Introduction: Pop-Up Penguin Card
I created this Instructable during Covid-19 lockdown because cards are a great way to connect with people we can’t visit. I designed this one for a friend who loves penguins.
I’m using a Cricut machine that can draw the penguins, create fold lines in the card and cut the shapes out. You could also make the card with a different vinyl cutter or a printer and scissors instead.
- Computer
- Cricut® Design Space software
- Cricut Maker®
- Cricut® LightGrip Mat
- Cricut® Scoring Stylus
- Cricut® Pens (I used Black, Coral and Bluebonnet - 0.4 Tip)
- White Card (2 sheets of A4)
- Blue Paper (1 sheet of A4)
- Grey Paper (5x5cm)
- Felt tip pens (Black and Orange)
- Glue (e.g Bostik or UHU® All Purpose Glue)
If you are using a printer and scissors instead of a cutting machine, you don't need any Cricut® supplies.
Step 1: Add the Cutting File to Cricut Design Space
Download the Pop-Up Penguin Card cutting file
Open a new project in Cricut® Design Space
Click Upload and then Upload Image
Browse and select the Pop-Up Penguin Card file you just downloaded
Click Open and Save
Select the image from the Recently Uploaded Images area and click Insert Images
Step 2: Set the Lines to Cut, Score and Draw
Click on the image and while everything is grouped together, change the Line Type to Draw
Click Ungroup to control the lines separately
Select the outer line of each object and change the Line Type to Cut
On the igloo layer, change the lines for the igloo entrance to Cut. If it changes colour, click on the square next to the Line Type dropdown menu and change the colour back to White
Set the Line Type for the horizontal fold lines to Score, including the horizontal lines of the pop-up mechanisms. Set the Line Type for the vertical lines of the pop-up mechanism to Cut
Change the colour of the penguin beaks and feet to one of the oranges (I used Candy Corn), but leave the feet on the pop-up penguin as black
Set the colour of the igloo and archway to one of the blues (I used Bluebonnet)
You can also change the Happy Birthday colour, but I kept it as Black. If you want a different message, you can just delete the letters, add new text and then use the curve tool
Click and drag the cursor around each object and click Attach to tell the Cricut which bits go together
Click Make It on the top right corner of the screen
Step 3: Automatically Draw and Cut the Shapes
Use the Material Size dropdown menu to select the size of your card supplies
Click Continue
Follow the prompt and connect the Cricut Maker® to the computer using Bluetooth or a cable. It can take a few moments to connect, so while you are waiting, stick the card you are using to the LightGrip Mat
Under Set Base Material, select the material that best matches the weight of your card/paper. Click Browse All Materials if you need more options. For my white card, I selected Medium Cardstock (216gsm) and for the blue paper I selected Copy Paper (75gsm)
The software assumes you have the scoring wheel, but if like me you have the stylus, click Edit Tools and select the Scoring Stylus
Load the tools and cutting mat into the Cricut, as directed on your screen
Press the flashing Go button to start the machine
When the machine pauses, change the tool as prompted on your screen and press the Go button to continue. It will pause for each tool change
When it’s finished, unload the mat and remove the finished parts
Tip: To stop the paper from curling, turn the mat upside down on a clean surface and peel the mat away from the paper
Repeat this process for the other sheets, choosing Copy Paper in the material settings when you load the blue paper
Step 4: Assemble the Card
Fold along all the score lines
Glue a square of grey paper behind the igloo
Colour in the penguins with felt tip pens
Add a bit of glue to the pop-up mechanisms and attach the archway and penguin
Glue the blue paper inside the card and stick the pop-up section on top
