Introduction: Pop Up Snowman With Honeycomb Pattern
This is an easy-to-make pop up card with can also be used for decoration purposed. Hope the instructions are clear enough :)
Step 1: Material Required
> Paper: Executive or copier sheets would be good enough. Avoid going for a paper too thin, or too thick as they would be problematic later,
> Colored sheets of paper for base, and decoration.
> Basic stationary
> Basic stationary
Step 2: Making the Honeycomb Pattern
Start by cutting circles of two different sizes. One will be the body of the snowman, other the head. So, size can be taken accordingly depending on the dimensions of the card.
8-10 circles of each size would be good enough.
Step 3:
Next, stack circles of the same size together and center fold them.
Now comes the tricky part. Once they are stacked, start applying white glue, a drop near the edge, stick both sides together and next time near the center fold line, and stick the sides together, again. Continue this step over all folds and for the smaller circles too.
The green dots in the image show position.
Next, once you are done, let it dry for a few minutes. The honeycomb pattern is now ready. At this point, you can also cut the hands and the hat of the snowman.
Step 4: Assembling
Stick the base of the circles to the card, aligning the center line of both. Also stick the hands and the hat.
If it looks something like shown in the picture, then you're going right :)
Step 5: Ready :)
You card is now ready. Personalize it in whatever way you want! :)
Step 6: Hang It!
If not a card, one can also hang it around the house or maybe like a Christmas tree decoration.
