g3
brne n310
ldi r19, 0x0C
ldi r22, 0b00111000
out PORTA, r22
rjmp n310
bogo33:
inc r24
breq bogo32
rjmp bogo33
n310:
cpi r23,0x38 ;b3
brne n312
ldi r19, 0x0C
ldi r22, 0b00110100
out PORTA, r22
;n311:
;cpi r23,0x39 ;null
;brne n312
;ldi r19, 0x05
;out PORTA, r22
;n312:
;brne n313
;ldi r19, 0x4B
;out PORTA, r22
n312:
cpi r23, 0x3B
ldi r24, 0b00000000
brne bogo33
clr r23
clr r20
clr r17
ldi r22, 0b00000000
out PORTA, r22
rjmp bogo33
Step 4: Song Storage Code Explained
It works like this:
control:
Start timer
Wait for timer overflow
Loop a certain number of times (this is the note length)
increment note number
Song data:
is the note number =1?
if so, output the correct number out port A, PIN0, and load the note length into a register
if not, continue
is the note number=2?
ad nauseum, over 300 notes
is the song finished?
if yes, clear all registers
if not, return to the "wait for timer overflow" step, with the correct note length value in the appropriate register. It will then increment note number and return to the "song data" function.
control:
Start timer
Song data:
if not, continue
Step 5: About the Song
I did not write the song... it is from an old computer game (Ultima) , and is called "Stones".
Over the years (it is an old game), people have done many different versions on many instruments. I would go so far as to say it is one of the best MIDI songs from that era of computer gaming. I've sort of always wanted to build a music box, and this was the obvious choice... cutting open one of those annoying "happy birthday" musical cards for the sound thing was simply not adequate this time :D
More photos will come later, as I build the electronics into the false bottom of a wooden box.
This first photo is of the soldered and fully functional circuit. There is one glitch: If you poke the darlington pair, the music can freeze on the current note (not sure precisely why yet)! I plan to fix this by simply securing the circuit properly so those parts don't contact anything less resistant than air... should work just fine.
Now that it is in the black plastic box, it works great. I have varnished a wooden box to hold all this, soon I will have photos of the finished product. I think this will make a great birthday gift!
Step 6: The Box Proper
To fit it into a false section of an actual box was a bit of a challenge. The box I had... which I had built 10 years ago because my high school thought it was a great idea to teach us to make boxes... had an indentation in the lid that looked promising. This gave me 2 centimeters of depth to play with, which was not much, but I did manage to cram everything in there.
I had varnished the box with satin finish black polyurethane varnish I had lying about. The varnish job turned out well enough, but there are a few places I made mistakes in. Notably, the colour I had added in to the varnish increased it's drying time to the point where it was hard to work with. Next time, I'll use wood stain and spray-on satin varnish.
Since I had decided to line the box with velvet, I decided to wrap the plastic box holding the electronics in velvet so that it would just barely fit in, and friction would hold it in place. That was surprisingly easy once I discovered that using a foam spacer to keep the speaker in place was very effective. All fabric was attached using double-sided tape, the memory of which now causes me to twitch (tip: do not use dollar-store double sided tape or you will likely go mad as a hatter).
Lining the rest of the box with velvet was troublesome, and I have to say I'm not entirely satisfied with the results. I tried to calculate the correct amount of cloth to use to create seamless lining for the inside of the box, and somehow failed miserably. Clearly, unlike my ancestors, I am not destined for the upholstery business.
In any case it's done, and overall I'm satisfied with the way it turned out. I may tweak a few bits to fix the fabric, and/or integrate a photo into the box to cleverly cover up one of the suboptimal spots.
