Introduction: Popsicle Stick Grenade (pocket Size)
How much fun can you have with 5 popsicle sticks?
More than what you would think!!
In this Instructable you will make a popsicle stick grenade.
Its pretty easy and you can make one in 15 seconds once you get the hang of it.
Surprise your friends with this quick and simple popsicle stick trick
Step 1: Materials
You will need:
5 popsicle sticks ( with out the popsicle)
so eat 5 popsicles
or
go to the hobby store and pick up a bag of popsicle sticks
the first option is more fun and tastier!
so eat 5 popsicles
or
Step 2: Put the Grenade Together
Once you have your sticks its time to put the grenade together.
First take 3 of the sticks and put them into an "arrow" pattern
Make sure that the stick closest to you is vertical
Step 3: Adding the Support
Once you have the "arrow" shape, you will need to add support to hold it together.
Hold the 3 popsicle sticks at the top of the arrow with your thumb
Then slide one of the other sticks over the top stick (in the middle) but under the two outside sticks.
Now take your last stick and slide it under the middle one but over the two outside sticks, exactly opposite from the other support stick
Step 4: Rigging the Nade
Finally you need to rig the grenade to make sure that it will explode every time.
Gently take the two outside sticks (from the original 3) and pull them so that they barley sit on the middle/vertical stick.
This will let the grenade explode from 3 inches or so off the ground or table.
The second picture shows what it should NOT look like.
Step 5: Time for Fun!!
Now that the grenade is rigged to go off, its time to have some fun!!
You will want to throw them like a frisbee or a ninja star, not like a baseball.
If you do it right you can land it on a table where someone is sitting and have it explode right in front of their face.
These grenades are not dangerous but can upset people who are jumpy, so be careful who you throw them towards.
If you want to get really artsy, you can paint your sticks for an attack of color!
as a side note
this triangle design has been done by:
Van Halen
Rye2121
kneecaps
JL2013
none of their designs included my step 4, rigging the grenade
as a side note
Van Halen
Rye2121
kneecaps
JL2013
