Introduction: Pop Up Bench Dogs
About: I just like creating stuff. Mostly recreational woodworking and diy projects. Please consider following me. It will fuel me to create more instructables. :-) Please check out my YouTube channel here : https://…
I wanted to add a bench dog to my work table. Why not make it a pop up bench dog? I picked up a cheap IKEA push latch. Please observe this is not my original idea - I adapted it and made my version of it described here.
Here is a short video of all the steps!
If you want a great instructable and build of this I warmly recommends John Zhu
https://www.instructables.com/id/2-Pop-Up-Woodwork...
Mine differs a bit with the mounting, size, shape and... well... the spring action that was a bit too strong. :-) This turned out to be a useful and fun project.
For this project I used
  • Pallet wood (white oak) for the bench dogs
  • IKEA push latch (art nr: 802.302.24) for around 5 bucks (for 2 pieces).
  • Scrap pieces of construction plywood.
  • Wood glue
  • Nails
Tools used
  • Belt sander
  • Palm sander
  • Bandsaw
  • Mitre saw
  • Chisels and files
  • Drill
Step 1: Making Some Bench Dogs
I wanted to make the bench dogs in hard wood. I had some pallet wood that happens to be white oak. I want to use this for a long time and then move it to another workbench in the future.
I cut the pieces to length and split it (square) on my band saw.
I squared it to final size with a belt sander and hand sanded it too with finer grit (120). You can make this the shape and size you want.
Step 2: Making the Mount/holder
I use the bench dog that I made to set the size of the case. I just cut some plywood pieces square and fasten in like a box around the "dog". Not to snug. Not to loose. It needs to move freely. I leave one of the sides longer, so I can fasten the push latch there.
I wont show the cutting and glue up here in this instructable. Hopefully that is OK with you guys?
Before I fasten the push latch I make sure I take in account the thickness of the table. I make the bench dog a bit proud, so I can later make the perfect size.
Step 3: Fasten the Push Latch
When I'm happy with the position of the latch holder, I put some screws in. Dont glue it, because you might want to make adjustments later. Or move it to another bench with another thickness of the table.
Now the case/holder for the bench dog is finished and I can mount it to my work bench of choice.
Step 4: Fitting the Holder to the Table
Now I need to make a hole in my work table. Please meassure twice or more. I only have single plywood here. But if you have a fancy hardwood workbench, it will be a sad day if you put that hole in the wrong spot.
Workbenches dont need extra venting holes...
I made a square bench dog. I like that shape and I have better use of the square surface for my projects. But you could also use round dowels. Then you only need to drill a round hole with the correct size.
I squared my hole with chisels and files. Snug fit, but not too snug.
I used some screws to fasten the latch holder under the table.
Step 5: Final Adjustments
I make sure that everything is working. As I described before, I made the bench dog a bit proud just to make sure I could do any adjustments if needed.
I used a belt sander and a palm sander to grind the bench dog flat to the surface of the workbench.
Step 6: Final Thoughts
So the push latch I used is too long (and strong). If I would make this again, I would maybe find shorter push latches - but I figured I made a cut out on the bench dog to turn it over, so it wont rise too high.
Mostly I will not need it, but its nice when I work with thinner pieces like plywood or anything like that.
The function is really nice, and I had to admit I played way too long with this. It makes me smile when I use it.
A bit of warning. The quality and size of this push latch is very good. If you let it go when you release the bench dog, it will shoot right up. It's not very practically, but super fun.
Now I'm thinking of other things to spring load... like sharp chisels or a saw?
Thank you so much for checking this instructable out! Hope you like it - please let me know in the comments. :-)
I entered the "Make it move" contest so if you like this, please consider giving me a vote down below.
Check out my other instructables here:
https://www.instructables.com/member/dekeros/instr...
Or my YouTube channel here:
https://www.youtube.com/channel/UCizkOEx_0EOqWDZu5...
Or maybe my blog over here:
www.dekeros.com
Thanks a million again!
