Pop-Up Pyramid
Intro: Pop-Up Pyramid
How to make a pyramid pop out of a plain piece of paper.
STEP 1: Draw a Square With a Couple of Gaps
STEP 2: Draw a Couple of Lines Next to the Square
STEP 3: Repeat the Square and Line
Rectangles are OK, too.
STEP 4: And Again
A couple more times should do it.
STEP 5: Cut!
Bust out the razor and cut along the lines. Goes much faster if you do all the verticals first, and then do the horizontals.
STEP 6: Pull!
Grab the center square and pull it out. Your plain piece of paper is now a funky bit of pop-up pyramidness.
STEP 7: Get More Elaborate
If you have a serious case of OCD or a laser cutter you can take a simple idea to some ridiculous extremes.
STEP 8: Change Direction
Instead of drawing squares and then lines, try drawing just squares with a 1/4 rotation in each successive square.
In other words, leave a gap on the right and left for the first, the top and bottom for the next, and back and forth and so on.
STEP 9: Change Shapes
Here's an example of a circle design with a slight twist to it. It's too subtle to really see here, unfortunately.
101 Comments
Chisom Obiukwu 9 years ago
hi
jk
nikkim 9 years ago
would it turn out okay if you use a rectangle instead or would it turn out differently?
playful-geometer 12 years ago
foks 13 years ago
Michaelgoode 13 years ago
Meganoki 13 years ago
SevereFlame 16 years ago
aqwiz 14 years ago
babymama11 15 years ago
KnexFreek 14 years ago
=SMART= 15 years ago
Kryptonite 14 years ago
uzerzero 17 years ago
SmurfJ 16 years ago
Trebawa 16 years ago
Clayton H. 15 years ago
Jesus Christ 15 years ago
struckbyanarrow 14 years ago
